Eigenvalue/Eigenvector by Inspection
  • Thread starter Thread starter BraedenP
The discussion focuses on finding one eigenvalue and two linearly independent eigenvectors of the matrix A=\begin{bmatrix} 5 & 5 & 5\\ 5 & 5 & 5\\ 5 & 5 & 5 \end{bmatrix} by inspection. The eigenvalue identified is 15, with the corresponding eigenvector being any vector of the form where x + y + z = 0. The two independent eigenvectors can be derived by setting specific values for x, y, and z, ensuring they are linearly independent. The repeated eigenvalue of 0 is also acknowledged due to the linear dependence of the matrix's columns.
  • Understanding of eigenvalues and eigenvectors
  • Familiarity with linear dependence and independence
  • Knowledge of matrix representation and properties
  • Ability to perform vector operations
  • Study the properties of eigenvalues and eigenvectors in detail
  • Learn about the geometric interpretation of eigenvectors
  • Explore methods for calculating eigenvalues and eigenvectors for larger matrices
  • Investigate applications of eigenvalues in systems of differential equations
Students studying linear algebra, mathematicians interested in matrix theory, and educators teaching concepts of eigenvalues and eigenvectors.
BraedenP
Without calculation, find one eigenvalue and two linearly independent eigenvectors of [tex]A=\begin{bmatrix}<br /> 5 & 5 & 5\\ <br /> 5 & 5 & 5\\ <br /> 5 & 5 & 5<br /> \end{bmatrix}[/tex]
Justify your answer.
N/A
This question would be incredibly easy if I could calculate the answers, but I'm not allowed to do that. How would I go about finding the eigenvalues/vectors simply by inspection?
I could use an eigenvalue of 0 to find one eigenvector, but given that the two eigenvectors I need have to be independent, I can't simply use another multiple of that eigenvector to be my second one.. I think I need to find the other eigenvalue, which I calculated to be 15, by inspection somehow.
Since all of the elements of A are the same, there's an obvious eigenvector with the same property. That gives you one nonzero eigenvalue. Also, since the columns of A are linearly dependent, you know at least one other eigenvalue. Since the 3 columns are actually equal, you know that this eigenvalue is repeated. Since the value of this repeated eigenvalue is very special, you can easily guess at the form of the other 2 eigenvectors.
We clearly have x+ y+ z= 0 for any eigenvector <x, y, z>. Taking x=0, z= -y and taking y= 0, z= -x. n That gives the two independent eigenvectors.
  • · Replies 33 ·
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 18 ·
