New Reply
Curve fitting to diffusion equation(Matlab)
Share Thread Thread Tools
Nov25-10, 12:49 AM   #1
We have been trying to fit experimental diffusion results to the diffusion equation using Matlab to evaluate the Diffusion coefficient.
The equation we used:
y=C*erfc(x/(2*sqrt(D*t)))
Experimental values [x],[y] and t are given. C and D are to be evaluated from the curve fit.
We used cftool of Matlab.
We have a problem in getting the results. We get error message as:
"Error using ==> <a href="error:C:\Program Files\MATLAB\R2007b\toolbox\curvefit\curvefit\@fittype\feval.m,97,0">fi ttype.feval at 97</a>
Error in fittype expression ==> C.*erfc(x./(2.*sqrt(D.*300)))
??? Error using ==> erfcore
Input must be real."
Can anyone help?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Nov25-10, 03:39 AM   #2
It looks like the problem is that the error function requires real input arguments. Looking at your expression I would say the most likely problem is that the D parameter gets negative during the fitting, and as such maybe you could try to use abs(D) instead, although this could lead to the fitting algorithm having problems finding the right values.
New Reply
Tags
curve fitting, diffusion equation, matlab
Thread Tools
Similar Threads for: Curve fitting to diffusion equation(Matlab)
Thread Forum Replies
curve fitting using matlab Engineering, Comp Sci, & Technology Homework 1
MATLAB Curve Fitting Question? Introductory Physics Homework 1
Curve-to-curve fitting trouble! Programming & Comp Sci 5
Curve fitting in Matlab Math & Science Software 1
curve fitting using Matlab Math & Science Software 0
