New Reply
Heat exchanger problem in Thermodynamics.
Share Thread Thread Tools
Nov25-10, 04:30 PM   #1
Hi!
I get the basics now, but this problem has got me stumped. I am trying to figure out where to start.
In a heat exchanger, cold water flows through the tubes of the exchanger. It enters at 5.5°C, and leaves at 65°C. In the shell of the exchanger steam is being condensed. The steam enters at atmospheric pressure and 100°C, and the condensate that is formed leaves the exchanger before it can be cooled. The flow rate of the steam is 15.0 kg/s. What is the cooling flow rate?
2. Relevant equations
Oil flows through a heat exchanger at a flow rate of 125 L/min. It enters at 20°C and leaves at 75°C. The oil has a specific heat of 2.84 kJ/kgK and a relative density of 0.8. The oil is being heated by steam. The steam enters the heat exchanger at 100°C and the condensate formed leaves the heat exchanger at 85°C. Calculate the mass flow rate of the steam.
3. The attempt at a solution
First thing we know is that cool water flows through the tube, and exits as warm water. In the shell, steam is being condensed. So basically water turns into steam.
Q (cool water absorbing heat) becomes hot water.
Q = mcΔt + mLv + mcΔt (water becomes steam)
The idea is solid, but I am not sure how I take the above, and find the flow rate. For all I know, those two are different categories.
Thank you for your help. I am this close to finishing up the course, so stumbling at this point does hurt, but the help which I receive will mean a lot to me.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
New Reply
Tags
heat exchanger, mass flow rate, specific heat, steam, thermodynamics
Thread Tools
Similar Threads for: Heat exchanger problem in Thermodynamics.
Thread Forum Replies
Thermo Heat Exchanger Problem Introductory Physics Homework 0
Is the overall heat transfer coefficient constant for a certain heat exchanger? Advanced Physics Homework 0
Is this even possible? (heat exchanger problem) Mechanical Engineering 4
Heat Exchanger problem Mechanical Engineering 7
Adiabatic heat exchanger problem... Please Help! Materials & Chemical Engineering 5
