| New Reply |
trig word problem |
Share Thread | Thread Tools |
| Nov16-10, 02:26 PM | #1 |
trig word problem
A pedulum, which is 0.5 m long, swings back and forth. The angle of it's displacement from it's original position is modelled by: Theta = 1/4Sin(Pi/3) IN the first 4 seconds, when will the vertical displacement of the pendulum be 1 cm? 3. The attempt at a solution What I did was: Find the angle theta. The pendulum can swing to the left into an imaginary "Quadrant 3" so sin theta = 0.01/0.5 theta = _____ Then I subbed that into the equation and got a decimal answer. I was sure there was more than one answer, so in the last minute, I added Pi and _____, since it's in the third quadrant. And ended up with 3. something. The other class did this question the day before our test and ended up with 4 answers! I looked at the solutions, but one of them was 5.94 or along those lines, but it didn't satisfy what the question was looking for - the first 4 seconds That teacher also drew the 1 cm displacement on the horizontal component of the pendulum, which was odd... didn't it ask for the vertical? ? :( |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Nov22-10, 12:04 PM | #2 |
First off there will always be more than one answer when dealing with periodic functions like sine and cosine. This is why they said in the first 4 seconds! Indacating your answer should be 4 seconds or less.
I don't think your equation is right, because it means theta = a constant, because there is no variable in your equation. Is there meant to be a t in there somewhere? I worked out theta to be 88.85 (degrees) to make the vertical displacement 1 cm. I did this by drawing the diagram, using Pythagoras theorem to find the horizontal displacement then using atan(O/A) = theta. Without a variable in the equation you gave the time cannot be calculated. |
| New Reply |
| Thread Tools | |
Similar Threads for: trig word problem
| Trig equation word problem. | Precalculus Mathematics Homework | 3 | ||
| Trig Word Problem: Finding Height of a Baloon | Precalculus Mathematics Homework | 4 | ||
| Trig word problem | Precalculus Mathematics Homework | 3 | ||
| trig functions translations and combinations of transfomations word problems | Precalculus Mathematics Homework | 6 | ||
| Trig word prob | Introductory Physics Homework | 9 | ||
