How start studying Topological Insulators
The discussion revolves around the foundational topics and resources necessary for studying topological insulators within the context of theoretical condensed matter physics. Participants share their insights on essential readings and concepts, as well as the relationship between topological insulators and other areas of condensed matter physics, such as strongly correlated systems.
  • Homework-related
  • One participant seeks guidance on essential topics and resources for studying topological insulators, given their limited background in condensed matter physics.
  • Another participant recommends starting with a specific article that introduces the field and provides references to foundational papers.
  • Books on quantum field theory methods in condensed matter physics are suggested as valuable resources, particularly for those with a solid introduction to quantum field theory.
  • Electron band theory is highlighted as a crucial aspect of understanding topological insulators, with suggestions to refer to standard solid state physics texts.
  • The use of Chern classes as a mathematical tool is mentioned, with a recommendation for Nakahara's book on geometry, topology, and physics.
  • One participant inquires about the relevance of the Quantum Hall Effect as a foundational topic for studying topological insulators and requests references on this subject.
  • A question is raised regarding the correlation between studying strongly correlated systems and topological insulators, with concerns about the potential shift in research focus and methodologies.
  • Another participant shares their experience with the Quantum Hall Effect, noting that original papers were more beneficial than textbooks for understanding the topic.
  • The necessity of learning algebraic topology to fully grasp the concepts related to topological insulators is mentioned.
Participants express varying opinions on the best starting points and resources for studying topological insulators, indicating that no consensus exists on a singular approach. Additionally, there is uncertainty regarding the relationship between topological insulators and strongly correlated systems.
Participants acknowledge the importance of foundational knowledge in solid state physics and quantum field theory, but specific assumptions about prior knowledge and the depth of understanding required remain unaddressed. The discussion reflects a range of perspectives on the necessary mathematical tools and concepts without resolving the complexities involved.
This discussion may be useful for graduate students or researchers beginning their studies in condensed matter physics, particularly those interested in topological insulators and related topics.
trustinlust
Hi all,
I'am starting a Phd In Theoretical Condensed Matter Physics, and I would like to produce a thesis on the Topological Insulators topic. Unfortunately I don't have a background in Consensed Matter Physics (in my curriculum there are exams about General Relativity, Quantum Field Theory and Statistical Mechanics) and I know only a bit of Solid State Physics. So, here's the question: what are the initial and essential topics which I should study and know (and on which books) to start managing (in a good way) topological insulators as soon as possible?
Thanks
This article should be your starting point:
http://arxiv.org/abs/1002.3895
Not only does it provide a very nice introduction into the field, it also provides a large number of references to articles which started the field.
It's hard to point out what you exactly need to know to understand these papers. Part of a PhD is to figure out what mathematical tools and physical principles you need to learn to understand the articles and perform your own research. If you have had a solid introduction into Quantum Field Theory then I highly recommend diving into one or more books on quantum field theory methods in condensed matter physics, such as:
https://www.amazon.com/dp/0521769752/?tag=pfamazon01-20
https://www.amazon.com/dp/0198566336/?tag=pfamazon01-20
These books are should be accessible enough.
A very important aspect of topological insulators that comes to mind is electron band theory. A book on solid state physics like Ashcroft and Mermin or Kittel should do the trick.
Another mathematical tool that is frequently used is that of Chern classes. Try Nakahara.
But again, start with the article I mentioned in the beginning (Kane is one of the people that made this field what it is today). Dig up the articles they refer to -- you'll soon come across concepts that you won't be familiar with. The trick is to find a proper source which explains it.
Thanks for the exhaustive reply, Xepma. Only some other question.
Do you refer to "Geometry, Topology and Physics" Nakahara's book? Is it correct?
Someone told me that Quantum Hall Effect is the starting point of all the topological problems in Condensed Matter, and that it should be useful to start studying this subject. Can you give me some references for this topic too?
Thanks
An other question:
In future I would like studying Strongly Correlated Systems in Condensed Matter, too. Do you think these two topics (Strongly Correlated Systems and Topological Insulators) are correlated? Or it would be - considering how highly specialized the research in physics is, nowadays - a considerable change of research area? (different methods, different mathematical tools used,...)
I studied the quantum hall effect in the spring as a reading course, and I mostly read the original papers. As long as you have some basic knowledge of solid-state physics, they are pretty accessible as long as you start at the beginning and then work your way up. I found the original papers more useful than textbooks since they went into much more detail. Eventually you'll need to learn some algebraic topology to get the full picture (that's where Chern classes come up, as mentioned above).
