Thread Closed
Connes & Marcolli paper on renormalization
Share Thread Thread Tools
Oct21-04, 02:47 AM   #35
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\n\nArnold Neumaier wrote:\n&gt; Chris Oakley wrote:\n&gt;\n&gt;\n&gt;&gt;&gt;No, I\'m saying that you have no right to expect that the theory works to\n&gt;&gt;&gt;infinite energy when you\'ve only tested it to ~1 TeV.\n&gt;&gt;\n&gt;&gt;I am not sure that I am following you here. Before renormalization QFT as\n&gt;&gt;normally practised leads to infinite cross sections and decay rates. I have\n&gt;&gt;seen it claimed that the infiniteness is because there is something going on\n&gt;&gt;at extremely high energies that we do not fully understand that rescues the\n&gt;&gt;situation at low-energy - the "ultraviolet completion".\n&gt;\n&gt;\n&gt; This is nonsense. Infinities arise because integrals taken over\n&gt; unbounded momenta don\'t exist; so doing it leads to nonsense.\n&gt; Instead, proper QFT takes regularized integrals, for example by\n&gt; adding an explicit cutoff Lambda. This simply means that they\n&gt; calculate with an action that depends on Lambda as an additional\n&gt; parameter. Once this is done, everything is finite, but\n&gt; Lambda-dependent.\n&gt;\n&gt; The only problem with that is that the cutoff destroys Lorentz\n&gt; covariance - apart from that it would be a completely respectable\n&gt; field theory in itself. Now Lorentz invariance is violated only\n&gt; at momentum &gt; O(Lambda); hence to have the theory conform to\n&gt; physics that can be checked it suffices to take Lambda large.\n&gt; But for aesthetic reasons or since we believe that symmetries are\n&gt; fundamental, we want to have fully invariant theories. This requires\n&gt; that we let Lambda go to infinity.\n&gt;\n&gt; But in order that the results have a finite limit we must at the\n&gt; same time make the coupling constants g dependent on Lambda.\n&gt; If this is done in a correct way (and the textbooks on QFT teach\n&gt; one or more of the known correct ways), one encounters no infinities\n&gt; at all in the whole process.\n&gt;\n&gt;\n&gt;\n&gt;&gt;I see the Feynman-Dyson approach to QFT as failing to give sensible\n&gt;&gt;or even finite answers to physical quantities, but I do not see this\n&gt;&gt;phoenix-like rebirth after all the infinities have been conveniently wiped\n&gt;&gt;out as anything more than just wishful thinking.\n&gt;\n&gt;\n&gt; The approach that gives infinities is the pre Feynman-Dyson approach,\n&gt; while what you call \'wishful thinking\' is the advance that earned\n&gt; Feynaman, Schwinger and Tomonaga the Nobel prize. They showed how to\n&gt; _avoid_ the infinities completely, on the perturbative level, and the\n&gt; renormalization group explains why the result is still meaningful as\n&gt; a \'perturbative\' approach, although at first sight, very large corrections\n&gt; seems to be involved.\n&gt;\n&gt;\n&gt; Arnold Neumaier\n\nYour setting Lambda to infinity is fine. That\'s what Feynman et al. did,\nand how they obtained a finite and accurate S-matrix. The problem with\nthis approach is that masses and coupling constants are infinite. In\nother words, the Hamiltonian of the theory is infinite. In other words,\nyou cannot do time evolution. You may say that nobody needs time\nevolution in high energy physics. And you will be partly correct: almost\nall existing experiments are well described by the S-matrix, i.e., the\nrelationship between remote past and remote future.\n\nHowever, I presume that every physicist believes that there is\nsome non-trivial time evolution of interacting physical systems\nbetween the two time extremes. Such time evolution is evident\nin macroscopic low-energy systems, for example.\nQFT ignores that. That\'s the main\nproblem, why renormalization approach of Feynman, Tomonaga, and\nSchwinger is not the final word in QFT.\n\nEugene\nwww.geocities.com/meopemuk\n\n\n\n\n&gt;\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Arnold Neumaier wrote:
> Chris Oakley wrote:
>>>No, I'm saying that you have no right to expect that the theory works to
>>>infinite energy when you've only tested it to ~1 TeV.
> unbounded momenta don't exist; so doing it leads to nonsense.
