New Reply
Weight hanging on a spring
Share Thread Thread Tools
Nov14-10, 02:16 AM   #1
Scenario: A block of mass m hanging on the end of a vertical spring with spring constant k
2. Relevant equations
When the spring has come to rest:
Vertical eqm: weight = force exerted by spring
mg = kx
Energy conservation: loss in GPE = gain in EPE of spring
mgx = 0.5*kx^2
3. The attempt at a solution
canceling x on both sides of the energy conservation equation will give me mg = 0.5*kx, which does not tally with the equation of vertical equilibrium. Why is this so?
Is there a problem with my understanding of energy conservation?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Nov14-10, 03:34 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi divineyang!
(try using the X2 icon just above the Reply box )
Quote by divineyang View Post
mg = kx
mgx = 0.5*kx^2
yes, you've lost your bounce!
if there's conservation of energy, then the weight will go speeding past the equilibrium position, and bounce happily up and down for ever and ever!
(and zero speed doesn't mean zero acceleration! )
Nov14-10, 05:50 AM   #3
so I cannot use the energy conservation approach to find the displacement of the mass? other than equilibrium of forces, how else can I find the value of x?
Nov14-10, 05:57 AM   #4
Recognitions:
what exactly is the original question?
Nov14-10, 07:43 AM   #5
i want to find the extension, x of a spring with spring constant k with a mass of m hanging on its end..
Express x in terms of k, m and g.
I want to know why its possible to derive an expression for x by using energy.
Nov14-10, 07:53 AM   #6
Recognitions:
but what are the initial conditions?
if you want to use conservation (of anything), you need a before and an after …
if the question gives you an equilibrium position, but no initial position, then there's nothing to conserve, is there?
(and then you simply use ∑F = 0)
Nov14-10, 08:56 AM   #7
oh there arent any initial conditions haha. i understand now, thanks so much!
New Reply
Tags
energy conservation, hanging, mass, spring
Thread Tools
Similar Threads for: Weight hanging on a spring
Thread Forum Replies
Statics Problem: Weight Hanging from a Rope Introductory Physics Homework 8
Weight On Hanging Supports Question Engineering, Comp Sci, & Technology Homework 4
Weight of copper hanging/submerged Introductory Physics Homework 5
Torque Problem: Weight of box hanging from Pivoting Boon Introductory Physics Homework 12
help: tension of a line with a hanging weight? Introductory Physics Homework 4
