Rope, Pulleys. and Lots of Tension
The discussion focuses on a physics problem involving a 7 kg monkey climbing a massless rope over a frictionless tree limb, which is connected to a 20 kg package on the ground. The calculations for the monkey's acceleration required to lift the package off the ground were determined to be 18.2 m/s², while the monkey's acceleration while holding onto the rope is 3.43 m/s². The tension in the rope, which was initially unanswered, is calculated to be 196 N based on the weight of the package and the acceleration due to gravity (9.8 m/s²).
  • Understanding of Newton's Second Law (F=ma)
  • Basic knowledge of gravitational force and weight calculation
  • Familiarity with concepts of tension in ropes
  • Ability to solve equations involving multiple forces
  • Study the concept of tension in static and dynamic systems
  • Learn about free body diagrams and their applications in physics problems
  • Explore advanced applications of Newton's laws in real-world scenarios
  • Investigate the effects of friction on tension and acceleration in pulley systems
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of tension and acceleration in pulley systems.
kazimo
Rope, Pulleys... and Lots of Tension!
hey,
For the following problem a picture is really needed so I tried drawing one on Paint and uploading a bitmap file ut it said that it was too large...
A 7 kg monkey climbs up a massless rope that runs over a frictionless tree limb and back down to a 20 kg package on the ground.
(a) What is the magnitude of the least acceleration the monkey must have in order to lift the package off the ground?
Assume that after the package has been lifted, the monkey stops its climb and holds onto the rope.
(b) What is the monkey's acceleration?
(c) What is the tension in the rope?
What I did was use the Equation Force = Mass * acceleration.
Using tension as the force the equation for the monkeys side became
Tension= Mass*(acceleration of gravity + acceleration of monkey)
My answer for (a) was 18.2 m/s^2
(b) was 3.43 m/s^2
(c) I couldn't answer it...
Please help me.... I have spent already 4 hours on this single problem already.
Kazim
Correct.
(b) was 3.43 m/s^2
How did you get this?
If you know the monkey's acceleration, then you should be able to find the tension in the rope that will produce that acceleration.
Great job on using the correct equation for this problem! Your answers for (a) and (b) are correct. To find the tension in the rope, you can use the equation F=ma again, but this time for the package. The package is not accelerating, so the only force acting on it is gravity, which is equal to its weight, mg. Therefore, the tension in the rope is equal to the weight of the package, which is 20 kg multiplied by the acceleration of gravity, 9.8 m/s^2. This gives a tension of 196 N.
Keep up the good work and don't hesitate to reach out for help if you get stuck on a problem. It's always better to spend a little extra time to fully understand a concept than to rush through and potentially make mistakes. Good luck!
  • · Replies 38 ·
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 27 ·