> adding an explicit cutoff [itex]\Lambda[/itex]. This simply means that they
> calculate with an action that depends on [itex]\Lambda[/itex] as an additional
> [itex]\Lambda-dependent[/itex].
> at momentum [itex]> O(\Lambda);[/itex] hence to have the theory conform to
> physics that can be checked it suffices to take [itex]\Lambda[/itex] large.
> that we let [itex]\Lambda go[/itex] to infinity.
> same time make the coupling constants g dependent on [itex]\Lambda[/itex].
> while what you call 'wishful thinking' is the advance that earned
> a 'perturbative' approach, although at first sight, very large corrections
> Arnold Neumaier
Your setting [itex]\Lambda[/itex] to infinity is fine. That's what Feynman et al. did,
QFT ignores that. That's the main
Eugene
Oct21-04, 02:47 AM   #36
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\n\nChris Oakley wrote:\n&gt; Let\'s just remember how we got to where we are:\n&gt;\n&gt; (i) We solved free field theory, including the expansion in terms of\n&gt; annihilation and creation operators.\n&gt; (ii) We introduced an interaction term in the Lagrangian density.\n&gt; (iii) We introduced a unitary transformation that turns free fields into\n&gt; interacting fields using the Interaction Picture.\n&gt; (iv) We wrote out the Interaction Picture time evolution operator as\n&gt; time-ordered products of the interaction.\n&gt; (v) We reduced the time-ordered products to normal-ordered products.\n&gt; (vi) We obtained thereby the S-matrix for scattering processes involving a\n&gt; finite number of incoming particles with definite four-momentum scattering\n&gt; to a finite number of outgoing particles with definite four-momenta as a sum\n&gt; of Feynman diagrams.\n&gt;\n&gt; Many of these Feynman diagrams are pathologically divergent integrals.\n&gt;\n&gt; My response: This is because the theory is fundamentally flawed. Go back to\n&gt; (ii) and try again.\n&gt;\n\nI would like to suggest a different path (similar to what Weinberg is\nwriting in his book):\n\n(i) We constructed the Fock space as direct sums of tensor products of\n1-particle spaces\n(ii) We defined a non-interacting representation of the Poincare group\nthere, including non-interacting Hamiltonian H_0 and\nboost operator K_0\n(iii) We defined interaction terms in the Hamiltonian and boost\noperator H= H_0+V, K = K_0+W (all operators are expressed through\nparticle creation and annihilation operators, no fields)\n(iv) We found that S-matrix is ultraviolet divergent\n(v) We added renormalization (infinite) counterterms to the\nHamiltonian H\' = H+R , so as to\nmake S-matrix finite and in agreement with experiment.\n\nThis is where QED stands now: finite and perfectly accurate S-matrix\nobtained from infinite (wrong) Hamiltonian H\'. My suggestion is\n\n(vi) Apply unitary dressing transformation U to the Hamiltonian H\',\nso that\n\n1) the new Hamiltonian\n\nH\'\' = U H\' U^{-1}\n\nis finite\n\n2) The S-matrices obtained with H\' and H\'\' are exactly the same.\n\nNow you can forget the nightmares of QFT, canonical quantization,\nHaags theorem, etc. You can use H\'\' in all usual quantum mechanical\nformulas (obtain time evolution operator, S-matrix, bound states via\ndiagonalization, etc) without any need of regularization,\nrenormalization, and other tricks.\n\nEugene\nwww.geocities.com/meopemuk\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Chris Oakley wrote:
> Let's just remember how we got to where we are:
> (ii) and try again.
1-particle spaces
there, including non-interacting Hamiltonian [itex]H_0[/itex] and
boost operator [itex]K_0[/itex]
operator [itex]H= H_0+V, K = K_0+W[/itex] (all operators are expressed through
Hamiltonian [itex]H' = H+R ,[/itex] so as to
obtained from infinite (wrong) Hamiltonian H'. My suggestion is
(vi) Apply unitary dressing transformation U to the Hamiltonian H',
so that
H'' [itex]= U H' U^{-1}[/itex]
is finite
2) The S-matrices obtained with H' and H'' are exactly the same.
Haags theorem, etc. You can use H'' in all usual quantum mechanical
Eugene
Oct21-04, 02:47 AM   #37
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n&gt; Haag\'s theorem does not apply since the theory with cutoff is not\n&gt; Lorentz invariant.\n\nOne cannot be so glib. In the only case of physical interest (Lambda =\ninfinity) the theory *must be* Lorentz invariant.\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Haag's theorem does not apply since the theory with cutoff is not
> Lorentz invariant.
