Escaping the solar system from Earth's orbit
The discussion revolves around calculating the minimum speed required for a spacecraft to escape the solar system from Earth's orbit. The problem involves concepts from gravitational potential energy and kinetic energy, specifically in the context of celestial mechanics.
  • Participants discuss the application of gravitational potential energy formulas and the significance of the radius used in calculations. There is an exploration of the implications of using different values for the radius of the solar system and the Earth's orbit.
Participants are actively engaging with the problem, questioning the assumptions made about the radius and the definitions of energy in the context of escape velocity. Some guidance has been offered regarding the relevance of certain masses and the correct radius to use in calculations.
There is mention of confusion regarding the appropriate value for the radius of the solar system, with participants noting the need to clarify which radius should be used in the calculations. The discussion also highlights the potential for misunderstanding the definitions of energy in gravitational contexts.
irishbob
(a) What is the minimum speed, relative to the Sun, necessary for a spacecraft to escape the solar system if it starts at the Earth's orbit?
Kinetic Energy=Potential Energy
0.5mv^2=rGM/(r^2)
0.5v^2=GM/r
Where M is the mass of the sun, and r is the radius of the solar system
v=[tex]\sqrt{\frac{2GM}{r}}[/tex]
v=[tex]\sqrt{\frac{2(6.673E-11)(1.98892E30)}{7.5E15}}[/tex]
v=188.1281 m/s
v=0.18813 km/s
So I'm pretty sure I'm using the right methods and variables, but I'm not sure what's going wrong. My only thought is that I'm using the wrong value for the radius, but I can't seem to find 1 value that's agreed upon for the radius of the solar system. Help?
There is a strange thing to understand on this E = GMm/R formula, Bob.
When R is infinitely large, E = 0. That means the makers of the formula defined zero potential energy to be when the m is infinitely far from the M. Any finite value of R gives a larger value for E which doesn't make sense. Of course you have to fire your rockets to boost m from any finite value of R to infinity. It DOES make sense if you put a minus sign on it: E = -GMm/R. Then your m has negative energy until you boost it way out there, where it then has zero energy. To make the long story short, energy E = GMm/R must be added to the negative energy it has at radius R in order to move it out of the solar system. And the R you use is not the radius of the solar system, but the starting radius - the radius of the Earth's orbit in this case.
I get the first part (number/large number=small number, lim as x->infinity of 1/x=0), but I'm having a little trouble following the second part. Would it be like this?
sqrt(2gm/r)=-GM(earth)m(rocket)/R(earth)+GM(sun)m(rocket)/R(earth)?
hi irishbob! :smile:
(have a square-root: √ and try using the X2 tag just above the Reply box :wink:)
no, the mass of the rocket is irrelevant (because it doesn't affect the escape velocity), so is the mass of the Earth (because the question says "from the Earth's orbit", which needn't be anywhere near the Earth! :wink:)
go back to your √(2GMSun/R) :smile:
what do I use for R though? It's still not coming up right...
R is distance to the Sun :smile:
if it still doesn't come out right, show us what you've done :wink:
That was the problem! it was 3 a.m. my time when I was doing this, and for some reason I thought it would be a good idea to use the radius of the sun for R. Thanks!
Glad to help! Hope you don't have to work through the night again.
:zzz: :zzz: :smile:
  • · Replies 30 ·
