| New Reply |
Dewatering Fiberglass - Vacuum |
Share Thread | Thread Tools |
| Nov18-10, 03:07 PM | #1 |
Picture a 15' sailboat with a hull made of a sandwich (from the outside in) of gelcoat (relatively impermeable), resin-impregnated fiberglass, stiff closed-cell foam, then more resin-impregnated fiberglass (which you see looking into the boat).
The foam is not one piece, but a grid of 2" x 4" pieces of foam on a flexible backing, like bathroom tiles. When flat and particularly when shaped around corners, there are voids between the foam pieces. Rain falls on the boat. Small voids in the fiberglass layer allow water to penetrate the sandwich. Osmosis draws the water throughout the sandwich, leaving water in the voids. Voila. A hull that weighed 240 pounds when built weighs 350 after just a few years. We're going to try pulling a (deep) vacuum on a small part of the inside of the hull, after drilling some holes through the glass. If we can maintain a solid vacuum the water should flash to vapor and be collected in our cold trap (so we don't go through gallons of pump oil). But is there a better/easier way? THE QUESTION What if we vacuum bagged the entire hull, which wouldn't be hard, and then pulled a partial vacuum? We wouldn't seek to reach the boiling point of the water (or, well, crush the boat), but to increase the rate of evaporation. What is the relationship between (just) pressure and evaporation rate, and then among those and airflow? There will be some airflow, of course, through the bag material and our (presumably) crappy sealing job. We could regulate higher airflow into the bag. And temperature...the boat will be in a shack where we could probably maintain the temperature at 16oC or so (this is Toronto, in November), and we could put a small heater inside the bagged boat. In short, what conditions would maximize the evap rate, as a practical matter? I've picked through a dozen threads on evaporation v pressure, but honestly they're beyond my basic physics. I'm pretty sure I never advanced through Poynting's Correction or any of the higher math. Any help would be much appreciated. FWIW you'll be helping a non-profit community club that just wants our boats to be lighter, faster and to last longer. Cheers...Ralph Edited to add: For years we've tried putting a dehumidifier and space heater in a bagged boat, for months on end, to little or no avail. It may be that the attractive force between the water and the sandwich demands a flash to liberate the water reasonably quickly? |
| Nov18-10, 04:10 PM | #2 |
Welcome to PF, Ralph. I can't help you with any formulae, but I have an idea that might or might not be useful. Since I don't know how often you'll have to do this, or how much coin is at stake, I obviously also don't know how much you're willing to spend. My thought is to drill only two holes in the hull, at opposite ends. Attach a desiccant canister (maybe silica beads) to one hole and force air through the other one. The sort of air filtration units available for machine shop pneumatic systems would perhaps be suitable. I have no idea of whether or not that will work, but it might be worth investigating.
The two things that really puzzle me about this are why anyone would need a sailboat in Hogtown, and why someone named Ralph has the title "Miss". Are they related? If so, would I want to know? edit: In checking over this post, I noticed an inconsistency in my logic. If you're forcing air through the hull, the desiccant at the exit is irrelevant; any transported moisture would simply disperse into the ambient air. The desiccant should be in the input line. Oops... ![]() 2nd edit: Are you the owner of the boat, or a manufacturer thereof? If the latter, I would suggest adding a flexible waterproof membrane to link the foam pieces. |
| Nov18-10, 04:41 PM | #3 |
Thanks, Danger. That's a good suggestion, and those are fair questions.
