What Is the Ideal Placement of a Rod on a Pendulum String for Complete Rotation?
  • Thread starter Thread starter JonDaMon8
    Pendulum
The discussion revolves around the placement of a fixed rod on a pendulum string to allow a bob to complete a full rotation. The problem involves concepts of energy conservation and the dynamics of pendulum motion.
  • Participants explore energy conservation principles, questioning how potential energy converts to kinetic energy during the pendulum's motion. There is discussion about the implications of placing the rod at various points along the string and how that affects the bob's ability to complete a rotation.
Some participants have suggested using energy conservation to analyze the problem, while others are questioning the adequacy of energy at different rod placements to maintain tension in the string. There is an ongoing exploration of how the bob's kinetic energy changes as it moves through its path.
Participants note the importance of ensuring that the string remains taut throughout the motion and are considering the effects of centripetal acceleration on the bob's trajectory.
JonDaMon8
Alright this is the problem, i hope i describe it so you can all understand it
You start out holding the bob at and angle of 90 degrees (horizontal), with the string tight. Then release the bob, when the angle hits 0 degrees a fixed rod is placed somewhere between the top of the string and the bob. This cuts the length of the pendulum so that the pendulum now spins around the fixed rod
At what spot on the string should the fixed rod be placed that will allow the bob to spin all the way around the fixed rod at least once
By doing guess and check i concluded that it would be at exactly half way down the string to allow it to spin around the fixed rod
But i can't figure out how you would figure it out
i kno you use mg sin theta to find the PE i believe but i can't figure out what to do from there
If you don't get my description i can prolly make a video to show what i mean
Try energy conservation!
How? When the string reaches the bottom, the potenial energy is at 100%, and then starts to turn into KE in an equal ratio. But i don't see how i can apply it into the problem
Alright i got an idea, since the length of the pendulum has been cut in half, (because of the fixed rod) half of the enegery from the original fall is used to get the bob back to horizontal with the x-axis, and the rest of the energy to get it around the bob past the y-axis and around to a complete rotation
If you set the fixed rod up at further down from the midpoint of the string, there is some energy left over
and if you set the fixed rod about the midpoint of the string, there isn't enough energy to get it to go around it would stop at around a positive angle from the -x axis...
does this make any sense or sound correct to u guys?
This is incorrect.
As Tide suggested, you will need to use conservation of energy. But be sure that the bob has enough energy at the top of its motion so that the string remains taut. (To find out how much energy is needed to keep the string taut, consider centripetal acceleration.)
Doc Al said:
This is incorrect.
Alright, so theoretically, if the fixed rod is at halfway between the top of the string and bottom, when the string gets to horizonal with the fixed rod, 50% of the KE is transferred, right? That means there's 50% KE left, but that 50% is not enough to keep the string taut just enough to get it to the very top and then it would fall, correct?
When the bob reaches half its original height, it will have half the KE it had at the bottom. And that is not enough to keep the string taut throughout the rest of the motion. When the string goes slack the bob will follow a parabolic path, so it won't even make it to the original height. (It's not being shot straight up: the string changes the bob's trajectory. So it will never make it to the original height if the rod is placed at the halfway point.)
  • · Replies 21 ·
