How to convert DC to AC for auto sensor?
The discussion focuses on converting 12V DC to AC for the purpose of measuring fluid permittivity in an automotive application. Participants explore the requirements for powering a sensor that operates as a capacitance meter for continuous monitoring of automotive fluids.
  • Exploratory, Technical explanation, Homework-related
  • One participant seeks assistance in converting 12V DC to AC for a sensor application.
  • Another participant suggests that the goal is to power the sensor with 12V DC, noting that the sensor itself likely contains an oscillator circuit to generate the necessary AC signal.
  • A participant confirms the intention to create a capacitance meter for monitoring auto fluids and references a specific product from SparkFun as a potential solution.
  • Another response agrees that the referenced kit appears suitable and also operates on 12V DC.
Participants generally agree on the need for an oscillator circuit within the sensor to generate AC, and there is a consensus that the referenced product may be appropriate for the intended application. However, the discussion does not resolve all technical details regarding the conversion process.
The discussion does not address specific technical methods for creating the oscillator circuit or any potential limitations of the suggested product.
Individuals interested in automotive sensor applications, capacitance measurement, or those looking to understand the integration of DC power with AC signal generation may find this discussion relevant.
jrstaples1
Can anyone help me convert 12v DC to AC for the purpose of measuring fluid permittivity in real time, automotive application? I'm new to PF and limited experience, so all the help/details you can provide are greatly appreciated.
Welcome to the PF.
I moved your post from the end of another thread to here, to start your own thread with the question.
It's not so much that you want to convert DC to AC, it's that you want to power your sensor with 12Vdc. The sensor will contain an oscillator circuit of some kind, and that's the source of your AC signal. There are lots of ways to make oscillator circuits. You basically want to make a capacitance meter? Is that right?
Yes exactly, I want a capacitance meter for continuous monitoring of auto fluids. I came across this,
http://www.sparkfun.com/products/9485
I wonder if this is not exactly what I'm looking for.
That looks like a great kit to use, and it runs off of 12Vdc too.
  • · Replies 20 ·
11K
  • · Replies 68 ·
16K
