Math connections between QM and classical?
  • Context: Graduate
  • Thread starter Thread starter Farn
    Classical Qm
The discussion explores the connections and distinctions between quantum mechanics (QM) and classical mechanics, particularly in the context of analyzing the trajectory of a baseball. Participants examine whether QM can provide results comparable to classical mechanics for macroscopic objects and the implications of using QM in such scenarios.
  • Some participants question whether QM can be applied to classical problems, such as the trajectory of a baseball, suggesting that QM does not compute trajectories in the same way classical mechanics does.
  • Others propose that the Lagrangian function serves as a bridge between classical and quantum physics, emphasizing its role in both frameworks.
  • A participant argues that while QM can handle ordinary potentials, it struggles with gravitational effects, complicating its application to macroscopic objects.
  • Some participants assert that QM is fundamentally statistical and does not provide well-defined paths for objects, contrasting with the deterministic nature of classical mechanics.
  • There is a suggestion that while QM can theoretically be used for classical problems, it may be impractical, likening it to using an "A-bomb to kill a gnat."
  • A later reply highlights that while QM encompasses all possible paths of an object, it ultimately leads to classical behavior in certain limits, yet does not allow for precise predictions of position and velocity at specific moments.
Participants generally disagree on the applicability of QM to classical problems, with some asserting that QM cannot compute trajectories while others suggest it can be used in principle. The discussion remains unresolved regarding the extent to which QM can be applied to macroscopic scenarios.
Limitations include the dependence on definitions of trajectory and the nature of quantum behavior, as well as the unresolved implications of applying QM to gravitational contexts.
Farn
If you were faced with an easy kinematics problem (trajectory of a baseball) could you use QM instead of classical mec. to get a result that’s just as accurate and useful?
I don’t know how well the maths of QM simplify, but if you were to set up the above problem in QM would you end up being able to essentially simplify the math down to the well known classical equations that describe the balls motion?
The only point of these questions is to help me to realize the connections between these two seemingly very different ways of looking at things (QM and classical). I feel there must be some connection because at one scale they should both give the same exact results.
The Lagrangian function is the most general connection between classical and quantum physics. It involves the action integral instead of the classical force concept, which is a derivative of the energy. Derivative is meant in the calculus sense of the word.
A good description is the "Special Lecture" in Feynman's Lectures.
Tajectory is not a quantum concept, no you cannot compute the trajectory of a baseball in QM.
You could compute the probability that the ball would tunnel through the bat, but not where the ball would land if the ball did not tunnel.
Hmm, I guess I was mislead at some point. I was under the idea that QM was a theory that came about to fix the problems that classical had at the atomic level, but that it could also be used in place of all classical equations... sort of like an all-in-one tool. If this is not the case, than QMs usefulness is limited to the particle world, just as classical is limited to more massive objects. This a correct assumption?
Anyway, so your saying there is no way to get trajectory or the like out of QM?
That is correct, QM is statistical in nature it simply does not deal with trajectrories. It deals with atomic interactions, that is the quantum world after all.
You can use the classical Lagrangian to solve the baseball problem, and it has the most direct connection to Quantum Mechanics. Solving the baseball problem with QM would be like using an A-bomb to kill a gnat, but you could do it in principle.
Not to make too big a deal out of this, but Tyger, does this mean you disagree with Integrals reply?
You couldn't find the trajectory of baseball as it involves gravity, something which quantum field theory explains poorly. You could consider the wave function of a baseball, but you would expect ot to display classical behaviour and considering the baseball as a collection of particles would lead to decoherence.
QM can handle ordinary potentials, though, can't it? If so then one can impose the typical U=mgh potential to approximate the gravitational field on the Earth's surface.
While the Lagrangian is used in QM it is also a very handy tool to handle classical problems. Use of the Lagrangain does not inherently equal QM. It is simply a way of solving dynamic problems using energy considerations.
I will stick by my initial statement trajectrories are not a part of QM.
I would tend to agree with Integral.
Classicaly, the trajectory of an object is simply the path that it follows, or more precisely the position of the object as a function of time. If we know the initial velocity of the ball and the angle it makes with the ground, we can easily calculate the trajectory -- this allows us to predict with certainty where the ball will be at any instant in time after it was hit.
If we extend the idea of the path of the ball to QM, then the ball does not travel a single, well-defined path -- instead, it travels all paths simultaneously, as described by its wavefunction. Now, some of these paths would be more preferable than others (they have higher probability, again calculated from the wavefunction). And, the most preferred path (highest probability) would correspond to our classical trajectory. However, since all paths are included, it is impossible for us to know where an object will be and how fast it will be going at any specific moment in time, contrary to the classical picture.
Ultimately, it just doesn't make sense to me to try and apply a statistical theory based on probabilities and expectation values to a macroscopic object with well-defined properties.
14K
  • · Replies 89 ·
  • · Replies 41 ·
  • · Replies 120 ·
16K
