What Is the Energy Transfer Mechanism in Waves and Sound?
The discussion focuses on the energy transfer mechanisms in waves and sound, addressing key concepts in physics such as simple harmonic motion, resonance, and wave interference. Participants confirmed that the period of a body in simple harmonic motion is independent of mass and that resonance allows for larger amplitudes with minimal energy input. Calculations for sound wavelength and frequency were discussed, with corrections provided for the speed of sound in air and temperature calculations based on sound pulse reflection.
  • Understanding of simple harmonic motion
  • Knowledge of wave interference patterns
  • Familiarity with the speed of sound calculations
  • Basic principles of resonance in physical systems
  • Study the derivation of the wave equation in different media
  • Learn about the Doppler effect and its applications in sound
  • Explore the principles of wave interference in more complex systems
  • Investigate the effects of temperature on sound speed in various environments
Students in physics, educators teaching wave mechanics, and professionals in acoustics or sound engineering will benefit from this discussion.
FestiveF
Ah...yet more questions...
These are some questions from my last assignment for the semester- I figured I would finish it all up before I head off the competitions for the next month. Again- I feel fairly confident with my answers- but I have had so much trouble in physics that I sometimes second-guess my work. Any help and/or comments would be great!
1) True or False. The period of a body in simple harmonic motion is independent of its mass.
True
2) True or False. At resonance, very little energy is required to obtain a larger amplitude.
True
*How exactly can you tell the difference (from drawings) as to whther or not they show complete of partial constructive/destructive interference? How do the direction of the forces make a difference?*
3) The air temperature is 10* C. What is the wavelength of a sound emitted by a tuning fork having a frequency of 440 Hz?
Using the equation V= (wavelegth)(frequency) as my base I first decided to find the frequency. To do this I used 331+.6(10) which is 337 m/s. I then substituted this into the equation and solved as follows: 337= w (440)
337/440= .765 m
is this correct?
4) The wavelength of a wave generated by an AM broadcasting station is 405 m. In KHz, what is the frequency of the wave?
Using 331 as the base velocity I used 331= 405 f
331/405=.817= 817 KHz
I think this sounds about right...
5) A sound pulse is directed from one airplane to another that is 1255 m away. A reflected pulse is detected 8 seconds after the original pulse was transmitted. What is the temperature of the air surrounding the plane?
V=d/t...d= 1255(2)=2510m
t= 8 s
V= 2510/8= 313.75
I then use 331 + .6x= 313.75 to find the temperature.
The resulting answer is -28.75 * C...is this right?
6) A Wave having a frequency of 2 Hz is generated along a spring. The wave has a wavelength of .457 m. What is the speed of the wave along this spring?
Here I am presuming "speed" to mean velocity. V= 2(.457)= .91 m/s
Does this sound correct?
7) /a sonar signal of frequency 1005 Hz has a wavelength of 145 cm in water, What is the velocity in water?
Again I use the equation V= Wavelength(F)
145 cm= 1.45 m so V= (1005)(1.45)
The answer is 1.46 x 10^3 m/s; correct?
Thank you so much for your time!
First of all, great job on your answers! You seem to have a good understanding of energy transfer of waves and sound. Let me provide some additional insights and clarifications to some of your answers and questions.
True. The period of a body in simple harmonic motion is determined by its frequency, which is independent of its mass.
True. At resonance, the frequency of the driving force matches the natural frequency of the system, resulting in a larger amplitude with very little energy input.
*How exactly can you tell the difference (from drawings) as to whether or not they show complete of partial constructive/destructive interference? How do the direction of the forces make a difference?*
In drawings, complete constructive interference is shown by a larger amplitude in the resulting wave, while partial constructive interference is shown by a smaller amplitude. Complete destructive interference is shown by a flat line or no wave at all, while partial destructive interference is shown by a smaller amplitude in the resulting wave. The direction of the forces determines the phase difference between the waves, which in turn affects the interference pattern.
Your method is correct, but there is a small error in your calculation. The speed of sound in air is actually 331.5 m/s at 0 *C, not 331 m/s. So the correct answer would be (331.5 + 0.6(10)) / 440 = 0.757 m.
Your method and answer are correct.
Your method is correct, but there is a small error in your calculation. The correct answer should be -28.75 *C, not -28.75 *F. Remember to use the correct units in your calculation.
6)
13K