One cannot be so glib. In the only case of physical interest [itex](\Lambda =[/itex]
infinity) the theory [itex]*must be*[/itex] Lorentz invariant.
Oct21-04, 02:47 AM   #38
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\n\nChris Oakley wrote:\n&gt;&gt;Well, you can throw out the theory, but that seems a bit drastic.\n&gt;\n&gt;\n&gt; I believe that one has no choice. One can in any case find holes in the\n&gt; cutoff procedure. Supposing, for example, we were to choose Lambda as a\n&gt; function rather than a constant. Furthermore, let us make it a function of\n&gt; variables that never even entered the original equations. There is no reason\n&gt; in principle why we should not be allowed to do this. We then very rapidly\n&gt; get nonsense. You will then say that it was my own fault for not making it a\n&gt; constant, but all that means is that you can find a path through the\n&gt; minefield. It does not mean that the minefield has ceased to exist.\n&gt;\n&gt; There is no such thing as "reasonable" in theoretical physics, there is only\n&gt; mathematical logic. The pillars of our current understanding of physics,\n&gt; namely quantum mechanics and special relativity, both defy common sense. One\n&gt; becomes aware of this very quickly when one tries to explain them to an\n&gt; intelligent non-physicist. You and Dr. Neumaier say that it is\n&gt; "unreasonable" to have four-momentum integrals extending to infinity,\n&gt; leading you to want to cut them off. I say that if the mathematical logic\n&gt; leads one there, then one has no choice other that to accept it, and if this\n&gt; leads to nonsense then one has to accept that that something is\n&gt; fundamentally wrong with the approach.\n&gt;\n&gt; Let me be clear on this - I could not do any better. All my attempts to find\n&gt; a rigorous way of doing Feynman-Dyson perturbation theory failed. This puts\n&gt; me in good company with Dirac, Pauli, Feynman, the axiomatic field theorists\n&gt; and many others. But in the end, I just decided that it was not worth\n&gt; rescuing, tore everything up and started again. And - intermittently, at\n&gt; least - I am still working on that.\n&gt;\n&gt;\n\nHi Chris,\n\nI share your frustration with renormalized QFT. I think I know the way\nto fix the problem of infinities. The idea is very simple: QED simply\nuses a wrong Hamiltonian. There is a rigorous way how to find a new\nHamiltonian of QED (while preserving the relativistic invariance and\ncluster separability) which is\n\n1. finite\n2. yields the same accurate S-matrix as renormalized QED.\n(so it has the same predictions as far as experiment is concerned)\n\nThe details are given in\n\nE.V.Stefanovich "Quantum field theory without infinities", Ann. Phys.\n292 (2001), 139\n\nand in online book available at www.meopemuk.com\n\nI would appreciate any comments and criticism of this approach to QED.\nIf you don\'t think it completely solves the problem of ultraviolet\ninfinities, I would like to know why.\n\nMore papers can be found at www.geocities.com/meopemuk\n\nRegards.\nEugene.\n\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Chris Oakley wrote:
> cutoff procedure. Supposing, for example, we were to choose [itex]\Lambda[/itex] as a
> least [itex]- I am[/itex] still working on that.
Hi Chris,
1. finite
292 (2001), 139
If you don't think it completely solves the problem of ultraviolet
Regards.
Eugene.
Oct21-04, 02:47 AM   #39
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n&gt; &gt; In all the references I have the arguments rely on the interaction being\na\n&gt; &gt; local product of fields. I do not know what one can do to make the\ntheory\n&gt; &gt; work when this is not the case.\n&gt;\n&gt; One simply gets more complicated Feynman rules. It is not very difficult\n&gt; to generalize them to arbitrary nonlocal interactions. In momentum space,\n&gt; the formulas become the standard formulas, but with explicit cutoff\n&gt; included.\n\nI have never, *ever* seen this. Can you give me a reference? I have only\nseen Feynman rules for *local* field equations being used and then the\nintegrals being cut off *after* we get the expressions for the loops and\nhave not liked what we saw.\n\n&gt; Thus to do the suggested exercise, you should always work in the momentum\n&gt; representation, and just apply the arguments of the textbooks in a\nsensible\n&gt; way to the regularized situation.\n\nI am familiar with the momentum representation (which I use more or less\nexclusively in my own work), but cannot see how to adapt the arguments of\nFeynman-Dyson perturbation theory using this to achieve the required result.\nPlease enlighten me.\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>In all the references I have the arguments rely on the interaction being
a
theory
> included.
