How to built Carbon Fibre parts at home
by sanjiv
Tags: built, carbon, fibre, home, parts
sanjiv
sanjiv is offline
#1
Nov14-10, 05:16 AM
P: 2
How Can i built carbon fibre parts at home work shop?
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
Danger
Danger is offline
#2
Nov14-10, 05:50 AM
PF Gold
Danger's Avatar
P: 8,961
The same way that you would do for Fiberglas (that is, incidentally, a trademarked name). It's also the way that I make my Hallowe'en facial appliances (as you can see in my avatar). You make a positive of what you want to duplicate. In my case, that's plasticene that I sculpt onto a Styrofoam head; for you, that might be taking an original hood or whatever. Coat it liberally with mould-release compound or at least WD-40. I use paste wax, but that's just a habit from the old days. You then lay down a few layers of Fiberglas or similar substance on top of that to make a negative mould. Once that has dried, you put down your carbon fibre the same way that you would with glass—matt, resin, squeegie, matt... etc. until you have a piece that is as thick as needed. (And you don't need a lot of that ****; it's incredibly strong.) For total accuracy, you then enclose the whole affair in an air-tight garbage bag (or similar). Hook the intake side of a compressor into a hose that connects to the bag, and just vent the exhaust as usual. After that, just cut off the trim, maybe give it a wax coat if you're not going to paint it, and send it on it's way.
sanjiv
sanjiv is offline
#3
Nov16-10, 11:01 PM
P: 2
few years back, i made some parts from fibre glass using general purpose epoxy, catylist, hardner (gernal purpose name for chemicals). you mean same way i can made parts from carbon fibre? If you know the ingradients for making tennis racket kindly tell. i have to built propeller blades for my RC helicopter.
sid_raptor
sid_raptor is offline
#4
Nov17-10, 09:05 AM
P: 10
maybe this will help
http://www.howtodothings.com/home-ga...on-fiber-parts
Danger
Danger is offline
#5
Nov17-10, 06:46 PM
PF Gold
Danger's Avatar
P: 8,961
That's a good link, Sid.
Sanjiv, I can't tell you about tennis raquets. When I was playing, they were made out of wood (probably maple). I think that they started using Fibreglas sometime in the 70's, and carbon fibre maybe in the past 20 years or so. Sometime in the middle of that, they tried aluminum alloys.
dingpud
dingpud is offline
#6
Nov23-10, 07:22 AM
P: 201
http://www.dragonplate.com/
These guys have a good selection of materials and pre-fab'd round and square tubes.
xxChrisxx
xxChrisxx is offline
#7
Nov23-10, 08:25 AM
P: 2,032
CFRP != GFRP. As far as i'm aware, and I've only just started working with composites. But Carbon fibre isn't layed up the same way as glass fibre.
The 'proper' way is to create your master part out of some sort of tooling block. Layup prepreg and autoclave it to make the master mould. You then layup your carbon fibre sheets and stick it in the autoclave again to cure. Carbon, as far as i'm aware is always cured at temp and pressure if you want a high performance part. Where as GF can be cured at room temperature. So far im not aware of any reason you can't make a carbon layup at room, just that it isn't done like that.
I suppose if you vacuum bagged it and then stuck it in the oven that could do the trick.
dingpud
dingpud is offline
#8
Nov23-10, 09:19 AM
P: 201
Is this a DIY type thing? If so I don't know if an autoclave is going to be available. Something that may be useful for helping to cure some of your layups is a regular conventional oven....i.e. if you know of anyone remodeling their kitchen, they may have a perfectly good oven for glass layups.
As per fiberglass vs. carbon fiber...I think that you "can" lay them up very similarily and get decent results...again, is this a DIY type thing or are we talking professional manufacutring?
xxChrisxx
#9
Nov23-10, 10:12 AM
P: 2,032
It's a DIY job.
It should be pointed out that although it's possible it's likely to be a proper **** job without the right tools. It's like trying to do precision machining when all you have is a bandsaw and a ruler.
Carbon fibre is a pretty difficult thing to get right yourself if it's being used for anything structural. As it's an all or nothing prospect OP. If you make a hash of it the part will have no strength and is essentially scrap.
What's the application anyway? (probably the most important question).
dingpud
dingpud is offline
#10
Nov23-10, 10:35 AM
P: 201
Yeah, knowing the application will help quite a bit. And having the right tools does help tremendously. It sure is neat when you can get professional quality with non professional tools...just very rare. Time, quality, or cost....Pick two
If the OP is making something like a truss or something...check that link out...they have interlocking connectors which mate with their tubes which can give you a good base frame.
mohsinkhalid
mohsinkhalid is offline
#11
Nov27-10, 03:42 AM
P: 5
dingpud
dingpud is offline
#12
Nov29-10, 10:46 AM
P: 201
Is there an echo in here?
xxChrisxx
#13
Nov29-10, 11:51 AM
P: 2,032
ell oh ell
Register to reply
Related Discussions
any papers/ articles on carbon fibre?? Materials & Chemical Engineering 1
Odd voltages on home built PSU Classical Physics 4
Carbon Fibre Flywheel (for energy storage) Materials & Chemical Engineering 5
Carbon fibre Introductory Physics Homework 0