Dessicant: I looked at using a dessicant canister but concluded that if we're trying to remove maybe 5-10 gallons of water it would be impractical to do it one pint (or so) at a time. I assume there's no such thing as a "self-draining dessicator" because the dessicant needs to be replenished. And any such thing would cost way more than our little budget could bear. Sailing in Hogtown: As you seem to know of our little town (aka "The Big Smoke", or {until recently} "The City With the World's Biggest Prick") you will know it's on a very big and often windy lake. Apart from the many gin-and-tonic yachts, the fleet of boats I race regularly has 50 entries in our weekly races, making it (kid you not) the largest regular one-design race series in North America. The sailing club owns the boats and is a ten minute drive from where I live. Miss Gradenko: Is a holdover handle from a politics website I used to frequent, where I was sometimes letting my feelings show. Best I can reckon, my only latency is my mild liberalism, which got quite a workout facing down members of the then-nascent Tea Party. Don't get me started on that, particularly if you believe anti-matter has only been around for 6000 years or so. Cheers...Ralph A good flight is any flight you walk away from. It's a great flight if you can use the plane again. |
| Nov18-10, 05:11 PM | #4 |
Re edit #1: Wouldn't the dessicant be on the exhaust side? Oh wait, I see what you're saying. I guess it amounts to "be sure to blow dry air through the hull".
Re edit #2: No, I just use the boats, owned by our club, for the grand cost of $400 per year. (FYI, we attract lots of engineer/physics types who join us in going out of our minds trying to make them go fast.) The builder only recently started to fill the voids in the foam, before laying-up the inner glass layer, with some kind of paste to avoid (ptp) this very problem. |
| Nov18-10, 09:43 PM | #5 |
Your mention of "often windy" was exactly why I wondered about sailing on Lake Ontario. I've always thought of it being too choppy for comfortable boating. I had no idea of the volume of water that you are dealing with; I was thinking maybe half a litre or so. Still, I think that desiccated air injection might be the best approach. To compensate for the amount of water involved, perhaps the boat should be hung by the stern in a vertical position (if space allows). Inject the air from the top and let both it and gravity assist in the moisture drain through the bottom. Again, just an amateur suggestion. I had no idea that those Tea Party morons had any presence on the intelligent side of the border, and the thought disgusts me. |
| Nov18-10, 10:06 PM | #6 |
Regarding desiccant, a good, cheap, bulk source for desiccant is kitty litter. Not all litter is silica gel based though, so make sure you buy one that is. Even if you go with your original idea, it might be worth tossing some in the bag with the hull. The internet seems to agree that silica gel can absorb 40% of its weight in water. A 25 lbs box should then do just over a gallon, and then need to be recharged.
| Nov18-10, 11:24 PM | #7 |
Cool idea about the cat litter, Dale. Most that I'm familiar with is made of clay rather than silica, but even that stuff has great absorbency. It's always my first choice for oil or antifreeze spills. If you are suggesting putting it inside the hull, though, I foresee one possible problem. The stuff expands as it absorbs, so you might just end up with huge clumps of unremovable mud stuck in there.
| Nov19-10, 12:00 AM | #8 |
If I understand you correctly this is a boat design with all parts removable. If I understand you correctly, for winter storage the boat can be stripped back to just the hull, allowing you to compare the current weight to when it was first built. (And you find that in a couple of years the hull gains a whopping 110 pounds.) Obviously this would not occur if the outer layers would be perfectly impermeable, but equally obviously, if a perfectly impermeable coat would exist you would be using that. I wonder, is it possible to use a highly permeable gelcoat on the inside of the hull? As I see it, the problem is that the water is trapped in between the layers. You describe that storage in a heated place does little to nothing to make the water migrate out again. What if you can make it easier for water vapor to escape? Ideally the inside coat would have to be a material with the properties of goretex. Some general remarks about drying: As long as water vapor can escape you can dry things at any temperature (preferably above freezing, but then again, ice does evaporate). Clothes hung out to dry will dry because the gentlest of a breeze transports water vapor away. (Inside the house no breeze hence longer drying time.) When water vapor is moved away more of the remaining water turns to vapor. The only thing that stops water from vaporizing is if the surrounding air is saturated with that water's vapor. Replace the air with unsaturated air and evaporation continues. A desiccant may offer a little speedup, but I don't expect much. For that hull I think the biggest issue is the fact that the water is trapped in the first place. I wonder, what if you drill tiny holes in the inside coat, and treat the surface with a strong water repellent, to try and mimick the properties of goretex. Maybe the water repellent is effective enough that during sailing on the lake liquid water won't find its way down the holes, but that in storage water vapor has a way of escaping. (Risky move though; it's only effective if thousends of holes are made, and if it doesn't work as hoped then the problem is worse.) Using just two holes, one for letting in air to the inbetween layer, and one hole to apply suction, I am doubtful. The motion of air is unlikely to spread everywhere. Probably most of the air flow will be along the shortest path, leaving most of the hull without any air motion. |
| Nov19-10, 08:56 AM | #9 |
Man, you guys rock.
