What Are KPOINT Grids and Their Importance in Surface Calculations?
  • Context: Graduate
  • Thread starter Thread starter discoduck
The discussion revolves around the concept of KPOINT grids in the context of surface calculations in solid state physics. Participants explore the significance of different grid configurations in k-space and their implications for numerical integration over the Brillouin zone.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant seeks clarification on KPOINT grids and the differences between nxnxn and nxnx1 grids, particularly their importance in calculations.
  • Another participant explains that KPOINT grids are used to approximate integrals over the Brillouin zone, comparing this process to numerical integration techniques like the trapezoid rule.
  • It is noted that an nxnx1 grid represents a single plane of k-points, suitable for strongly 2-dimensional systems.
  • Some participants suggest that using an even grid can help leverage symmetries to enhance computational efficiency.
  • A question is raised about the appropriate grid for surface calculations involving bulk structures adjacent to a vacuum.
  • A later reply indicates that for surface calculations, only one k-point should be used in the direction of the surface normal, leading to a grid configuration of NxNx1.
Participants generally agree on the use of KPOINT grids for numerical integration in solid state physics, but specific configurations and their implications for surface calculations remain a topic of discussion.
There are limitations regarding the assumptions made about the dimensionality of systems and the specific conditions under which different grid configurations are optimal. The discussion does not resolve the best practices for all scenarios.
discoduck
Could somebody explain to me the concepts of KPOINT grids please. I know what k-space/reciprocal space is
What is the difference between an nxnxn grid and a nxnx1 grid for example, and why is it important to use even or odd grids for specific calculations
The calculation of many quantities in solid state physics require some sort of integral over the Brillouin zone. When doing numerical calculations, these integrals cannot be carried out analytically, so you approximate the integral by using a grid in k-space. This is exactly the same as using, say, the trapezoid rule to integrate a function in one dimension, only we generalize it to a function of two or three dimensions.
An nxnx1 grid only is a single plane of k-points. You would only use this in a case where you have a system which is strongly 2-dimensional (examples might be cuprates and systems like ZrNCl). An even grid is usually best to take advantage of symmetries to speed the computation.
What type of grid would I need to use for a surface calculation i.e. bulk structure next to a vacuum?
For a surface calculation, you would only use one k=point in the direction of the surface normal. So if your surface is in the x-y plane, then your grid would be NxNx1
  • · Replies 46 ·
  • · Replies 36 ·
  • · Replies 29 ·
  • · Replies 48 ·
