Showing a matrix is diagonalizable and calculating powers
  • Thread starter Thread starter Boom101
    Matrix
The discussion revolves around the diagonalizability of a given 3x3 matrix A and the calculation of its powers A^2 and A^3. Participants are exploring the process of finding eigenvalues and eigenvectors to construct the matrices P and D.
  • Participants discuss finding eigenvalues (2, 3, and -1) and the corresponding eigenvectors. There is confusion regarding the selection of eigenvectors to form the matrix P, with attempts to verify eigenvector correctness through matrix multiplication.
Some participants have identified potential errors in their eigenvector calculations and are questioning the validity of their results. There is ongoing exploration of how to correctly construct the diagonal matrix D and the invertible matrix P from the eigenvalues and eigenvectors.
Participants note that there may be a misunderstanding regarding the number of eigenvectors associated with each eigenvalue, as well as the requirement for the eigenvalues to match the order of the columns in matrix P.
Boom101
Consider the matrix A =
| 7 16 8|
|-1 0 -1|
|-2 -10 -3|
Show that A is diagonalizable. Find an invertible matrix P and diagonal matrix D and use the obtained result in order to calculate A^2 and A^3
Determinant equation I suppose.
D is the diagonal matrix, like identity matrix but constructed from the eigenvalues. The order of the eigenvalues must match the columns in P precisely.
Alright well I've done a huge chunk of this problem already. I found the eigenvalues to be 2, 3, and -1. Then I find my eigenvectors, and I come up with 2 per eigenvalue.
For λ = 2 I get [-2 1 0] and [-1 0 1]
For λ = 3 I get [-3 1 0] and [-1 0 1]
For λ = 1 I get [1 1 0] and [0 1 1]
So now I have to construct P from these. This is where I'm confused. Which eigenvectors from which eigenvalues do I use? I've tried several combinations to make AP = PD and I just can't do it. Everything comes out wrong. I suppose there's just something I'm not understanding. Please help.
| 7 16 8|
|-1 0 -1|
|-2 -10 -3|
Since you have a 3 x 3 matrix and found three eigenvalues, you should not have two eigenvectors per eigenvalue, so you have definitely done something wrong.
Once you have that squared away, it's a good idea to check your eigenvalues and eigenvectors. If λ is an eigenvalue, and x is an eigenvector associated with that eigenvalue, it should be true that Ax = λx. If not, you did something wrong.
If you end up with three eigenvectors, form a matrix P with those eigenvectors as columns. It doesn't matter what order you put them in, but the order will determine which eigenvalue goes where in your diagonal matrix D.
| 7 16 8|
|-1 0 -1|
|-2 -10 -3|
[tex]\begin{bmatrix} 7 & 16 & 8 \\ -1 & 0 & -1 \\-2 & -10 & -3\end{bmatrix}\begin{bmatrix}-2 \\ 1 \\ 0\end{bmatrix}= \begin{bmatrix}2 \\ 2 \\ -6\end{bmatrix}[/tex]
so this is NOT an eigenvector.
[tex]\begin{bmatrix} 7 & 16 & 8 \\ -1 & 0 & -1 \\-2 & -10 & -3\end{bmatrix}\begin{bmatrix}-1 \\ 0 \\ 1\end{bmatrix}= \begin{bmatrix}1 \\ 0 \\ -1\end{bmatrix}[/tex]
so this is and eigenvector but with eigenvalue -1, not 2.
[tex]\begin{bmatrix} 7 & 16 & 8 \\ -1 & 0 & -1 \\-2 & -10 & -3\end{bmatrix}\begin{bmatrix}-3 \\ 1 \\ 0\end{bmatrix}= \begin{bmatrix}-5 \\ 3 \\ -4\end{bmatrix}[/tex]
so this is not an eigenvector.
[-1 0 1] is the same vector as in the second case. It is an eigenvector with eigenvalue -1, not 3.
[tex]\begin{bmatrix} 7 & 16 & 8 \\ -1 & 0 & -1 \\-2 & -10 & -3\end{bmatrix}\begin{bmatrix}1 \\ 1 \\ 0\end{bmatrix}= \begin{bmatrix}23 \\ -1 \\ -12\end{bmatrix}[/tex]
[tex]\begin{bmatrix} 7 & 16 & 8 \\ -1 & 0 & -1 \\-2 & -10 & -3\end{bmatrix}\begin{bmatrix}0 \\ 1 \\ 1\end{bmatrix}= \begin{bmatrix}24 \\ -1 \\ -13\end{bmatrix}[/tex]
I did the work again and found my mistake. The eigenvectors are
[0 -1 2], [2 -1 1], [-1 0 1]
