Error Propagation: Solutions to Complex Equations
Error propagation in equations with uncertainties can be effectively managed by applying specific mathematical rules. When only one term has uncertainty, the uncertainty can be propagated by multiplying the uncertainty value by the constants involved in the equation. For equations like y = ax + b, where a and b are constants and x has an uncertainty, the maximum and minimum values can be calculated to determine the overall uncertainty. When multiple terms have uncertainties, the exact error is found by calculating the maximum and minimum values, while a rule of thumb states that errors add when measurements are added or subtracted, and percentage errors add when measurements are multiplied or divided.
  • Understanding of basic algebraic equations
  • Familiarity with error analysis concepts
  • Knowledge of propagation of uncertainty in measurements
  • Ability to perform calculations involving maximum and minimum values
  • Study the propagation of uncertainty in complex equations
  • Learn about the rules for combining uncertainties in addition and multiplication
  • Explore advanced error analysis techniques in scientific measurements
  • Investigate software tools for error propagation calculations
Students, researchers, and professionals in scientific fields who deal with measurements and require accurate error analysis in their calculations.
coregis
Always the easy things we forget...
I know how errors propagate through multiplication or division when every term has an error, but how do I propagate errors in equations when only one term has an uncertainty? I want to say just multiply and divide the uncertainty value by the constants, i.e plug my value in the equation, then plug the uncertainty. This is the same as if I just found the % uncertainty, and multiplied the final product by that, correct? Is this the right way to go about this? And what if two (or more) terms have uncertainties? Would I find the uncertainty between those terms and then apply that % to the final number? Thanks.
If you mean something like y= ax+ b where a and b are exactly defined constants and x is measurement: x= m+/- e, then the largest possible value is a(m+e)+b= am+ ae+ b= (am+b)+ ae and the smallest possible is a(m-e)+ b= am-ae+ b= (am+b)- ae.
That is: (am+ b)+/- ae. Any added constants you can ignore. Constants multiplied by x multiply the error. Same for percentage error.
With more than one "uncertain" number you can get the exact error by calculating the maximum and minimum. A "rule of thumb" (good approximation but not exact) is that when you add or subtract measurements, the errors add, when you multiply or divide measurements, the percentage errors add.
  • · Replies 22 ·
  • · Replies 30 ·
  • · Replies 19 ·
