Calculating Probability of Multiple Rolls on a D6
  • Context: High School
  • Thread starter Thread starter RDLowrider
    Multiple
The discussion focuses on calculating the probability of achieving specific results when rolling a D6 dice multiple times. The probability of rolling a "3+" on the first or second attempt is calculated as 8/9. Following a successful roll of "3+", the probability of rolling "4+" on the subsequent attempts is determined to be 1/2 for each roll. The overall probability of successfully rolling "3+" and then "4+" in the sequence described is 2/9.
  • Understanding of basic probability concepts
  • Familiarity with D6 dice mechanics
  • Knowledge of conditional probability
  • Ability to perform simple fraction calculations
  • Study advanced probability theory, focusing on conditional probabilities
  • Explore combinatorial probability techniques for multiple events
  • Learn about expected value calculations in dice games
  • Investigate simulations for probability outcomes using programming languages like Python
This discussion is beneficial for game designers, mathematicians, and hobbyists interested in probability calculations related to dice games.
RDLowrider
Hi, I play a dice game using a D6 to work out results. Sometimes you need to make multiple rolls and I'd like to be able to work out probability of getting certain results.
1st roll of a D6 needing 3+
If the first roll fails you get a second try again needing 3+
If either roll gets 3+ you roll again this time needing 4+
If succesfull you roll once more needing 4+
Any help with how to work this out would be greatly appreciated.
Cheers,
RD
The probability of getting "3+" (3 or more?) is 4/6= 2/3. The probability of not getting a "3+" is 1- 2/3= 1/3 and if that happens you roll again, the probability of getting "3+" on the second roll is again 2/3. The probability of getting a "3+" on the first roll or on the second roll is (2/3)+ (1/3)(2/3)= 6/9+ 2/9= 8/9.
Assuming that happens, your probability of getting "4+" (4 or more) on the next roll is 3/6= 1/2. If you are successful in that, the probability of getting "4+" on your last roll is also 1/2. The probability of all of those things happening is (8/9)(1/2)(1/2)= (8/9)(1/4)= 2/9.
Many thanks.
  • · Replies 16 ·
