| New Reply |
conversion question: normal litres per min to velocity |
Share Thread | Thread Tools |
| Nov23-10, 03:38 AM | #1 |
So, Im going to be doing a simulation of a combustor, with premixed air + fuel, and for input I'll need to put in the velocity. I've been given the flow rate in units of Normal litres/min (air = 2000Nl/min, fuel = 25Nl/min), as well as the normal density (normal density air = 1.293kg/Nm³ and fuel = 0.7 kg/Nm³). The case Im simulating should be at approx 600K and 2 bar. 2. Relevant equations mass flow = density*velocity*area, density = mass/volume 3. The attempt at a solution The main problem Im having here isnt so much the actual conversion, as what to do with the units. From the definition of normal litre: "A unit of mass for gases equal to the mass of 1 litre (0.035 3147 ft3) at a pressure of 1 atmosphere and at a standard temperature, 0 C (273.15K)." Do I need to calculate what the volume & mass flows will be at the simulation temperature & pressure, and then calculate the velocity? Or can I just use the values of the normal density and normal volume flow to calculate the inlet velocity, then use this as the input for the simulation? |
| New Reply |
| Thread Tools | |
Similar Threads for: conversion question: normal litres per min to velocity
| unit conversion litres to gallons or vice versa | Introductory Physics Homework | 2 | ||
| angular velocity --velocity conversion | Introductory Physics Homework | 1 | ||
| Grammes/second to litres/second | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Is it possible to convert kg/(kWh) to litres/100m ? | General Physics | 3 | ||
| Litres to moles? | Introductory Physics Homework | 17 | ||
