Is there a simpler method to prove absolute inequalities?
  • Context: High School
  • Thread starter Thread starter imranmeghji
    Absolute Inequalities
The discussion focuses on proving the absolute inequality |x+y+z| ≤ |x| + |y| + |z| for real numbers. A participant suggests starting with the simpler case of |x+y| ≤ |x| + |y|, which holds true when both terms share the same sign or are opposites. The three-term case can be established by applying the two-term proof iteratively. This method emphasizes a systematic approach to handling absolute values in inequalities.
  • Understanding of absolute value properties
  • Familiarity with real number inequalities
  • Basic knowledge of mathematical proofs
  • Experience with case analysis in mathematics
  • Study the properties of absolute values in inequalities
  • Learn about mathematical induction for proving inequalities
  • Explore case analysis techniques in mathematical proofs
  • Investigate other inequalities involving absolute values, such as the triangle inequality
Mathematicians, students studying real analysis, and anyone interested in understanding and proving inequalities involving absolute values.
imranmeghji
prove the folowing and state when the inequality holds...
|x+y+z|<=|x|+|y|+|z|
i was thinking that i consider all the possible cases, ie x is positive, y positive, z positive; then the various combinations with negative as well...
is there another shorter method of doing it?
help...
You can start with 2 terms first. |x+y|<=|x|+|y|. (I am assuming you are talking about real numbers). Equal if the same sign, less if opposite. Then the 3 term case can be proven in two steps using the 2 term case.
  • · Replies 22 ·