sensible
Oct21-04, 02:47 AM   #40
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n&gt; Smearing an interaction in time just amounts to using a different\n&gt; time-dependent potential, constructed at time t from the original\n&gt; time-dependent potential (in the interaction representation) at all other\ntimes.\n&gt; This is best seen by using the representation of the S-matrix\n&gt; as time-ordered exponential. This holds for arbitrary time-dependent\n&gt; nonlocal potentials, and one can go back from any nonlocal 4D interaction\n&gt; to a time-dependent potential formulation. Thus smearing in time is not a\n&gt; real problem: One starts with the smeared interaction defined by the\n&gt; cutoff, uses the time-ordered exponential to work out the corresponding\n&gt; Hamiltonian interaction, and proceeds from there.\n\nThis may be obvious to you, but it is not obvious to me, I am afraid, so\nplease spell it out.\n\n&gt; &gt; In all the references I have the arguments rely on the interaction being\na\n&gt; &gt; local product of fields.\n&gt;\n&gt; This is not even the case in nonrelativistic field theories:\n&gt; Coulomb interactions are not describable by local products of fields.\n\nI think we are talking cross purposes here. E.g. Weinberg, QFT Vol. 1,\nchapter 6. The arguments assume that (e.g.) H(x_1), etc. in equation 6.1.1\nis a local product of fields defined at the particular spacetime point. He\nis already considering this interaction Hamiltonian density H in the\nInteraction Picture. My point is that one can only transform a product of\nfields to the I.P. in the naive way if they are all for the same time, so\none cannot get to this equation if H is a smearing that is non-local in\ntime.\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Smearing an interaction in time just amounts to using a different
times.
a
chapter 6. The arguments assume that (e.g.[itex]) H(x_1),[/itex] etc. in equation 6.1.1
time.
Oct22-04, 12:01 PM   #41
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\nEugene Stefanovich wrote:\n&gt; Chris Oakley wrote:\n&gt;\n&gt;&gt;Let\'s just remember how we got to where we are:\n&gt;&gt;\n&gt;&gt;(i) We solved free field theory, including the expansion in terms of\n&gt;&gt;annihilation and creation operators.\n&gt;&gt;(ii) We introduced an interaction term in the Lagrangian density.\n&gt;&gt;(iii) We introduced a unitary transformation that turns free fields into\n&gt;&gt;interacting fields using the Interaction Picture.\n&gt;&gt;(iv) We wrote out the Interaction Picture time evolution operator as\n&gt;&gt;time-ordered products of the interaction.\n&gt;&gt;(v) We reduced the time-ordered products to normal-ordered products.\n&gt;&gt;(vi) We obtained thereby the S-matrix for scattering processes involving a\n&gt;&gt;finite number of incoming particles with definite four-momentum scattering\n&gt;&gt;to a finite number of outgoing particles with definite four-momenta as a sum\n&gt;&gt;of Feynman diagrams.\n&gt;&gt;\n&gt;&gt;Many of these Feynman diagrams are pathologically divergent integrals.\n&gt;&gt;\n&gt;&gt;My response: This is because the theory is fundamentally flawed. Go back to\n&gt;&gt;(ii) and try again.\n&gt;&gt;\n&gt;\n&gt;\n&gt; I would like to suggest a different path (similar to what Weinberg is\n&gt; writing in his book):\n&gt;\n&gt; (i) We constructed the Fock space as direct sums of tensor products of\n&gt; 1-particle spaces\n&gt; (ii) We defined a non-interacting representation of the Poincare group\n&gt; there, including non-interacting Hamiltonian H_0 and\n&gt; boost operator K_0\n&gt; (iii) We defined interaction terms in the Hamiltonian and boost\n&gt; operator H= H_0+V, K = K_0+W (all operators are expressed through\n&gt; particle creation and annihilation operators, no fields)\n&gt; (iv) We found that S-matrix is ultraviolet divergent\n&gt; (v) We added renormalization (infinite) counterterms to the\n&gt; Hamiltonian H\' = H+R , so as to\n&gt; make S-matrix finite and in agreement with experiment.