Register to reply
Why does an object in motion remain in motion?
by trendy
Tags: motion, object, remain
Share this thread:
trendy
#1
Sep29-04, 03:24 AM
P: 6
Hello. I need an answer to a question that I couldn't find on the web.
Why does Newton's first law hold? I mean is there an explanation why does an object in uniform motion tend to stay in this state of motion? Is this still a principle derived from mere observation or we can explain it with some underlying theory?
Thanks.
Phys.Org News Partner Physics news on Phys.org
Scientists uncover clues to role of magnetism in iron-based superconductors
Researchers find first direct evidence of 'spin symmetry' in atoms
X-ray laser probes tiny quantum tornadoes in superfluid droplets
Tide
#2
Sep29-04, 03:36 AM
Sci Advisor
HW Helper
P: 3,144
You left out the part about "unless acted upon by a force."
Mere observation? Isn't that what science is all about - observation and theories? You don't get much more "underlying" than that. Besides, it makes perfect sense.
LURCH
#3
Sep29-04, 06:14 AM
Sci Advisor
P: 2,510
As of this date, there is no known "cause" for inertia. I believe some forms of string theory may be attempting to give a reason for this property of mass, but for the most part, it is simply accepted as a consequence of mass (in fact, a part of the very definition of mass). I recall reading that it was once thought that a spear thrown through the air caused a parting of the air, and this air rushing back in to fill the void is what kept the spear moving forward. Currently, there is no such mechanistic explanation.
trendy
#4
Sep29-04, 06:23 AM
P: 6
Quote Quote by Tide
I don't mind if it is an observation. I just need to know how far the science has gotten.
I am not sure if it makes perfect sense though. How does the object "know" where it has been a while ago, so that it can continue to move in the same direction and with same velocity? How does it "remember" that it is moving instead of being at rest? Do the objects have in fact some kind of "memories"?
I would say that it would make much more sense if the objects move randomly instead of in such predictable fashion...
trendy
#5
Sep29-04, 06:26 AM
P: 6
Thanks LURCH, I guess that answers my question
spacetime
#6
Sep29-04, 07:41 AM
P: 119
That a body in motion will remain in the same state of motion unless unbalanced forces act upon it is a matter of definition. What does it define? It defines inertial frames of reference. That is, inertial frame is a frame in which a body in motion will remain in the same state of motion unless unbalanced forces act upon it.
The real law of nature as that it is possible to find such frames. So, your question can be reframed as - Why do inertial frames exist?
The answer - symmetry. If it doesn't remain in the same state of motion, it must change the state, and there are an infinite number of ways in which that can happen and one can't be preferred over another.
But there is just one way to remain in the same state of motion, and that is exactly what happens.
www.geocities.com/physics_all/index.html
trendy
#7
Sep29-04, 10:04 AM
P: 6
WOW, that was a cool logic indeed, I like it, it makes sense
LURCH
#8
Sep29-04, 10:51 AM
Sci Advisor
P: 2,510
Another way to look at it is to take the other half of that law (that a body at rest tends to remain at rest), and apply it to moving bodies. This idea seems more intuitive to most people. Then Spacetime's point about inertial frames comes into play, when you aknowledge that motion is relative. So, a body in motion is a body at rest, to any observer in that body's inertial frame of reference (if you speed up to match the speed and direction of the object, it is "at rest" to you).
Gokul43201
#9
Sep29-04, 11:29 AM
Emeritus
Sci Advisor
PF Gold
Gokul43201's Avatar
P: 11,155
It is intuitive to look for causes that change things. If there is no cause, you can expect no change. And conversely, if there is no change in the behavior, you expect that there no agent acting on it.
So, really, the answer should be "why not ?".
sinyud
#10
Sep29-04, 10:59 PM
P: 23
"An object in motion stays in motion"
in the reference frame of the moving object, this statement can be reformulated as
"An object not in motion, stays in not motion"
Aha!
I realize the duck has been slaughtered, and while I'm against curelty to animals, it's really not that cruel to beat the duck if it is already dead (Although it is a sign one might be disturbed). So; to beat the dead duck (I also like hear my self talk, or write)
"An object in motion stays in motion" Why? One of Einstein's posulates is that there is no prefered reference frame. So in the reference frame of a moving object, for arguments sake, let's say a duck, the duck doesn't always perceive himself as moving.
Let me reforumulate the motion principle for the duck
A: "A duck in motion, stays in motion"
but wait, the duck can say "I'm standing still, you are the one who is moving"
in which case statement A becomes
"A duck thats not in motion, stays in not motion"
So then the question is, how does the duck ever perceive himself moving?
aekanshchumber
#11
Sep30-04, 01:15 AM
P: 91
hello,
If you understand the Law of conservation of energy properly then it is much easier to understand why the Newton's first law holds. You see, L.C.E states that energy remained conserved for a proper system, now if any object have to move without any force acting on it then it voilates the laws of conservation of energy. Hence to increase the energy of the object we have to sped the energy on it i.e apply force on it.
