| New Reply |
Measurement in de broglie-bohm theory |
Share Thread | Thread Tools |
| Nov17-10, 06:16 AM | #1 |
Hi,
Could you describe the "before the measurement" mechanism in de broglie bohm theory? Is there a real collapse during the measurement? Can we determine the particle's position in its guiding function without disturbing it? Is there any way to calculate guiding function? |
| Nov17-10, 06:57 AM | #2 |
http://xxx.lanl.gov/abs/quant-ph/020818 [Found.Phys.Lett. 17 (2004) 363] See also the recent discussion in http://www.physicsforums.com/showthread.php?t=444233 |
| Nov18-10, 08:59 AM | #3 |
Then, for example in double slit experiment, why the interference pattern disappears when we are measuring the particle? Why it would not reappear when we stop measuring it?
Does the measuring particle effects somehow guiding function? After all it is the guiding function that determines its path right? |
| Nov18-10, 09:35 AM | #4 |
| Nov18-10, 09:47 AM | #5 |
But the measurement affects the path of the particle say electron. Since guiding function determines the path, shouldn't it also be effected? For example in the interference pattern we see that electrons in the screen that cannot be there classically. That means electron's path changes with the act of measurement or by decoherence.
| Nov18-10, 09:54 AM | #6 |
| Nov20-10, 10:02 AM | #7 |
Then, what is the difference between guiding function and wave function?
| Nov22-10, 03:17 AM | #8 |
| Nov22-10, 04:23 PM | #9 |
You said measuring particle is not effecting guiding function. But measurement changes the path, and path is determined by guiding function. Aren't these statements conflicting?
| Nov23-10, 03:29 AM | #10 |
What I meant is that the MEASURED PARTICLE does not effect the guiding function. But the MEASUREMENT OF the particle does effect the guiding function. |
| Nov24-10, 11:28 AM | #11 |
Ok, I realized the confusion. That's my mistake. I wanted to say "whether measurement of particle effects guiding function or not?". Ok, I understand now.
| Nov24-10, 03:19 PM | #12 |
| Nov25-10, 03:45 AM | #14 |
I did not close the topic, so I want to ask actually some other things after I finished my readings. So, of course I will thank you at the end. However, thank you Demystifier for your explanations so far. :)
| Dec17-10, 01:47 PM | #15 |
And, what is configuration space? |
| Dec17-10, 04:17 PM | #16 |
dBB is a non collapse interpretation of Quantum Mechanics. .......‘No collapse’ interpretations avoid the measurement problem by selecting other sets of observables as determinate for a system in a given quantum state........ http://www.psiquadrat.de/downloads/b...uniqueness.pdf |
| Dec20-10, 03:22 AM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: Measurement in de broglie-bohm theory
| Graduate University for de Broglie-Bohm Theory Research | Academic Guidance | 22 | ||
| Status of deBroglie-Bohm pilot wave theory | Quantum Physics | 56 | ||
| Questions about the de-Broglie Bohm interpretation | Quantum Physics | 31 | ||
| Empty waves in Bohm theory | Quantum Physics | 1 | ||
| Quantum scattering using Bohm theory?.. | Quantum Physics | 0 | ||