\n&gt;\n&gt; This is where QED stands now: finite and perfectly accurate S-matrix\n&gt; obtained from infinite (wrong) Hamiltonian H\'. My suggestion is\n&gt;\n&gt; (vi) Apply unitary dressing transformation U to the Hamiltonian H\',\n&gt; so that\n&gt;\n&gt; 1) the new Hamiltonian\n&gt;\n&gt; H\'\' = U H\' U^{-1}\n&gt;\n&gt; is finite\n&gt;\n&gt; 2) The S-matrices obtained with H\' and H\'\' are exactly the same.\n&gt;\n&gt; Now you can forget the nightmares of QFT, canonical quantization,\n&gt; Haags theorem, etc. You can use H\'\' in all usual quantum mechanical\n&gt; formulas (obtain time evolution operator, S-matrix, bound states via\n&gt; diagonalization, etc) without any need of regularization,\n&gt; renormalization, and other tricks.\n\nWell, this is a research program - the question is whether you can\nactually carry it out. How do you construct U? It is there that all\nthe renormalization issues will recur. Since H\' is an ill-defined object\none must regularize it, then construct U for the regularized theory,\nand then go to the limit and show that it really exists. This poses\nthe same problems as the original renormalization program.\n\n\nArnold Neumaier\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Eugene Stefanovich wrote:
>>(ii) and try again.
> 1-particle spaces
> so that
> is finite
the renormalization issues will recur. Since H' is an ill-defined object
Arnold Neumaier
Oct22-04, 12:01 PM   #42
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n&gt; I share your frustration with renormalized QFT. I think I know the way\n&gt; to fix the problem of infinities. The idea is very simple: QED simply\n&gt; uses a wrong Hamiltonian. There is a rigorous way how to find a new\n&gt; Hamiltonian of QED (while preserving the relativistic invariance and\n&gt; cluster separability) which is\n&gt;\n&gt; 1. finite\n&gt; 2. yields the same accurate S-matrix as renormalized QED.\n&gt; (so it has the same predictions as far as experiment is concerned)\n&gt;\n&gt; The details are given in\n&gt;\n&gt; E.V.Stefanovich "Quantum field theory without infinities", Ann. Phys.\n&gt; 292 (2001), 139\n&gt;\n&gt; and in online book available at www.meopemuk.com\n&gt;\n&gt; I would appreciate any comments and criticism of this approach to QED.\n&gt; If you don\'t think it completely solves the problem of ultraviolet\n&gt; infinities, I would like to know why.\n&gt;\n&gt; More papers can be found at www.geocities.com/meopemuk\n\nEugene,\n\nAs you may remember we met and talked in California three years ago. It is\nnice (and rare) to see someone who has bothered to figure everything out for\nthemselves.\n\nI don\'t claim to understand every detail of your work, but I do take Haag\'s\ntheorem seriously and therefore don\'t believe that the U, W and F operators\nin section 2 of your 2001 Ann. Phys. paper exist. Not in a fully\nrelativistic theory, anyway. Also I notice that the regularization scheme is\nstill exactly that ... i.e. you get the infinities and then devise a scheme\n(in your case a "clothing" operator) for dealing with them. This is still\nsubtracting infinity from infinity, and I really don\'t think that people\nought to do that.\n\nChris\n\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>I share your frustration with renormalized QFT. I think I know the way
> 1. finite
> 292 (2001), 139
Eugene,
themselves.
I don't claim to understand every detail of your work, but I do take Haag's
theorem seriously and therefore don't believe that the U, W and F operators
subtracting infinity from infinity, and I really don't think that people
ought to do that.
Chris
Oct22-04, 12:01 PM   #43
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\nChris Oakley wrote:\n&gt;&gt;Haag\'s theorem does not apply since the theory with cutoff is not\n&gt;&gt;Lorentz invariant.\n&gt;\n&gt;\n&gt; One cannot be so glib. In the only case of physical interest (Lambda =\n&gt; infinity) the theory *must be* Lorentz invariant.\n\nWe only know that the universe is governed by Lorentz invariance to\na certain accuracy, which means that the theories with finite but large\ncutoff (significantly larger that the largest energy we can create or\nmeasure) already are in full agreement with nature.\n\nThus Lambda=inf is not needed for results of physical interest.\n\n\nArnold Neumaier\n\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Chris Oakley wrote:
>>Lorentz invariant.
