New Reply
How do I get water vapor fraction and pressure?
Share Thread
Dec1-10, 09:54 PM   #1
Hi Guys,
I'm building a numerical Matlab simulation of a thermochemical heat storage device (using zeolites), and need to update the state of water vapor in the device at every time step. My question is, if I have an empty space with water in it, with temperature, pressure, density, etc. all known, how can I get the vapor fraction and pressure of that same boiler after removing x kilograms of water from it (and not replacing it with anything)?
The temperature range is about 50°C - 500°C and pressure should be between 1-20atm.
Ideally, I would love to get an empirical function for Vapor fraction of water - or at least a comprehensive table I can index in my simulation, so far I haven't been able to find anything myself.
Help would be greatly appreciated!
PhysOrg.com engineering news on PhysOrg.com
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
>> Faster, more precise airstrikes within reach
>> How smart technology could change public transit
Dec8-10, 07:56 PM   #2
Quote by jason_85 View Post
Hi Guys,
I dont realy know the answer but maybe I can kind of give you some hints.
pressuve= force/area
force= Newton
if you are going to multuply you kilograms by 9.81m/s2(squered)= gravity, you are going to get newtons.
if you are going to get rid of watter you are going to increase steam space (area).
so maybe using this somehow u can determin pressure differential.
Forse= Newton= kg x gravity.
from there you can maybe determin how mutch steam you got. that all will be under constant temperature.
I just started 4th class power engineering so I am not realy sure what I am talking about.
when I will finish first year I will help out more.
Dec28-10, 01:25 AM   #3
Code:
by using steam table you can know the pressure on water and its corresponding temperature and amount of vapor generated.
you can find steam table on most thermodydamic books.
New Reply
Similar Threads for: How do I get water vapor fraction and pressure?
Thread Forum Replies
Estimating Vapor Pressure and Vapor Mole Fraction Biology, Chemistry & Other Homework 0
Vapor Pressure of Water Biology, Chemistry & Other Homework 2
Increasing vapor pressure in water Chemistry 1
Calculating mass of vapor from vapor pressure Biology, Chemistry & Other Homework 4
Vapor pressure of Water calculation Biology, Chemistry & Other Homework 3
