Calculating r(dot): Dynamics Time Derivative of Radius
  • Thread starter Thread starter Spectre5
The discussion focuses on calculating the time derivative of the radius, denoted as r(dot), in dynamics. The formula derived is \dot{r} = R\dot{\theta}\cos(\frac{\theta}{2}), which involves applying the chain rule for differentiation. A participant expressed confusion about differentiating \sin(\frac{\theta}{2}) with respect to time, mistakenly considering theta as a constant. The clarification provided emphasizes that theta can change over time, necessitating its differentiation in accordance with the chain rule.
  • Understanding of calculus, specifically differentiation and the chain rule.
  • Familiarity with trigonometric functions and their derivatives.
  • Basic knowledge of dynamics and kinematics concepts.
  • Ability to interpret mathematical notation and expressions in LaTeX format.
  • Study the application of the chain rule in calculus.
  • Learn about the relationship between angular velocity and linear velocity in dynamics.
  • Explore the differentiation of trigonometric functions in various contexts.
  • Investigate the implications of time-varying parameters in physical equations.
Students and professionals in physics, particularly those studying dynamics, as well as anyone looking to deepen their understanding of calculus and its applications in motion analysis.
Spectre5
This is from Dynamics where r(dot) is the time derivative of the radius.
[tex]\dot{r} = \frac{d(r)}{dt}[/tex]
[tex]\dot{r} = \frac{d}{dt}(2R\sin(\frac{\theta}{2})) \ \ \ \ \ \mbox{note: this is given}[/tex]
[tex]\dot{r} = 2R\frac{d}{dt}(\sin(\frac{\theta}{2}))[/tex]
[tex]\dot{r} = 2R\cos(\frac{\theta}{2})\frac{d}{dt}(\frac{\theta}{2})[/tex]
[tex]\dot{r} = 2R\cos(\frac{\theta}{2})(\frac{1}{2})\dot{\theta}[/tex]
[tex]\dot{r} = R\dot{\theta}\cos(\frac{\theta}{2})[/tex]
I am confused on one part...in this step:
Why do you have to differentiate the sin(theta/2)?? Since you are differentiating with respect to t, don't you count the theta as a constant and therefore not differentiate it? But my profressor said that the above is correct.
PS: Sorry for my bad tex.
Hello Spectre5
The derivative of a function [tex]f(\phi)[/tex] with respect to a variable it does not explicitly depend on is given by the chain rule,
[tex]\frac{df}{du} = \frac{df}{d\phi}\frac{d\phi}{du} = f'(\phi)\frac{d\phi}{du}[/tex]
In your case therefore
[tex]\dot{r} = 2R\frac{d}{dt}(\sin(\frac{\theta}{2})) = 2R\cos(\frac{\theta}{2})\frac{d}{dt}(\frac{\theta}{2})[/tex]
You must understand that you are differentiating [tex]\dot{r}[/tex] with respect to time so you must first differentiate with respect to theta and then multiply by the derivative of theta with respect to time in accordance with the chain rule for total derivatives as shown above.
You are probably thinking that when you differentiate with respect to time, theta will remain constant (with time) but that is not so since theta too can (and in a general situation, will) change with time. Unless you are explicitly told that [tex]\dot{\theta} = 0[/tex] you cannot say so.
Hope that helps...
Cheers
Vivek
yea, I was not paying attention to the fact that it uses the chain rule :-/
Thanks for the help, I understand it now.
  • · Replies 24 ·
