How Fast is Time?
  • Thread starter Thread starter RunToFreeForFly
    Running Time
The discussion revolves around the concept of the "speed of time," exploring how time is perceived and measured in relation to movement and reference frames. It touches on theoretical implications from special relativity and the subjective nature of time perception.
  • Some participants propose that the speed of time is influenced by the speed of movement of an object, suggesting that time may flow differently on Earth compared to other locations.
  • One participant emphasizes that experimental evidence shows time intervals differ for objects moving relative to one another, asserting that there is no absolute speed of time.
  • Another viewpoint suggests that time is perceived differently based on one's frame of reference, with the rate of time flow being subjective and dependent on relative motion.
  • A participant argues that if one object accelerates, the passage of time for that object decreases as viewed from another object, linking this to the fraction of lightspeed the object is traveling.
  • There is a suggestion that the concept of "speed of time" could be equated to the speed of light, with implications for synchronization of time between objects at different speeds.
  • One participant humorously connects running speed to the speed of time, indicating a more metaphorical interpretation of the concept.
  • A question is raised about the existence of a FAQ on this topic, indicating a potential for further exploration of commonly asked questions regarding time perception.
Participants express differing views on the nature of time and its relationship to speed and reference frames. There is no consensus on the concept of "speed of time," and multiple competing interpretations remain unresolved.
The discussion includes assumptions about reference frames and the subjective nature of time perception, which may not be universally agreed upon. The implications of special relativity are referenced but not fully resolved in terms of their application to the concept of time speed.
RunToFreeForFly
How fast is it?
Exactly 1 (s/s).
estein said speed of time is change with the speed of movement of the object.
so the speed of time in Earth should be different?
Sticking to special relativity...
Experimental facts have shown that intervals of time are different for things that move relative to other things. What Einstein did was to explain it using other experimental facts.
All frames of reference are equivalent (earth = car = shuttle = particle = baseball = asteroid = random object in galaxy = Random object in Univers = etc.). While 4 seconds tick in one frame, 4.00001 seconds might tick in the other, and 3.554 s in another, and 10 s in another. (all depending on relative speed)
There is no "speed of time" anymore than there is a "speed of distance". Your question may assume there is an absolute reference frame in which time intervals are more important than in another. This is not the case. (although it was common good sense until 100 years ago, when new phenomena were discovered.)
Time is flowing at a rate that is determined by your perception, or the rate at which an instrument may detect constant distance.
Not quite - since you are at rest relative to yourself (or your watch), you don't notice time dilation.
It could be said that the "speed of time" is c. For two objects that are at rest relative to one another, time progresses at the same rate for both. If one object accelerates to some arbitrary speed, the passage of time for that object (as viewed by the other object) will decrease. This decrease is a function of whatever fraction of lightspeed the first object is traveling. If you look at time as traveling by at lightspeed, you can say that the accelerating object is "catching up" to time. If this object were ever to actually reach the speed of light, time would cease to move for that object. It could be argued that the object has accelerated until it was synchronized with a particular moment, and is not traveling parallel with that moment.
Isn't there a FAQ on this?
  • · Replies 25 ·
  • · Replies 31 ·
10K
