Master Motion Problems: Time, Velocity, and Trajectory | Expert Help ASAP!
  • Thread starter Thread starter debbie18
    Motion
The discussion revolves around motion problems involving projectile motion, specifically focusing on a ball thrown horizontally from a height and a projectile fired vertically. Participants are exploring the concepts of time of flight, initial velocity, and velocity components at different points in the projectile's trajectory.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants are attempting to identify relevant formulas and concepts related to projectile motion. Questions about the given information and how to separate components of motion are raised, particularly regarding the first question about the ball thrown from the building.
Some participants are providing hints and guidance on how to approach the problems, suggesting the separation of vertical and horizontal components of motion. There is an ongoing exploration of the necessary principles without a clear consensus on the steps to take.
Participants express uncertainty about the information provided in the problems, particularly in the first question where only distance is given. There is a mention of needing to consider angles in the second question, indicating potential assumptions about the projectile's launch angle.
debbie18
Please help asap!- Motion problems
I am stuck on these questions, please can some one help asap!
1. A ball is thrown horizontally from the top of a building 32.5 m high. The ball strikes the ground at a point 96.9 m from the base of the building. The acceleration of gravity is 9.8 m/s^2. Find the time the ball is in motion. Find the initial velocity of the ball. Find the x and y components of its velocity just before it strikes the ground.
2. A projectile is fired straight upward at 135 m/s. How fast is it moving at the instant it reaches the top of its trajectory? How fast is it moving at the instant it reaches the top of its trajectory if the particle is fired upward at 33 degrees from the horizontal?
what have you done?
I have no idea what to do in the 1st question because nothing is given except the distance. Can u just tell me what formulas to use? Just a little hint would be helpful.
Srry couldn't help you yesturday I had to leave, :mad: . But just separate it into vertical and horizontal components I think youll be able to do it.
1) At the top of the building, what's the only component of velocity?
2) For the first part, it seems like a 90 degrees angle with the horizontal, so consider what you learned in 1D motion, Use what you know of projectile motion.
  • · Replies 38 ·
  • · Replies 36 ·
