What causes a mutation in an enzyme that changes Tyrosine to Alanine?
  • Thread starter Thread starter Sarup
    Mitochondria
The discussion centers on a mutation in mitochondrial DNA (mDNA) that alters the enzyme responsible for converting the amino acid Tyrosine to Alanine. This mutation is likely a point mutation affecting the codon sequence for Tyrosine, resulting in the incorporation of Alanine instead. Additionally, the conversation highlights the role of mitochondria in energy production through respiration and lactate fermentation, particularly when mitochondrial function is compromised, leading to increased lactate levels in affected individuals.
  • Understanding of mitochondrial DNA (mDNA) and its role in protein coding
  • Knowledge of amino acid codons and their translation
  • Familiarity with metabolic pathways, particularly respiration and lactate fermentation
  • Basic genetics, specifically mutations and their effects on protein synthesis
  • Research the specific codon sequences for Tyrosine and Alanine to identify the mutation type
  • Study the mechanisms of mitochondrial DNA mutations and their impact on cellular function
  • Explore the process of lactate fermentation and its role in energy production under anaerobic conditions
  • Investigate diseases associated with mitochondrial dysfunction and their symptoms
Biochemists, geneticists, medical researchers, and students studying mitochondrial biology and metabolic disorders will benefit from this discussion.
Sarup
Ok, so we all know that Mitochdiria contains its own DNA, mDNA, which codes for 13 of the approx. 80 needed proteins. We all know, that mutations in the mDNA almost always cause diseases in the central-nervous-system, heart and muscles.
Now, I've been asked the following question: One of theese mDNA mutations causes a fault in an enzyme, where the aminoacid Tyrosin has been changed to Alanin. Now, What kind of mutation could cause the changing of Tyrosin to Alanin in the enzyme?
I'm from denmark, so I'm not sure that I've translated the names of the two aminoacids correctly, but it shouldn't be a problem.
And on a sidenote: why do you often see an encreased level of laktate in the victims of this disease?
*yay - my first but definitely not last post here*
Biology news on Phys.org
First you should look at a table that show the translation of nucleic acid codon to amino acid. What is the difference between the base pair in the tyrosine and alanine codons? This should give the type of mutation. Give the answer I will confirm if it is right or wrong but you have to show some of thinking.
For the sidenote, What is is the role of mitochondria and if the mitchondrial system does not work what are metabolism pathway that are used instead? This should lead you the answer.
Thanks a lot for the hints.
The first you told me to do i can't do now, because i have to go to school to get the book with the table.
The other thing though, i can i right here. I thought of the solution that you pointed out, but I didn't think the answer was that simple.
The role of the mitochondria is of course to provide energy to the body. They do this via a process called respiration. Normally we do this by turning oxygen and glucosis into water, ATP and CO2, but if the mitochondrial system doesn't work, then the body finds another way out:lactate fermentation(at least i think that's the english word for it). This process does not produce a lot of energy, but it does so very fast. When the mitochondrial system fails, lactate fermentation takes over and produces energy (2 ATP) and the bi-product lactate. Hence the higher levels of lactic acid (or lactate) in the sick persons, than in the healthy ones.
I'll return with the first question tomorrow.