It might help you.
trendy
#12
Sep30-04, 06:03 AM
P: 6
Yes, I can see it in the context of the L.C.E. But still LCE is another principle derived from observation, so it seems that we are stuck here... like a dead duck
In the context of LCE, I can reformulate my speculation like this - how does the system "know" what energy it has? But I guess I got the answer to that one -> it's a matter of cause and effect - if there is no cause, there is no effect For the system energy to change, there must be a force applied, so if there is no force, there is no change. But this is pretty much philosofical, I guess after time we will have a better understnding of the ways of the Universe
aekanshchumber
#13
Sep30-04, 07:07 AM
P: 91
it seems that you want a complete independent explaination for it. I think it is not so far posible to give you know that all the laws, theories are derived by observing the phenomena therefor what we derive is only what we observe and in my point of view explaining something like that is not possible only by simply observing. And i agree on that we can understand thing better when we start understanding universe better.
sinyud
#14
Sep30-04, 08:48 PM
P: 23
So if in the reference frame of an object
Newtons first law is reformulated as
"An object not in motion does not start to spontaneously move"
Q: Why should an object not in motion, not start to move?
A: If the object did start to move, in which direction would it move?(<- this is a typical symetry argument)
BTW; I used the wrong idiom. It's supposed to be "beating a dead horse". But I think duck works fine.
mathfeel
#15
Oct1-04, 04:02 AM
P: 181
It is matter of personal opinion, I think, but I do not like stating the first law like
"An object not in motion does not start moving spontaneously" (1)
What about an object that IS in motion?
So, first law defines inertial frame. Perhaps we should even be more broad. Inertial frames are frames in which all laws of physics are equivalent. In this case the law:
dp/dt = F_external is true. As far as we know, all forces are interaction forces.
Imagine someone confined in an accelerating elevator and has no way to communicating with the outside. He would develope physics a lot differently. He found that objects in his world likes to go downward (toward the floor) and it is NOT due to ineraction with anything in his world. So he concludes that his world is anisotropic. Momentum and energy and such are not conserved. And his equation of motion would read: ma=F_interaction
+ F_floor.
(j/k: perhaps the guy can invent a theory of gravity with massive floor?)
So, I think a good definition of inertial frame is as follow:
Inertial Frame are frames in which the world is (or remains) homogeneous and isotropic. And it is precisely the isotropicity that would demand "An object at rest stays at rest" . And also accelerated frame then cannot be inertial frame by definition.
I don't think the object knows. In its frame, it's merely staying at rest. Since both frames (yours and the objects) are inertial, you can't prefer one frame over another (principle of relativity). Since your frame in inertial, object can't change its motion spontaneously, otherwise there is a preferred direction in your frame (the direction in which the object's motion changed without interaction).
I wonder if one can argue that perhaps the frame can still be inertial (hence isotropic), if an object that spontaneous changes its direction at one point implies an opposite change to another object somewhere else. I suppose homogeneity and isotropic-ness must be locally true as well...
another way of looking at this: you can certianly (classically anyway) plot x(t) in your frame. But it can only be of the form x(t)=x0+v0*t. There can be no acceleration or higher term, otherwise, you can conclude that the object is no in an inertial frame.
A comment on a point of the first post. Observation is the BEST verification that our models and laws of the world are actually correct. A model with well observational support is a theory, those without are hypothesis (string?). Charge quanization is a good example. People has done dilute hydrogen gas exp. for long time hoping to see some charge different between proton and electron. Within experimental error (~2x10^-20e), none has every been observed. On the other hand, I wonder what is (if there is at all) the best experiment data on this topic.
reilly
#16
Oct1-04, 12:49 PM
Sci Advisor
P: 1,082
There's a very simple way to look at all of this -- alluded to above by spacetime and mathfeel. The big one is the second law: if motion changes, then that change has a cause, which we call a force. Logic then says that no force no change. Nature agrees.
2nd Law. Definition? Postulate? People have argued about this for a long time; no resolution in sight. But, one thing we can all say about the 2nd Law: inspired.
No force, no change of motion. Pure Newton.
Regards,
Reilly Atkinson
Register to reply
Related Discussions
An object travels 14 cm in fourth second of motion.. Introductory Physics Homework 3
Motion of object (simple harmonic motion?) Introductory Physics Homework 3
Motion of an object attached to a spring Introductory Physics Homework 3
How to calculate the motion of this object? Classical Physics 14
Motion Of An Object Introductory Physics Homework 5
