New Reply
Which force is called weight?
Share Thread Thread Tools
Jan7-11, 04:23 AM   #18
Saw
Recognitions:
Gold Membership Gold Member
Quote by jtbell View Post
...which form two distinct action-reaction (Third Law) pairs.
Ok, I see. I paraphrase for your confirmation.
When an object is standing on the Earth, there are two interactions: one attractive (gravitational) and another repulsive (electromagnetic = normal).
Each one has its own pair of 3rd Law forces. The 3rd Law pairs (acting on different objects) do not counteract each other.
Hence it is the mixture between two forces of different kind and opposite sign (which are not 3rd Law pairs and do act on the same object) what causes the equilibrium, isn’t it?
For example:
Gravitational Force by the Earth on the object (pushing the object downwards) is cancelled by Normal Force also by the Earth on the object (pushing the object upwards).
Gravitational Force by the object on Earth (pushing the Earth upwards) is cancelled by Normal Force also by the object on the Earth (pushing the Earth downwards).
The fact that the forces that cancel against each other have equal magnitudes is not due to one being a reaction against the other, as noted, but to… the fact that we have assumed that they do cancel against each other. In fact, when a ball bounces off the floor after being dropped from some height, they do not cancel: in that case, normal force prevails at collision time and hence the bouncing.
Some language problems:
Usually the gravitational force is referred to as weight. But in common language one tends to think that weight is that sensation that arises when weight combines with an opposite force that makes it “apparent”. So people think that whenever that sensation is absent, like in free fall, the body is weightless, which is not technically true: it is only “supportless”. Hence people should stop saying that or… physics could change its nomenclature and reserve the word “weight” for “apparent weight”. As the latter is too ambitious at this stage, your suggestion is at least try to avoid the word “weight”, to avoid discussions... Good.
Usually Newton’s third Law is explained saying that for every action, there is a “reaction”: a force by A on B triggers a “reaction force” by B on A of the same nature, same magnitude, same direction and opposite sense. But in common language we use the expression “reaction” also to refer to situations where a force by A on B triggers and opposite force also by A on B. This is our case, where gravitational force on the object exerted by the Earth triggers, when the object touches the ground, a reaction through another force, normal force, exerted also by the Earth itself on the same object. Who should rectify here? To me, physics should not use the word “reaction” in the context of 3rd Law. The two sides of a 3rd Law are really the two sides of the same thing. It is an interaction, a single phenomenon, having effects on both sides… What would you advise?
Jan7-11, 04:25 AM   #19
Mentor
Quote by Gallin View Post
So when is the normal force different than the gravitational one?
Whenever you are accelerating. For example, jump off of a bench and the normal force goes to zero yet the gravitational force hasn't changed. Or simply stand in an elevator while it accelerates upward--the normal force is now greater than the gravitational force.
Jan7-11, 04:32 AM   #20
Mentor
Quote by Saw View Post
Exactly. 3rd law pairs can never produce equilibrium on their own, since they act on different bodies.
The 'action/reaction' terminology is old-fashioned and misleading, for exactly the reasons you point out. Avoid it! Much better to refer to them as 3rd law pairs.
Jan7-11, 04:35 PM   #21
Saw
Recognitions:
Quote by Doc Al View Post
Thanks a lot. I corrected my notes accordingly and now everything fits better in my head.
Jan11-11, 08:47 AM   #22
Freely falling body is not weightless. It just doesnt feel any weight because one feels weight cause of the normal force acting on it
Jan11-11, 11:11 AM   #23
D H
Mentor
Quote by ashishsinghal View Post
That depends on what you mean by "weight". "Weight" is one of those semi-scientific terms that has multiple meanings. With one of those meanings, also called scale weight or apparent weight, a freely-falling body is weightless.
New Reply
Thread Tools
Similar Threads for: Which force is called weight?
Thread Forum Replies
Weight, Gravitational Force Introductory Physics Homework 2
Gravitational Force and Weight Introductory Physics Homework 1
Normal Force and Weight Introductory Physics Homework 1
which is larger? the weight or the force? Introductory Physics Homework 6
Force and weight General Physics 7
