What are the kinetic frictional forces in an accelerating elevator?
  • Thread starter Thread starter BlackMamba
    Forces Kinetic
The discussion revolves around a problem involving a 2.60kg box sliding across the floor of an elevator, with a coefficient of kinetic friction of 0.490. Participants are exploring the kinetic frictional forces in two scenarios: when the elevator is accelerating upward and when it is accelerating downward.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of the kinetic friction formula and the role of normal force in different scenarios. There are attempts to analyze forces using free body diagrams and Newton's second law. Questions arise about the significance of gravitational force and how acceleration affects the normal force and frictional force.
Some participants have drawn free body diagrams and attempted calculations, while others are seeking clarification on the equations involved. There is an ongoing exploration of the effects of upward and downward acceleration on the normal force and frictional force, with some participants expressing uncertainty about their calculations.
Participants are working under constraints of homework rules, which limit the number of submissions allowed for their answers. There is a recognition of the importance of correctly accounting for gravitational forces in their calculations.
BlackMamba
Hello,
I have a problem that I am stuck with. The problem consists of a 2.60kg box sliding across the horizontal floor of an elevator. The coefficient of kinetic friction between the floor and the box is 0.490. I have to determine the kinetic frictional forces of different cases.
(a) when the elevator is stationary ------Which I have already done. That part was easy.
but I'm stuck on the following two.
(b) when the elevator is accelerating upward with an acceleration of 1.30 m/s^2
(c) when the elevator is accelerating downward with an acceleration of 1.30 m/s^2.
I assumed that I could use the equation, kinetic frictional force = kinetic friction times mass and acceleration. That however was not correct.
Any help or direction provided would be greatly appreciated.
Remember [tex]F_{f} = \mu N[/tex]
Do a analysis on the y-axis of the forces, you know the mass and acceleration.
That is the first time I've seen the equation you provided. I am not sure I understand it. Is that the Force of friction = the coefficient of the normal force?
I also don't understand what you mean by doing an analysis of the y axis.
Yes I know the mass (2.60kg) and the acceleration is (1.30 m/s^2). By analysis, do you mean what direction the acceleration is going? If so, when the elevator is moving upward the acceleration is pointing downward...right? And vice versa with the opposite direction. Other than that, what else do I need to know about the y axis?
Oh...there would be a Weight force acting on the block. Would I need to know that? Would that be in play?
Thanks for helping
[tex]\mu[/tex] is the coefficient of friction, in this case kinetic, and N is the normal force.
I'm talking about a Free Body diagram of the forces acting on the block, you know the elevator is accelerating upwards/downwards, so the block will have a movement on y-axis.
Use Newton's 2nd Law
[tex]\sum^{n}_{i=1} \vec{F}_{i} = m \vec{a}[/tex]
Right, I drew a free body diagram and that did nothing. LOL
Oh and your initial equation is just a bit different from how it is in my book. That's why I didn't quite get it at first. I used that equation to find the frictional force when the elevator was stationary, that was easy. But I don't understand where acceleration comes into play.
Using Newton's second law, I understand that net force equals mass times acceleration. Oh...I think I get it now. I have to find the net force of the box when the elevator is traveling up and down then plug that into my equation to find the kinetic friction force. Is that correct?
So if this were the case then the number would be the same for up and down?
Give it a try :biggrin:
Well what's your sign convention? if up and right is positive, then left and down must be negative.
LOL, thanks. But I have to be somewhat sure before I post my answer considering my class uses webassign and we are only alloted so many submissions and this is only my second problem I'm working on. LOL But yes, I will give it a try.
Thank you for your help. :)
Well I did it your way and still got the same answer I got before. LOL And I know that's wrong because I submitted it once already and it was wrong.
Show me what you did.
I found the net force of the box when the elevator is going up and down using Newton's second law.
[itex]\sum \vec{F} = m \vec{a}[/itex]
So that gave me a total -3.38 and 3.38
I pluged those figures into : [itex]F_{f} = \mu N[/itex]
and got -1.66 and 1.66.
I will do b)
Y- Axis
Up and Right positive.
[tex]N - mg = ma[/tex]
[tex]N = ma + mg[/tex]
[tex]N = m(a + g)[/tex]
Now
I got 14.14 N
Just as you posted this I figured out that I was neglecting gravity. LOL Thanks again.
Just double checking. For (c) then the answer would be: 10.83N correct?
I believe so.
Thanks again for your help. It is much appreciated.
Well, It's always good to be of help :smile:
Well perhaps you could help me with another problem then. :D
Here is a link to the picture: http://www.webassign.net/CJ/4-67alt.gif
The block on the table is 492N and the hanging block is 175N.
(a) find the acceleration of both blocks
(b) find the tension in the cord
I know the tension will be the same for both blocks and have managed to come up with these two equations for each block.
Block 1
[tex]\sum F_{x} = - W_{1} + T = m_{1}a[/tex]
Block 2
[tex]\sum F_{y} = T - W_{2} = m_{2}(-a)[/tex]
Now I'm supposed to solve for both T and a and I'm supposed to do this by solving simultaneously. My question being how on Earth do I solve them simultaneously?
Thanks for any help.
if there's no friction, there's only tension on the first block.
Right that's what I meant. But I'm still getting extremely frustrated in that I've tried solving this every which way and I don't appear to be getting any closer.
I tried by getting T alone for the block 2 equation and substituting that into the block 1 equation and still nothing.
I will solve it, if there's something you don't understand, let me know.
On x-axis:
[tex]T = m_{1}a[/tex]
On the y-axis:
[tex]T - m_{2}g = -m_{2}a[/tex]
[tex]m_{2}g - T = m_{2}a[/tex]
Adding Equations on X-axis and Y-axis:
[tex]m_{2}g = (m_{2}+m_{1})a[/tex]
[tex]\frac{m_{2}g}{m_{2}+m_{1}} = a[/tex]
OK I understand what you've done, and understand once I've solved for [tex]a[/tex] I can plug that back into this equation: [tex]T = m_{1}a[/tex] to find [tex]T[/tex].
But I've been trying to match this up with an example from my book and I'm still not getting the same answer in their example. However the only difference is their example involves an incline degree. I'll keep working on it, I'll be back though I'm sure.
Ah good as gold. Thanks again cyclovenom. :D
Like i said, no problem, it's always good to help out.
  • · Replies 16 ·
