Calculating Thermal Energy Supplied by Heater in 30.0s - Kilo-joules
  • Thread starter Thread starter questionmaster
    Heater
The discussion focuses on calculating the thermal energy supplied by a heater with a resistance of 15.0 W operating at 120.0 V over a duration of 30.0 seconds. Using Ohm's Law, the power is derived from the voltage and resistance, leading to the formula Energy Transfer (J) = Power (W) x Time (s). The final calculation confirms that the heater supplies 450 J, which is equivalent to 0.45 kJ of thermal energy.
  • Understanding of Ohm's Law
  • Basic knowledge of electrical power calculations
  • Familiarity with energy units (Joules and Kilo-joules)
  • Ability to perform unit conversions
  • Study the principles of Ohm's Law in detail
  • Learn about electrical power calculations and their applications
  • Explore energy conversion techniques between Joules and Kilo-joules
  • Investigate the thermal efficiency of different types of heaters
Students in physics or engineering, electrical technicians, and anyone interested in understanding thermal energy calculations in electrical systems.
questionmaster
A heater has a resistance of 15.0 W. It operates on 120.0 V. What thermal energy is supplied by the heater in 30.0 seconds? Answer must be in Kilo-joules.
Well o_o ..it would be nice if you could try to help me with this question. Since I recently moved from Germany to the U.S. with my parents.. and we weren't at this point in my old school.
Do you mean 15 Ohms resistance?
Use Ohm's Law to calculate the power usage (voltage times current) and note that energy = power times time.
Voltage (volts) = Current (amps) x Resistance (ohms)
Power (watts) = Voltage (volts) x Current (amps)
Therefore:
Resistance (ohms) = Power (watts)
Energy Transfer (J) = Power (W) x Time (s) => E = 15 x 30
=> Answer should be 450 J or 0.45 kJ.
The Bob (2004 ©)
9K
