| New Reply |
Java problem |
Share Thread |
| Nov30-10, 12:52 PM | #35 |
Java problemCode:
public class Transmitter
public int X ;
public int Y ;
public int Radius = 300 ;
public Transmitter(int X1, int Y1, int Radius1)
if(X1 < 800 || X1 > 1280)
System.out.println("ERROR, The X value you've entered is incorrect.") ;
System.out.println("Range MUST be : 800 to 128") ;
System.out.println("A default value will be set to 800");
X1 = 800 ; //Minimum value ( deafult range)//
else
X1 = X ;
if(Y1 < 100 || Y1 > 440)
System.out.println("ERROR!, The Y value you've entered is incorrect.") ;
System.out.println("Range MUST be : 100 to 440") ;
System.out.println("A default value will be set to 100");
Y1 = 100 ; //Minimum value ( deafult range)//
else
Y1 = Y ;
if(Radius1 < 300 || Radius1 > 500)
System.out.println("ERROR!, The Radius value you've entered is incorrect.") ;
System.out.println("Range MUST be : 300 to 500") ;
System.out.println("A default value will be set to 300");
Radius1 = 300 ; //Minimum value ( deafult range)//) ;
else
Radius1 = Radius ;
public Transmitter(int X1, int Y1)
System.out.println("Range MUST be : 800 to 1280") ;
else
X1 = X ;
else
Y1 = Y ;
///---Accessers---//
public int getX()
return X ;
public int getY()
return Y ;
public int getRadius()
return Radius ;
///---Mutators---///
public void setRadius(int rad)
Radius = rad;
| Nov30-10, 01:00 PM | #36 |
Mentor
Please read my comments in post #32.
| Nov30-10, 01:01 PM | #37 |
I did i thought thats what you menat to change.
for post #34 I put in the accesors just for me iwanted to see the values that were being returned. the main method is the transmitter test. |
| Nov30-10, 01:13 PM | #38 |
Mentor
The member variables for your class are X, Y, and Radius. X1, Y1, and Radius1 are parameters in the constructors. You should NOT be setting X1, Y1, and Radius1. |
| Nov30-10, 04:21 PM | #39 |
This is definitly it :)
i have a System.out.println() method that prints out all the x,y cords but it uses the last set to calculate the signal strength. For the next part i don't really understand what i've done wrong, it genrates the random corodinates for x,y for however many transmitters the user puts in. I know i'm probably wrong but like before i'm confused where to go with it,it seems right to me. Code:
public int X ;
public int Y ;
X1 = X ; //Minimum value ( deafult range)//
X = 800 ;
else
X = X1;
Y1 = Y ; //Minimum value ( deafult range)//
Y = 100 ;
else
Y = Y1 ;
Radius1 = Radius ; //Minimum value ( deafult range)//) ;
Radius = 300 ;
else
Radius1 = Radius ;
X1 = X ;
X = 800 ; //Minimum value ( deafult range)//
else
X = X1 ;
Y = 100 ;
else
Y = Y1;
public int getX()
return X ;
public int getY()
return Y ;
return Radius ;
Radius = rad;
| Nov30-10, 05:45 PM | #40 |
Mentor
That will work, but has some extra cruft in it that should be removed.
Code:
X1 = X ; //<-- Take out this line
X = 800 ;
In the second constructor there are two lines where you set X1 = X and Y1 = Y. They should be removed, too. |
| Nov30-10, 05:49 PM | #41 |
okay done can u help with the test part i'm very confused with it
| Nov30-10, 06:20 PM | #42 |
Mentor
A mobile phone user's signal strength is determined by their distance from a transmitter. If the distance is greater than the transmitter radius then the signal strength is zero. Otherwise the signal strength is determined as follows
(1 - (distance/radius)) * radius . . . Testing the Transmitter Class To test the transmitter class you should create another class called TransmitterTest. The test class should look like the following public class TransmitterTest { private Transmitter[] network ; public TransmitterTest(int networkSize) { network = new Transmitter[networkSize] ; // // PUT YOUR CODE HERE // to load the network array with // "networkSize" instances of the Transmitter class. // The x,y coordinates of the transmitters should be // randomly generated. You can specify a radius or // use the Transmitter Class default. } // PUT YOUR CODE HERE // to do the operation(s) specified below } • Include a method called bestSignal that has the following header public int bestSignal(int phoneX, int phoneY) The method is passed the x,y coordinates of a phone and calculates the distance from the phone to each transmitter in the network. It returns the array index of the network transmitter that provides the best (i.e. highest) signal strength. If none of the transmitters provides a signal level greater than zero the method should return a -1 value. ------------------------------------------------------------------------------------ You're going to need a Main method that sets a value for networkSize and creates the network array with that many Transmitter objects in it. You'll need a loop that executes networkSize times, once for each Transmitter object in the network array. For each Transmitter object generate random numbers for the x and y coordinates and the radius. The bestSignal method should go through the network array and calculate the distance from the specified phone (the one with coordinates phoneX and phoneY), and return the index of the Transmitter array with the highest signal strength. In your earlier code you had bestSignal returning the distance, which isn't what it's supposed to do. |
| Nov30-10, 06:42 PM | #43 |
i basically have that don't i. all i need to do is the best signal part isn't it?