I wake up and find my thread flooded like I posted a Trig Birther rant. Thanks for that. I have comments on all of the above, including a survey of various techniques we've tried in past years, but gotta run for now. I hope you'll check back after I post so we can get to ground on this. One thing I don't see is whether pressure has any effect on evaporation, and if so how much. We bought a 5cfm vacuum pump (used, for $200) so we can move the pressure around pretty well, and with some airflow. Cheers...Ralph Michael: Explain it to me like I'm 8 or something. Oscar: [lemonade stand explanation for surplus funds] Michael: OK, explain it like I'm 5. |
| Nov19-10, 09:28 AM | #10 |
As for the waterlogged hulls. It seems to me getting air to move is the key thing. What about creating suction at one point, and multiple holes for air to flow inbetween the layers? The inlet holes can be opened and closed in sequence, to maximize the chance that over the course of a drying treatment all parts of the hull get a period of air flow. Perhaps it is possible to monitor the weight continuously. If you actually see a weight drop from day to day you know you're on to something. Conversely, if you see no change of weight for days on end you can decide to pull the plug. |
| Nov19-10, 11:52 AM | #11 |
After posting that and doing a few more searches though, it seems that litter that is made up of only silica isn't that common. Most of the 25 lbs boxes I saw that mentioned crystal (in the litter world crystal = silica gel), are just clay with silica added. I'm not sure how large and cheap a container of pure silica gel you can get. The link I posted before quoted $5 for 4 lbs at Petco. |
| Nov19-10, 12:06 PM | #12 |
I have a GRP sailing cruiser and have read a lot of forum posts (Westerly Owners Association and others) about this topic. The 'Hot VAC' system is used successfully for drying out hulls with the dreaded fibreglass 'osmosis' You heat an area of the hull with IR heaters and apply a large 'sucker' to the surface with a vacuum unit. It's a long job. You keep moving the site of the sucker around the hull. It's electrical energy hungry but it works.
| Nov19-10, 03:55 PM | #13 |
OK, there's a lot to cover. Please bear with me, and thanks again for your help.
Hot Vac: Yup, Sophie, our Plan A is to try to achieve the poor man's Hot Vac. Apply a deep vacuum to a portion of the hull, heat it up and flash off the water. But if our inline cold trap isn't efficient then we'll end up fouling gallons of vacuum pump oil at $30/gallon. As of today I have all the pieces to give Plan A a go this weekend, and will report. But Plan B, the driver of this thread, is to put the whole hull in a vacuum bag and try to dewater the sandwich through evaporation. Hence my question whether a partial vacuum will speed evaporation. I just don't know. Ingress: The water gets into the sandwich through voids in the sandwich. The most problematic void is at the inside back of the boat where the floor meets the vertical transom. This seam flexes and invariably cracks, and because the boats are stored outside during the summer with the bow elevated, rainwater pools right there. Other voids are where there are through-hull fittings. We do our best to silicone them, but they are probably contributors. I should mention that the dewatering is only Step 1 of our experiment. If it works - if significant water weight is lost - then Step 2 will be sealing up as many of these ingress points as possible so that Step 1 is not for naught. Sandwich Channels: One problem with blowing air through the sandwich, end-to-end or otherwise, is that although there are lots of voids there may not be enough! That is, when the sandwich is laid-up (no vacuum is used), the resin will seep into some of the voids and seal them from adjoining ones. So we can't rely on the passages down the cut lines of the foam being free of blockages. Dessicant: For dessicant to work it has to be in contact with the water in its liquid or vapor state. We can't contact the water in its liquid state, because it's trapped in the sandwich. And if we're liberating it from the sandwich through vaporization (by way of evaporation or boiling/flashing) then the job is already done and it's just a question of evacuating the vapor. We don't need to collect the water, though it would be interesting to see just how much we get out. I think I've got this right... Monitoring Weight: Yup, we borrowed an electronic scale and will be working on the boat as it hangs underneath from a sling. Drilling Holes: On either Plan A (deep vacuum) or Plan B (partial vacuum evaporation) we will drill holes from the inside of the hull through the resin-impregnated fiberglass into the foam layer. We'll try to put the holes into the voids between the foam pieces, because the closed-cell foam is dry (of course) and we want to access as much of the channel matrix (see "Sandwich Channels" above) as possible. Past Efforts: This has been a problem for 20 years. With temperature, vapor pressure and airflow being the most important variables (I think), we have kept hulls heated in a garage for months, wrapped them (with voids for airflow) with a heater and/or dehumidifier inside for months, in each case with and without holes drilled into the sandwich. Little or no water was lost, but Ontario Hydro gained nicely. Gravity: Hanging the hull from one end could be done, but I doubt this would work as I'm presuming it's the attractive force between the water and the components of the sandwich that's distributing the water throughout the hull and making it hard to get out. Gravity would help, of course, but how much? If only a little, the hang time could be longer than...a Toronto winter. Interior Parts: Cleonis asks whether the interior parts are removable. They are really not. Attached to the hull are sealed side tanks and a bow tank. These provide a place to sit, and add buoyancy when we flip (see "Comfortable Boating" below). This is among the reasons why Plan A is not the best, because we can't access all of the hull from the inside without tearing out these tanks. Maybe the "sandwich channels" will allow the vacuum to penetrate these inaccessible areas, which would be great so long as the back pressure isn't so much as to kill the vacuum. We have a moisture meter and will be measuring lots of stations as the experiment unfolds. We could pull the deep vacuum from the outside of the hull (like the Hot Vac folks), but this would require that all the gel-coat be stripped off and then later replaced, which is a big undertaking (particularly considering these hulls get polished to 2000 grit or more). Comfortable Boating: Danger, I respectfully chuckled when you suggested Lake Ontario is too choppy for comfortable sailing in such a small boat. At risk of sounding needlessly macho, the club's boats are indeed used for teaching and pleasure sailing in sheltered bays, but when raced are pushed to their max. Bashing through (or, faster, planing over) 5-foot waves in 25 knots or more is a balls-out, ovaries-out, thrill. And doing it NASCAR-style, 4 or 5 boats abreast, is a ton of fun. So the racing is quite competitive. 1/10th of a knot slower means I just lost the 2-mile race by a lot. (Trust me, I know all too well.) And heavier boats are slower, which is why the water is a problem (it also causes accelerated degradation, but that's a secondary concern). Photos: If I'd known my evaporation question would have spawned such creative replies I would have added some pictures from the beginning. Here's a pic of three Albacores planing down a deep reach in 20 knots or so (I'm in the middle, in CAN 8016): ![]() And here's a pic of the inside stern of an Albacore hull (note the side tanks): ![]() I trust you'll agree that's enough for now. I look forward to your thoughts, and thanks again. Cheers...Ralph |
| Nov19-10, 05:28 PM | #14 |
Heat (very expensive) will speed up any drying process because hot air absorbs much more water vapor than cold air does, and I suppose that in general any material that absorbs water will absorb more of it when hot. Lowering air pressure may have the paradoxical effect of slowing down the drying process because the thinnner air can carry less water vapor. My hunch is that since the water is so badly trapped you are just not going to get any convection. And lowering pressure will work if and only if you can get significant convection. I get the impression that the only way for the water to come out is to come out the way it came in: by migrating through the marginally permeable coatings. By agressively drying the top surface of the coating water from deeper layers of the coating can migrate to the top surface (allowing water from the sandwiched layer to migrate outward etc.). I guess that if (a section of) the hull is heated this migration can proceed faster. I suppose that in big money racing the boats are lifted out of the water all the time, so that the hulls spend very little time in actual contact with water. (That sounds seriously weird to me: boats that need to be kept away from water.) |
| Nov19-10, 05:52 PM | #15 |
Thanks, Cleonis.