Thus [itex]\Lambda=inf[/itex] is not needed for results of physical interest.
Arnold Neumaier
Oct22-04, 12:20 PM   #44
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\nChris Oakley wrote:\n\n&gt; I think we are talking cross purposes here. E.g. Weinberg, QFT Vol. 1,\n&gt; chapter 6. The arguments assume that (e.g.) H(x_1), etc. in equation 6.1.1\n&gt; is a local product of fields defined at the particular spacetime point. He\n&gt; is already considering this interaction Hamiltonian density H in the\n&gt; Interaction Picture. My point is that one can only transform a product of\n&gt; fields to the I.P. in the naive way if they are all for the same time, so\n&gt; one cannot get to this equation if H is a smearing that is non-local in\n&gt; time.\n\nRewrite in each of Weinberg\'s formulas the fields in x as integral\nover fields in p. This gives you completely equivalent formulations,\nnow only involving momenta. Once you have done that, it is very easy\nto take care of a cutoff.\n\n\nArnold Neumaier\n\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Chris Oakley wrote:
> time.
Rewrite in each of Weinberg's formulas the fields in x as integral
Arnold Neumaier
Oct22-04, 12:20 PM   #45
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\nChris Oakley wrote:\n&gt;&gt;&gt;In all the references I have the arguments rely on the interaction being a\n&gt;&gt;&gt;local product of fields. I do not know what one can do to make the theory\n&gt;&gt;&gt;work when this is not the case.\n&gt;&gt;\n&gt;&gt;One simply gets more complicated Feynman rules. It is not very difficult\n&gt;&gt;to generalize them to arbitrary nonlocal interactions. In momentum space,\n&gt;&gt;the formulas become the standard formulas, but with explicit cutoff\n&gt;&gt;included.\n&gt;\n&gt; I have never, *ever* seen this. Can you give me a reference?\n\nNo; I don\'t know of any. I had to work it out for myself; it was a hard\nroad to gain this understanding.\n\nI gave you instead an exercise. Physicists are too lazy to do things as\ncarefully as you wish, so you have to do it yourself. I gave you the\noutline, so that you can fill in the details.\n\n\n&gt; I am familiar with the momentum representation (which I use more or less\n&gt; exclusively in my own work), but cannot see how to adapt the arguments of\n&gt; Feynman-Dyson perturbation theory using this to achieve the required result.\n&gt; Please enlighten me.\n\nPlease start doing it and you\'ll see that everything can be done.\nBegin by writing the interaction in the momentum representation as a\nmultiple integral, add the cutoff, and then start copying in spirit\neach line of Peskin & Schroeder or your favorite textbook, adapting it\nto the new situation at hand. You can hardly go wrong, but of course\nit takes some effort to get familiar with the nonlocal case.\n\nIt is very hard writing out pages of details in ascii, and I have no\nintention to do so. Should you ever want to visit Vienna, I\'d show you\non the blackboard what to do.\n\n\nArnold Neumaier\n\n\n\n\n\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Chris Oakley wrote:
>>included.
No; I don't know of any. I had to work it out for myself; it was a hard
Please start doing it and you'll see that everything can be done.
intention to do so. Should you ever want to visit Vienna, I'd show you
Arnold Neumaier
Oct22-04, 12:31 PM   #46
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\nEugene Stefanovich wrote:\n&gt; Arnold Neumaier wrote:\n\n&gt;&gt;But in order that the results have a finite limit we must at the\n&gt;&gt;same time make the coupling constants g dependent on Lambda.\n&gt;&gt;If this is done in a correct way (and the textbooks on QFT teach\n&gt;&gt;one or more of the known correct ways), one encounters no infinities\n&gt;&gt;at all in the whole process.\n&gt;&gt;\n&gt; Your setting Lambda to infinity is fine. That\'s what Feynman et al. did,\n&gt; and how they obtained a finite and accurate S-matrix.\n\nThey don\'t set it to infinity; they keep it finite and take the limit at\nthe end.\n\n&gt; The problem with\n&gt; this approach is that masses and coupling constants are infinite.\n\nThe bare masses and bare coupling constants are finite but depend on\nLambda. In the limit they would diverge. But one never needs to take\nlimits on bare objects. The renormalized masses and coupling constants\nare finite.\n\n&gt; However, I presume that every physicist believes that there is\n&gt; some non-trivial time evolution of interacting physical systems\n&gt; between the two time extremes. Such time evolution is evident\n&gt; in macroscopic low-energy systems, for example.\n&gt; QFT ignores that. That\'s the main\n&gt; problem, why renormalization approach of Feynman, Tomonaga, and\n&gt; Schwinger is not the final word in QFT.\n\nOne, not necessarily the main one. The fact that the S-matrix exists\nonly as a formal series instead of as a unitary operator on some\nHilbert space is another important reason.\n\n\nArnold\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Eugene Stefanovich wrote:
They don't set it to infinity; they keep it finite and take the limit at
the end.
