Indirect vs. Direct Bandgap Semiconductors
The discussion revolves around the differences between direct and indirect bandgap semiconductors, exploring the underlying reasons for these distinctions, including theoretical and structural considerations. Participants inquire about predictive rules and the implications of band structure on semiconductor behavior.
  • Some participants inquire about the reasons why certain semiconductors have direct bandgaps while others have indirect bandgaps, seeking a "thumb rule" for prediction.
  • One participant explains that the determination of a semiconductor's bandgap type can be derived from the E-k diagram, which requires complex numerical techniques.
  • Another participant notes that most III-V semiconductors are direct bandgap, while group IV semiconductors tend to be indirect, citing examples like GaAs and Si.
  • Questions are raised about the theoretical differences between Si and Ge, particularly regarding their similar structures but differing bandgap types, with speculation on the influence of crystal structure and electron interactions.
  • There is discussion about the tight-binding model and its relation to atomic orbital overlap, with questions about how this affects electron excitation between bands in Si and Ge.
  • One participant describes the E-k diagram characteristics of direct and indirect semiconductors, highlighting the role of phonons in indirect semiconductors for energy transfer during recombination.
Participants express varying viewpoints on the reasons behind the differences in bandgap types, with no consensus reached on a definitive explanation or predictive rule. The discussion remains unresolved regarding the underlying theoretical principles.
Participants acknowledge the complexity of the topic, noting that the relationship between crystal structure and bandgap characteristics is not straightforward and may depend on various factors, including atomic interactions and potential energy variations.
question2004
I have one question to trouble you.
Why some semiconductors have a direct bandgap, while some have an indirect bandgap? Is there any very crude "thumb rule" of predicting/justifying it? Thanks a lot
bandgap= ?
are you talking about ttl vs mos?
Bandgap in semiconductor is the energy gap between the conduction and valence band. Whether a semiconductor's bandgap is direct or indirect can be determined from the E-k diagram, which is obtained by solving Bloch equation using comprehensive numerical technique. I don't think there's a rule of thumb that allow us to specify the bandgap characteristic from cold. But to date most of the technologically exploited III-V semiconductor compound are direct bandgap (GaAs, InP etc), while group IV are indirect (eg Si, Ge).
Why the big difference?
hi!
A question...why the big difference? Let's say Si and Ge where both have the same structure, the only difference is the 18 extra electrones, but Si have an indirect bandgap and Ge a direct. What in the theory makes the band structure direct or indirect bandgap? Is it that the Bolch waves of the valence electrones "see" different amount of electrons and therefore feel a different potensial or the small difference in cell parameter or something completely different?
Dielectra (...exame soon :rolleyes: )
Dielectra said:
hi!
There isn't anything obvious, or "rule of thumb" to know which will give you wish. The only way that I know is via direct band structure calculation and/or experimental observation. There is nothing obvious simply by looking at either the atomic structure, or the crystal structure. The crystal structure especially can severely influence the band structure, but again, there is nothing direct that I know of that can point one way or the other.
Zz.
I suspect that the big difference between the behaviors of Si and Ge comes from the differing crystal structures (in addition to other possibilities). Si has a diamond structure, while Ge has a cubic close packed structure...that by itself provides more than a plausibility argument for the different dispersions.
ok...
I read some more...and do you think it can be a result of the tight binding model? And then because of overlap of atomic orbitals? Then for Si we get s(+)-p(+)-p(-)-s(-) because of a high Vss potensial and a smaller Vxx, and the valence electrons and for Ge is s(+)-p(+)-s(-)-p(-). Can we then get an easier exitation of electrons from p(+) to s(-) in Ge than p(+) to S(-) in Si? Can that be the case?
Dielectra said:
ok...
Unfortunately, your question now doesn't make a lot of sense. It is BECAUSE of the overlap of atomic orbitals that you have to consider the tight-binding model. They are not different things.
It isn't this easy. Tight-binding model can include nearest neighbor, next nearest neighbor, next next nearest neighbor, etc. It depends on how much there is an overlap, and the crystal structure. That is why you have the so called hopping integral.
Zz.
Direct semiconductors have minimum conduction band and maximum valence band at k=0 in E-k diagram. That’s allows direct carrier recombination.
In indirect semiconductors (Si) electron got some energy in minimum conduction band and mediator needed for transferring energy (phonons usually) in recombination process.
So it’s big difference in carrier lifetime.
If you asked HOW it happens – the answer is – such E-k diagram.
If you asked WHY it happens – nobody knows I guess… ))))
