Shortest Distance btw Point & Hyperbola
  • Thread starter Thread starter Monsu
    Shortest distance
The shortest distance between a point (x,y) and a hyperbola can be determined using the distance formula and the properties of the hyperbola's equation. The general equation of a hyperbola is expressed as (x-h)²/a² - (y-k)²/b² = 1, where (h,k) is the center and a and b are the distances to the vertices. By equating the distance between the point and the hyperbola, and simplifying, one can derive an equation resembling that of a circle, allowing for the calculation of the shortest distance using d = √(x² + y²).
  • Understanding of hyperbola equations, specifically (x-h)²/a² - (y-k)²/b² = 1
  • Familiarity with the distance formula, d = √((x2-x1)² + (y2-y1)²)
  • Basic algebraic manipulation skills for simplifying equations
  • Knowledge of coordinate geometry concepts
  • Study the properties of hyperbolas and their equations in detail
  • Learn advanced techniques for minimizing functions in calculus
  • Explore the geometric interpretation of distance in coordinate systems
  • Investigate optimization methods for distance calculations in analytical geometry
Mathematicians, students studying calculus and analytical geometry, and anyone interested in optimization problems involving distances in coordinate systems.
Monsu
hi, pls anyone, how would i find the shortest distance btw a point (x,y) and a hyperbola , given the equation of the hyperbola?? :rolleyes:
Here's one way:
The slope of the line that connects the given point to the one closest on the hyperbola will be the negative reciprocal of the tangent to the point on the hyperbola (i.e. the connecting line and the tangent will be perpendicular to each other).
This should give the same result(s) as explicity writing the distance between the given point and an arbitrary point on the hyperbola them minimizing it.
To find the shortest distance between a point (x,y) and a hyperbola, we can use the distance formula. The distance formula is given by d = √((x2-x1)^2 + (y2-y1)^2), where (x1,y1) and (x2,y2) are the coordinates of the two points.
First, we need to find the equation of the hyperbola. The general equation of a hyperbola is given by (x-h)^2/a^2 - (y-k)^2/b^2 = 1, where (h,k) is the center of the hyperbola and a and b are the distances from the center to the vertices.
We can rewrite this equation in the form of (x-h)^2/a^2 - (y-k)^2/b^2 = 1 as (x-h)^2/a^2 - (y-k)^2/b^2 = 0. Then, we can equate the distance between the point (x,y) and the hyperbola to the distance formula and solve for x and y.
We get the following equation: √((x-h)^2/a^2 - (y-k)^2/b^2) = √((x-x)^2 + (y-y)^2).
Squaring both sides and simplifying, we get (x-h)^2/a^2 - (y-k)^2/b^2 = x^2 + y^2.
Simplifying further, we get (1/a^2 - 1/b^2)x^2 + (1/a^2 - 1/b^2)y^2 = h^2/a^2 - k^2/b^2.
Now, we have an equation of a circle with center (0,0) and radius √(h^2/a^2 - k^2/b^2). The shortest distance between the point (x,y) and the hyperbola will be the shortest distance between the point (x,y) and the circle.
Using the distance formula again, we get the following equation: d = √((x-0)^2 + (y-0)^2) = √((x-x)^2 + (y-y)^2).
Simplifying, we get d = √(x^2 + y^2).
Thus, the shortest
  • · Replies 26 ·