> The problem with
[itex]\Lambda[/itex]. In the limit they would diverge. But one never needs to take
are finite.
Arnold
Oct22-04, 12:40 PM   #47
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\nOn Thu, 21 Oct 2004 07:47:32 +0000, Chris Oakley wrote:\n\n&gt;\n&gt;&gt; &gt; In all the references I have the arguments rely on the interaction\n&gt;&gt; &gt; being\n&gt; a\n&gt;&gt; &gt; local product of fields. I do not know what one can do to make the\n&gt; theory\n&gt;&gt; &gt; work when this is not the case.\n&gt;&gt;\n&gt;&gt; One simply gets more complicated Feynman rules. It is not very difficult\n&gt;&gt; to generalize them to arbitrary nonlocal interactions. In momentum\n&gt;&gt; space, the formulas become the standard formulas, but with explicit\n&gt;&gt; cutoff included.\n&gt;\n&gt; I have never, *ever* seen this. Can you give me a reference? I have only\n&gt; seen Feynman rules for *local* field equations being used and then the\n&gt; integrals being cut off *after* we get the expressions for the loops and\n&gt; have not liked what we saw.\n\nOne does not have to go far to see this. As Arnold mentioned in a previous\npost, the coulomb interaction in non-relativistic many body systems is a\nstandard example. When drawing diagrams in momentum space instead of a\npoint interaction vertex we an internal line which represents the\ninteraction. However, the internal line does not represent a photon\nas we would expect in full QED, but simply the Coulomb potential. The\nelectron vertices are allowed to have distinct positions and the Coulomb\npotential depends on their difference. Since the Coulomb interaction is\ntranslation invariant, there is still a nice picture of the interaction in\nmomentum space: the internal interaction line represents a momentum\ntransfer. All the necessary Feynman rules are worked out for both position\nand momentum space in _Methods of QFT in Statistical Physics_ by Abrikosov\net al. Even the cases when the interaction is not translation invariant\nare treated.\n\nIgor.\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>On Thu, 21 Oct 2004 07:47:32 [itex]+0000,[/itex] Chris Oakley wrote:
>> > being
> a
> theory
>> cutoff included.
are treated.
Igor.
Oct22-04, 12:40 PM   #48
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\n&gt; However, I presume that every physicist believes that there is\n&gt; some non-trivial time evolution of interacting physical systems\n&gt; between the two time extremes. Such time evolution is evident\n&gt; in macroscopic low-energy systems, for example.\n&gt; QFT ignores that. That\'s the main\n&gt; problem, why renormalization approach of Feynman, Tomonaga, and\n&gt; Schwinger is not the final word in QFT.\n\nIt is interesting that undergraduate quantum mechanics does better than QFT\nfor processes that involve a (finite) time variable. QFT ought to be an\nextension of this, not an alternative.\n\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>However, I presume that every physicist believes that there is
Oct24-04, 09:04 AM   #49
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n&gt; &gt;&gt;&gt;In all the references I have the arguments rely on the interaction\nbeing a\n&gt; &gt;&gt;&gt;local product of fields. I do not know what one can do to make the\ntheory\n&gt; &gt;&gt;&gt;work when this is not the case.\n&gt; &gt;&gt;\n&gt; &gt;&gt;One simply gets more complicated Feynman rules. It is not very difficult\n&gt; &gt;&gt;to generalize them to arbitrary nonlocal interactions. In momentum\nspace,\n&gt; &gt;&gt;the formulas become the standard formulas, but with explicit cutoff\n&gt; &gt;&gt;included.\n&gt; &gt;\n&gt; &gt; I have never, *ever* seen this. Can you give me a reference?\n&gt;\n&gt; No; I don\'t know of any. I had to work it out for myself; it was a hard\n&gt; road to gain this understanding.\n&gt;\n&gt; I gave you instead an exercise. Physicists are too lazy to do things as\n&gt; carefully as you wish, so you have to do it yourself. I gave you the\n&gt; outline, so that you can fill in the details.\n\nI have not done it because I do not believe that it can be done. Products of\nfield operators in the interaction Hamiltonian density must refer to the\nsame time if we are to be able to transform to the Interaction Picture.\n\nI might just add that I am not the first person to be bothered by the sloppy\nmathematics in QFT. People have been working on this, on and off, since\n1928. If there was a way of making the procedure rigorous, it would have\nfound its way into the text books by now. However the best QFT text book *I*\nknow of - Weinberg - makes no mention of the possibility of defeating\ninfinite subtractions via non-local field equations. Neither does the\nsupposedly more rigorous Scharf.\n\n&gt; Should you ever want to visit Vienna, I\'d show you\n&gt; on the blackboard what to do.\n\nA kind offer, but be careful - I might take you up on it.\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>>>>In all the references I have the arguments rely on the interaction
being a
theory
space,
> >>included.
