How Fast is the Triangle's Area Changing When the Board is 9 Feet from the Wall?
  • Thread starter Thread starter buffgilville
    Derivative Prime
The discussion focuses on calculating the rate of change of the area of a triangle formed by a 15-foot board, a wall, and the ground, as the bottom of the board slides away from the wall at 3 feet per second. The area A is expressed as A = 1/2 * x * sqrt(225 - x^2), where x is the horizontal distance from the wall. To find the rate of change of the area with respect to time, the relationship dA/dt = dA/dx * dx/dt is utilized, leading to the conclusion that the area is changing at a specific rate when x equals 9 feet.
  • Understanding of related rates in calculus
  • Knowledge of differentiation techniques, including the product rule
  • Familiarity with the geometric properties of triangles
  • Ability to manipulate square root functions
  • Study the concept of related rates in calculus
  • Practice differentiation using the product rule with various functions
  • Explore geometric applications of calculus, particularly in real-world scenarios
  • Learn how to derive and solve equations involving square roots in calculus problems
Students and professionals in mathematics, particularly those studying calculus, as well as educators looking for practical examples of related rates problems.
buffgilville
What is the y prime of:
A 15 foot board rests against a vertical wall. If the bottom of the board slides away from the wall at the rate of 3 feet per second, how fast is the area of the triangle formed by the board, the wall and the ground changing at the instant the bottom of the board is 9 feet from the wall?
I got this far:
y= square root of (225 - x^2)
I'm stuck after this step.
Can the answer for this be [(-9 yprime /2) + 18] square feet per second.
Hint x in terms of t. The displacement x away from the wall is equal to what in terms of t? It will be easy to then sub in this for x.
Area of a triangle is 1/2 * base * height
Base is x height is sqrt(225-x^2) right?
so A = 1/2 * x * sqrt(225-x^2)
However you need to plug in t to this I just didn't want to give away that much work.
Differentiate with respect to t in the new equation you find using the product rule (gets a little messy). Since 3t = 9, t = 3 goes into this new derivative and bam you got your answer.
I'm not sure what you mean by the question "what is the y prime of...?". If anything, the question seems to be asking for A'(t), where A is the area of the right triangle formed by the ladder, the wall, and the ground.
Draw a diagram, label the horizontal distance between the bottom of the ladder and wall x, and the corresponding vertical distance y
Given:
[itex]\frac{dx}{dt}[/itex] = 3 ft/s
This is a related rates problem. A is a function of x, so given the rate at which x changes with time, you should be able to find the rate at which A changes with time using the functional relationship:
[tex]A = \frac{1}{2}xy = \frac{1}{2}x\sqrt{225 - x^2}[/tex]
You identified this relationship correctly! :smile:
Now, please relate the rates:
[tex]\frac{dA}{dt} = \frac{dA}{dx}\frac{dx}{dt}[/tex]
[tex]= \frac{1}{2}\frac{d}{dx}(x\sqrt{225 - x^2})(3 \text{ft/s})[/tex]
Once you solve that, evaluate it at the value specified. I think that's right. It's kinda late here, so if any of this is bogus, please let me know.
EDIT: right, vsage, I forgot that you need x in terms of t.
  • · Replies 56 ·
