Finding Initial Velocity of a Freely Falling Object
The discussion focuses on calculating the initial velocity of a freely falling object that takes 1.50 seconds to travel the last 30.0 meters before hitting the ground. The acceleration due to gravity is established as -9.80 m/s². The user initially calculated the average velocity for the last 1.50 seconds as 20 m/s, but later derived the initial velocity using the kinematic equation, resulting in a more reasonable value of 12.65 m/s after adjusting the acceleration. The final solution involves substituting values into two derived equations to find the total time of descent, which is approximately 2.8 seconds.
  • Understanding of kinematic equations in physics
  • Knowledge of acceleration due to gravity (-9.80 m/s²)
  • Ability to manipulate algebraic equations
  • Familiarity with concepts of free fall and displacement
  • Study the derivation and application of kinematic equations in physics
  • Learn about the effects of air resistance on free-falling objects
  • Explore advanced topics in projectile motion
  • Investigate real-world applications of free fall in engineering and physics
Students studying physics, educators teaching kinematics, and anyone interested in understanding the principles of free fall and motion dynamics.
elsmith2
need help finding where to start,
"A freely falling object requires 1.50sec to travel the last 30.0m before it hits the ground. From what height above the ground did it fall?"
I know that:
accel = -9.80m/s^2
avg. veloc for last 1.50 sec = 20m/s
that i need the initial velocity for that period
Thanks in advance for your help,
Ed
sitting here looking at my post and my physics book it dawned on me to use this eqn:
() = subscript
x(f) = x(i) + v(xi)t + 1/2 a(x)t^2
therefore
30 = 0 +v(1.50) + 1/2(-9.80)(1.50^2)
v = 27.35m/s
but that can't be, so i switched the accel to positive and got v = 12.65m/s which sounds more reasonable, but i thought that we use -g for accel of free falling objects. now I'm confused.
ok let's do a little modification to the displacement formula
originally we have d = d1 + v1*t + 0.5*a*t^2
Since it's free falling let's just make v1 = 0 and assume it was just dropped from a height d1
d = d1 + 0.5*a*t^2 where d1 was the original height from which it began a descent
let t' = t - 1.50 so then d' would be the displacement at time t' (30 m above the ground). I'm using t as the total time it took for the descent.
d' = d1 + 0.5*a*t'^2
30 = d1 - 0.5 * 9.8*(t-1.5)^2 Equation (1)
You also know that
0 = d1 + 0.5*a*t^2
0 = d1 - 0.5 * 9.8*(t)^2
d1 = 0.5 * 9.8 * (t)^2 Equation (2)
substitute d1 back into equation 1 to get
30 = 0.5*9.8*t^2 - 0.5*9.8*(t-1.5)^2
solve for t. you should get around 2.8 seconds.
so now you know d1 = -0.5*a*t^2 by equation 2 so plug in t and you're done!
I could have done this a lot easier but I wanted to show you step by step.
