Solving Glancing Collision: 50Kg Object Velocity Before Collision
  • Thread starter Thread starter punjabi_monster
The problem involves a glancing collision between a moving object and a stationary object, focusing on determining the initial velocity of the moving object based on the conservation of momentum principles. The subject area pertains to mechanics, specifically the analysis of collisions and momentum conservation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of conservation of momentum, with one participant questioning the original poster's understanding of the problem and encouraging them to consider the implications of linear momentum in a closed system. Another participant suggests resolving the velocities into components to set up equations for momentum conservation.
The discussion is ongoing, with participants providing guidance on how to approach the problem through vector resolution and momentum equations. There is no explicit consensus yet, as participants are exploring different aspects of the problem.
There is an emphasis on the original poster needing to provide their own solution attempt before seeking help, which reflects the forum's guidelines for collaborative learning. The original poster has expressed uncertainty about how to proceed after setting up the momentum equations.
punjabi_monster
Hi, i was wondering if someone could please help me on this question:
A 50.0 Kg Object is moving east at an unknown velocity when it collides with a 60.0 Kg stationary object. After the collsion, the 50.0 Kg object is traveling at a velocity of 6.0 m/s 50.0° N of E, and the 60.0 Kg object is traveling at a velocity of 6.3 m/s 38° S of E.
What was the velocity of the 50.0 Kg object before the collision?
Can someone please explain to me how this question is solved. Thank-you.
First of all, you are supposed to post your own solution before you ask for help.
What is your specific problem with this question? Do you know that the change in linear momentum of a system on which no external force acts, is zero? Can you think of applying this principle to this problem?
Sorry i didnt post my solution earlier, but i did not no what to do after this:
a=1st object
b=2nd Object
Ma=50.0 Kg
Va=?
Mb=60.0 Kg
Vb=0 m/s
Va'= 6.0 m/s 50.0° N or E
Vb'=6.3 m/s 38° S of E
Pa + Pb = Pa' + Pb'
Pa= Pa' + Pb'
Now from here what do you do in order to solve for Pb'?
Hi
You have to resolve the velocities in mutually perpendicular directions (say x and y) and write either one vector equation for the conservation of linear momentum or (which is the same thing really) two separate equations correspdonding to momenta along the two chosen axes. That will give you the equations to solve for the velocity components.
Like this
[tex]P_{A,x} + P_{B,x} = P'_{A,x} + P'_{B,x}[/tex]
[tex]P_{A,y} + P_{B,y} = P'_{A,y} + P'_{B,y}[/tex]
Cheers
Vivek
