Circular Motion Problem: Calculating Acceleration for a Re-entry Maneuver
The discussion centers on calculating the total acceleration of a spacecraft during a re-entry maneuver. The spacecraft travels at a speed of 7360 m/s in a circular orbit with a radius of 7.34 x 106 m, resulting in a radial acceleration of 7.38 m/s2. When the engines fire, providing an opposing acceleration of 6.60 m/s2, the total acceleration must be calculated as a vector sum, leading to a magnitude of 0.78 m/s2 in the direction opposite to the spacecraft's velocity.
  • Understanding of vector addition in physics
  • Knowledge of centripetal acceleration formula (a = v2/r)
  • Familiarity with the concepts of radial and tangential acceleration
  • Basic principles of circular motion
  • Study vector addition techniques in physics
  • Learn about centripetal acceleration and its applications
  • Explore the effects of thrust on spacecraft trajectories
  • Investigate the principles of re-entry dynamics for spacecraft
Aerospace engineers, physics students, and anyone involved in spacecraft dynamics and orbital mechanics will benefit from this discussion.
pulau_tiga
Hi!
I'm working on a circular motion problem, and I'm not sure on how to go about doing it.
The question:
A spacecraft moves in a circular orbit with a speed of 7360 m/s with a period of 6270. seconds. The radius of the spacecraft 's orbit is 7.34 x 10^6 m and the radial acceleration of the satellite is 7.38 m/s^2. In order to begin its re-entry, the spacecraft engines are fired to provide an acceleration of 6.60 m/s^2 in a direction opposite to its velocity. What is the magnitude of the spacecraft 's total acceleration just after the engines begin to fire?
My first try at the question involved simply adding a negative 6.60 m/s^2 to the radial acceleration (7.38 m/s^2). I came up with 0.780 m/s^2 for the spacecraft 's total acceleration which is wrong.
If anyone could point be in the right direction on how to go about this problem it would be greatly appreciated.
Thanks.
The two accelerations you are trying to add are vectors. They are perpendicular to each other. (One is radial, the other tangential.) Add them as vectors.
Hi there!
I can definitely help you with this circular motion problem. First, it's important to understand that acceleration is a vector quantity, meaning it has both magnitude and direction. In the case of circular motion, the acceleration is constantly changing direction, which is why we use the term "radial acceleration".
To solve this problem, we need to use the equation for centripetal acceleration, which is given by a = v^2/r, where v is the linear velocity and r is the radius. In this case, we are given the velocity (7360 m/s) and the radius (7.34 x 10^6 m), so we can plug these values into the equation and solve for the radial acceleration, which is 7.38 m/s^2.
Since the spacecraft is now firing its engines in the opposite direction of its velocity, we need to subtract the acceleration provided by the engines (6.60 m/s^2) from the radial acceleration. This will give us the total acceleration, which is 0.78 m/s^2 in the opposite direction of the spacecraft's velocity.
Remember, acceleration is a vector quantity, so we need to include the direction in our answer. The magnitude (or size) of the total acceleration is 0.78 m/s^2, but the direction is opposite to the spacecraft's velocity.
I hope this helps! Let me know if you have any other questions. Good luck with your problem!
  • · Replies 41 ·