| Nov30-10, 06:59 PM | #44 |
Mentor
No, you don't "basically have that."
1. You don't have Main(). 2. You aren't creating any Transmitter objects in your network array. 3. The values you are generating for X, Y, and Radius aren't correct. For example, in your code you have Code:
X = randnumb.nextInt(800) + 480 ; There's a similar problem for Y, where you have Code:
Y = randnumb.nextInt(100) + 340 ; 4. You're doing something very silly with Radius. Code:
Radius = Radius ; 5. The Transmitter objects should have random values for Radius, but your code isn't doing this - it uses the value 300 all the time. 6. What is the purpose of countX, countY, and countRad? By the time you get to i++ in your loop, i will have the same value as these other three variables, so what's the use of having them? |
| Nov30-10, 07:08 PM | #45 |
oh okay, right i dont understand the main() part. how do i make it create a transmitter instance inside another class?
The count parts we're so that when it had 1 value it stored that then generated another one depending on how many transmitters you wantted the radius is being set to the default radius in the transmitter that just has X1,Y1 as paprameters, i thought it would be easier if i just used the x and y instead of using all the variables |
| Nov30-10, 07:16 PM | #46 |
Mentor
| Nov30-10, 07:19 PM | #47 |
yeah your right i'm trying to do it now i'll out up what i've done in a few mins
| Nov30-10, 07:24 PM | #48 |
How do i use the transmitters i made do i rewrite the code in or is there a way of calling a class within a class? do i apply the distance formula for each instance of the transmitters that i call
| Nov30-10, 07:33 PM | #49 |
it's not fully finished but is the random generation right?
Code:
import java.util.Random ;
public int X ;
public int Y ;
public int X2 ;
public int Y2 ;
public int RadiusDefalut = 300 ;
public int Radius ;
int i = 0 ;
while (i < networkSize)
Random randX = new Random() ;
X = randX.nextInt(480) + 800 ;
System.out.println(X) ;
Random randY = new Random() ;
Y = randY.nextInt(340) + 100 ;
System.out.println(Y + " ") ;
Random randRadius = new Random() ;
Radius = randRadius.nextInt(200) + 300 ;
System.out.println(Radius);
i++ ;
int bestSignal ;
int X1 = X ;
int Y1 = Y ;
int X2 = phoneX ;
int Y2 = phoneY ;
int distance = (int)Math.sqrt( (X2 - X1)*(X2 - X1) + (Y2 - Y1)*(Y2 - Y1)) ;
bestSignal = (1 - ((distance/Radius)) * (Radius)) ;
return bestSignal ;
| Nov30-10, 07:54 PM | #50 |
i'm so confused i don't know how to input each x,y and radius into each transmitter that gets created in the array, does it go in the loop or what??
| Nov30-10, 08:18 PM | #51 |
Mentor
Yes, your random numbers look fine. They're now in the right intervals.
For your other question, the x, y, and radius values don't come from user input - they are generated as random numbers. And yes, each iteration of the loop needs to generate an x, a y, and a radius, then call a Transmitter constructor, passing those values of x, y, and radius in the constructor call. You're going to have a statement like this inside the loop: Code:
// generate random x, y, and radius values network[i] = new Transmitter(x, y, radius); network[2].getX() will return the X value for the Transmitter object at index 2 in the array. network[m].getY() will return the Y value for the Transmitter object at index m in the array. I think I remember that you have a getRadius() method. It would work the same way. |
| New Reply |
Similar discussions for: Java problem
| Homework problem in Java | Engineering, Comp Sci, & Technology Homework | 9 | ||
| problem w/ java calculation | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Help me with a Java code problem | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Java problem | Computing & Technology | 4 | ||
| Java Problem | Introductory Physics Homework | 0 | ||