Oct24-04, 09:04 AM   #50
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n&gt; &gt; I think we are talking cross purposes here. E.g. Weinberg, QFT Vol. 1,\n&gt; &gt; chapter 6. The arguments assume that (e.g.) H(x_1), etc. in equation\n6.1.1\n&gt; &gt; is a local product of fields defined at the particular spacetime point.\nHe\n&gt; &gt; is already considering this interaction Hamiltonian density H in the\n&gt; &gt; Interaction Picture. My point is that one can only transform a product\nof\n&gt; &gt; fields to the I.P. in the naive way if they are all for the same time,\nso\n&gt; &gt; one cannot get to this equation if H is a smearing that is non-local in\n&gt; &gt; time.\n&gt;\n&gt; Rewrite in each of Weinberg\'s formulas the fields in x as integral\n&gt; over fields in p. This gives you completely equivalent formulations,\n&gt; now only involving momenta. Once you have done that, it is very easy\n&gt; to take care of a cutoff.\n\nYou are missing my point. Limiting the integral in p^0 space results in a\nsmearing in the time integral. This is just basic Fourier analysis. It is\nthe latter which prevents a transformation between the Heisenberg and\nInteraction pictures for the field operators.\n\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>I think we are talking cross purposes here. E.g. Weinberg, QFT Vol. 1,
6.1.1
He
of
so
> > time.
You are missing my point. Limiting the integral in [itex]p^0[/itex] space results in a
Oct24-04, 09:04 AM   #51
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\n\n\n\n\nChris Oakley wrote:\n&gt;&gt;However, I presume that every physicist believes that there is\n&gt;&gt;some non-trivial time evolution of interacting physical systems\n&gt;&gt;between the two time extremes. Such time evolution is evident\n&gt;&gt;in macroscopic low-energy systems, for example.\n&gt;&gt;QFT ignores that. That\'s the main\n&gt;&gt;problem, why renormalization approach of Feynman, Tomonaga, and\n&gt;&gt;Schwinger is not the final word in QFT.\n&gt;\n&gt;\n&gt; It is interesting that undergraduate quantum mechanics does better than QFT\n&gt; for processes that involve a (finite) time variable. QFT ought to be an\n&gt; extension of this, not an alternative.\n&gt;\n\n\nThat\'s exactly right, and my approach (with finite well-defined Hamiltonian)\nmakes time evolution in QFT\nnot more difficult that in non-relativistic undergraduate QM. The only\ndifference is that 1) relativity is respected; 2) creation and\nannihilation of particles is allowed.\n\nEugene\nwww.geocities.com/meopemuk\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Chris Oakley wrote:
That's exactly right, and my approach (with finite well-defined Hamiltonian)
Eugene
Thread Closed
Thread Tools
Similar Threads for: Connes & Marcolli paper on renormalization
Thread Forum Replies
algebra of Kreimer-Connes renormalization General Physics 1
algebra of Kreimer-Connes renormalization General Physics 0
new Alain Connes paper Beyond the Standard Model 5
connes fusion General Math 3
