New Reply
Calculating Distance Using Force, Mass, and Acceleration
Share Thread Thread Tools
Nov24-10, 06:40 PM   #1
A rock is dropped from x(meters) height. The rock weighs 68 kg, and its force at impact with the ground is 15 kilonewtons. If the acceleration due to gravity is 9.8m/s^2, what is the distance/height the rock has fallen?
2. Relevant equations
F=m*a
15kN=15000kg*m/s^2
666.4N=68kg*9.8m/s^2
The force exerted by the rock at stationary position is 666.4 Newtons.
The rock fall distance is x meters.
3. The attempt at a solution
666.4N*x=15000N
(666.4kg*m/s^2)*x=15000kg*m/s^2
x=(15000kg*m/s^2)/(666.4kg*m/s^2)
x=22.51
This was all I could come with, but it is simply the ratio of the force. How do I find distance?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Nov25-10, 06:15 AM   #2
Mentor
Please state the complete problem exactly as given. As you've written it, there's not enough information. (The impact force depends on the nature of the surface being hit.)
Nov25-10, 03:59 PM   #3
Quote by Doc Al View Post
Shouldn't there be a formula for the kinetic energy of a mass falling distance x and a formula for the F generated by an unknown kinetic energy when it hits? The two could then be equated resolving x.
I don't see elastic/inelastic collisions mentioned.
Nov25-10, 05:02 PM   #4
Mentor
Quote by AC130Nav View Post
That one's easy.
That one's not so easy. More information is needed.
Nov25-10, 07:28 PM   #5
Thank you for your responses. This was a question posed to me by a friend of mine who rock climbs. He inferred that the distance of the fall could be calculated using the force, mass and gravitational constant. Is it correct to say that the energy spent to stop will be the same for different stopping distances while the required force will be variable?
The question may be better understood as follows:
A person who weighs 68 kg falls an unknown distance. The climber's rope has a breaking strength of 15 kN, and a dynamic elongation of 29%. Barring any other variables (friction, etc.), what is the furthest distance the climber could fall before the rope fails?
New Reply
Thread Tools
Similar Threads for: Calculating Distance Using Force, Mass, and Acceleration
Thread Forum Replies
Calculating power without distance? Introductory Physics Homework 6
Calculating Stopping Distance Introductory Physics Homework 2
Calculating distance to object? General Astronomy 5
Calculating Distance in Two Different Methods Introductory Physics Homework 3
Calculating Wavelength without distance Introductory Physics Homework 3
