Why don't we emit radio waves
  • Context: High School
  • Thread starter Thread starter LogicalAcid
    Radio Radio waves Waves
The discussion revolves around the emission of radio waves by humans and biological systems, exploring the relationship between temperature, infrared radiation, and radio wave emission. Participants examine the mechanisms of radiation emission, the differences between thermal and coherent emissions, and the implications for visibility and detection using various technologies.
  • Some participants assert that humans emit radio waves, but at a much fainter level compared to infrared radiation.
  • There is a hypothesis that humans primarily emit infrared radiation, which is why they are not visible in complete darkness without external light sources.
  • One participant questions why humans cannot be used as antennas despite emitting radio waves, suggesting a comparison between biological emissions and antenna functionality.
  • Another participant argues that there is no requirement for biological systems emitting infrared to also emit lower frequencies, challenging the assumption that all wavelengths must be emitted.
  • Some contributions clarify that the visible light we perceive is due to reflection rather than direct emission from human bodies, with visible light being where the sun's emission peaks.
  • There is a distinction made between thermal emissions from the body and coherent emissions from antennas, with emphasis on the weak nature of thermal emissions compared to the direct emissions from radio transmitters.
  • Participants discuss the implications of Kirchhoff's law in relation to human emissions and transparency at different wavelengths.
Participants express a variety of views on the nature and extent of radio wave emission by humans, with no clear consensus reached. Some agree on the basic principles of thermal radiation, while others contest the implications of those principles regarding antenna functionality and the necessity of emitting all wavelengths.
Participants highlight limitations in understanding the relationship between temperature and emission spectra, as well as the differences between coherent and incoherent emissions. There are unresolved questions regarding the specific mechanisms of radio wave emission in biological systems.
LogicalAcid
If our temperature is already above the necessary temperature to emit radio waves? At our temperature we emit mainly infrared right?
Science news on Phys.org
We do emit radio. It's just much, much fainter than the infrared we emit. Similarly, the sun emits much more infrared per square meter than we do, even though it peaks in the visible.
At our temperature, we mainly emit infrared radiation correct?
Then why do we see each other in visible light? Here's my hypothesis:
Left to ourselves, meaning no light present (at night) we are not seen because we don't have enough energy in us to emit visible light, we emit infrared at the most. That is why even if there is no light, we can still see if we have infrared goggles.
Then we are basically antennas? Why can't we be used as antennas then?
Lemme rephrase that, why do antennas have the ability to send out radio waves, if we emit radio waves as well?
To suggest that biological systems, emitting IR, must ALSO emit lower frequencies is false.
There is no natural requirement for a biological system emitting a specific wavelength to be required to emit all the other sub-wavelengths down to zero.
Took it right outta my mouth, why is this?
That's reasonably accurate.
The reason we see each other in visible light is because we see the light reflected off of each other, not because we see the light emitted. The reason this is in the visible range is because that's where the sun's emission peaks.
How do you know we don't?
Humans can be clearly imaged using the 8-12 um (LWIR) band, which corresponds closely to the peak in thermal emission.
I know that humans are opaque to millimeter waves (new airport full body scanners), and o we emit in the millimeter wave as well. But at some point we become transparent, and so by Kirchoff's law we won't emit in that waveband.
Great, I have some questions I would like to ask you instead of starting a new thread, would you mind?
Kirchoff's law BRB
As opposed to phonon's(sound waves), photons do not have interactive, potentially harmonic properties.
LogicalAcid said:
Kirchoff's law BRB
I don't understand?
Andy Resnick said:
I don't understand?
I went to research it.
We emit infrared because we aren't at absolute zero, not due to any unusual property of biological systems. The radiation our bodies emit more or less follows a black body spectrum, and we do indeed emit at lower frequencies, all the way down to zero. Your statements suggest the IR emissions are special, when it is really the gaps and other variations due to our deviations from black body emitters that are special. Your statement applies to bioluminescence, but not to body heat.
The question doesn't make sense. Why would the fact that we emit radio waves make you think antennas can't?
But anyway, note that there's two types of emission here. You and an antenna both emit thermal radiation in a range of frequencies including the radio band but peaking in the infrared spectrum. Heat an unpowered antenna up to body temperature in the sun, and its emission spectrum will be quite similar. These emissions are very weak, though. An object at human body temperature won't be emitting particularly large amounts of power, and most of that will be in the infrared range.
Radio transmitters do not produce radio waves by thermal emission. They do it far more directly, by literally pushing the electrons in the antenna back and forth at the frequency desired. Accelerating charges radiate, and by doing this you can emit very large amounts of power in a very narrow portion of the spectrum.
Because it could trigger painful sparks every now and then so no, thank you.
We should be emitting radio waves too , or at least i think so. It's just we emit much more infrared and infrared has a lot more energy than radio waves, infrared dominates.
To be totally fair, most night-vision goggles are based around photomultipliers. They also have some IR sensitivity, but that is mainly so that they can use an IR light source to "illuminate" an area without being seen. But that's an engineering point. You are more or less correct about the underlying emission phenomenon.
You are conflating two concepts here:
An antenna is something that transmits and receives COHERENT radio transmissions. This is done by applying electromotive force of the appropriate phase and frequency, blah blah blah.
Thermionic emission is what the human body does, with respect to radio waves. Just the heat of the body causes some ultra-long-wave IR (AKA RF) waves to come off. They are not, in any way, coherent. Similarly, the body is not a coherent absorber. The energy we absorb from RF waves is just dissipated as heat, not conducted down our length to a detector. A lot of the art of antenna design is optimizing it for sensitivity to what we are interested in.
(Moderator note -- 2 similar threads merged)
  • · Replies 33 ·
  • · Replies 17 ·
9K
  • · Replies 17 ·
  • · Replies 30 ·