I grasp the seeming paradox, but if nature abhors a vacuum then won't the water evaporate more quickly to fill that vacuum? Put simply, if the inner hull surface temp is 16oC and the air pressure is lowered by 20%, to 24 inches, will that pressure change materially accelerate evaporation, presuming sufficient airflow to clear the boundary layer? Or does pressure only make a material difference as the boiling point is approached? As for the marginally permeable coating, we're planning to drill holes through it to expose some of the voids (and maybe a lot of the voids, if the channels are open) to the air so that the relevant surface area is increased. And in fact these boats are kept out of the water when not being sailed. The ingress is not through the outer gelcoat layer to any appreciable extent, but from the water migrating from voids on the inside surface of the hull. I think you can rest comfortably in knowing that although water molecules are very small, such that few compounds are actually waterproof, the hulls of boats are, for all practical purposes, sufficiently water resistant. ![]() Cheers...Ralph |
| Nov19-10, 10:29 PM | #16 |
Let me make a comparison. A Torricelli barometer: http://www.ems.psu.edu/~nese/f4_2.htm The vacuum that is drawn is a very good vacuum. In effect the Mercury does not vaporize at all. (The amount of Mercury vapor above the Mercury column is negligable.) Mercury that is left to stand does vaporize, but the question is, what gives the fastest evaporation? Fastest evaporation, I think, is when there is normal air pressure above the Mercury, and convection, continuously replacing the air, so that the air close to the Mercury is never saturated. Slower, I think, is when a vacuum is maintained around the mercury. The fact that a vacuum is maintained will interfere with the necessity for convection. With little to no convection, you get an equilibrium with just as many mercury molecules returning to the liquid as are evaporating from it, leaving you with zero net evaporation. Getting back to the case of water: Think of evaporation of water into air as similar to dissolution of a substance into a liquid, such as dissolution of sugar in coffee. Hot air can carry a larger percentage of water. In a sense one might say that more water can dissolve in hot air than in cold air. That is one of the reasons that heat speeds up drying. In a case where you can maintain convection I actually expect that by increasing pressure you can increase drying capacity. (Generally a solution will saturate at a particular percentage. So I expect double pressure air to carry twice as much water vapor.) Conversely, the extreme case of no air at all. Water does evaporate into vacuum of course, but the vapor pressure of water is quite small. Certainly it is far less than atmospheric pressure. So if you are in a situation where maintaining a degree of vacuum reduces the volume of convection then you lose drying capacity. Anyway, by the looks of it isn't possible in the first place to get any convection where you really need it. I get the impression that drying out the hull is as difficult as drying an egg. The egg's membrane is hardly permeable to water. There is very little you can do to speed up drying of an egg. Warmth and convection are your best shot. A vacuum (with correspondingly reduced convection), I don't see that helping you. (I wonder: could it be that drying an egg is actually a good model for drying the hull? If so then you can set up small scale experiments.) |
| Nov19-10, 11:10 PM | #17 |
Wikipedia water vapor pressure graph I expect that at 16oC you are not going to come anywhere near the low pressure level for water to boil. In other words, I don't see a higher evaporation rate at the achievable lower pressure. |
| New Reply |
| Tags |
| airflow, evaporation, fiberglass, pressure, vacuum |
| Thread Tools | |
Similar Threads for: Dewatering Fiberglass - Vacuum
| Compression or Tensile on Fiberglass | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Einstein Vacuum Equation, Vacuum Constraint Equations | Special & General Relativity | 2 | ||
| Do vacuum fluctuations contribute to vacuum polarization | High Energy, Nuclear, Particle Physics | 2 | ||
| Vacuum to Vacuum Amplitudes and Functional Integrals | Quantum Physics | 9 | ||
| Does a Vacuum Cleaner work inside a Vacuum? | General Physics | 12 | ||
