Electric Potential at a Distance
The discussion revolves around calculating the electric potential difference at a specified distance from an alpha particle, focusing on the relevant equations and concepts in electrostatics.
  • Participants explore the formula for electric potential, questioning the necessary charge and its relevance to the problem. There are attempts to substitute values into the equation, alongside discussions about potential energy and its relationship to electric potential.
Participants are actively engaging with the problem, sharing calculations and clarifying concepts. There is a mix of agreement and confusion regarding the definitions and signs associated with potential energy and electric potential, indicating a productive exploration of the topic.
Some participants express uncertainty about the charge of the alpha particle and its implications for the calculation, as well as the assumptions regarding potential energy at infinity.
xxabr
Find the electric potential difference at a point 4.0x10-2m away from an alpha particle.
V= kq/r
k= 9x109
r= 4.0x10-2
I'm not quite sure how to get this answer considering I don't have any charge and there's nothing that says to use the charge from the previous question...
Help, please?
hi xxabr! :smile:
an alpha particle consists of two protons and two neutrons, so it has a positive charge whose magnitude is twice the charge on an electron …
see http://en.wikipedia.org/wiki/Alpha_particle" for more details :wink:
Oh! Okay, thanks (:
So...
V= kq/r
= (9x109)(3.2x10-19)/ (4x10-2)
= 7.2x-8V ?
xxabr said:
V= kq/r
= 7.2x-8V ?
yup, looks ok! (assuming that the zero of potential energy is at infinity) :smile:
(or is it minus that … i get confused … isn't PE minus kq/r ? :confused:)
Uh... No, I don't think so.
At least my textbook doesn't say that.. :confused:
hi xxabr! :smile:
(just got up :zzz: …)
hmm … let's work this out from scratch …
https://www.physicsforums.com/library.php?do=view_item&itemid=269"
work done is the work bringing a positive test charge from infinity (because that's zero PE) to distance r from a positive charge q …
force is outward (both charges positive), movement is inward, so work done is negative, so PE is positive
yes, you're right! :smile:
  • · Replies 22 ·
