Some help understanding the metric tensor
In summary: Can someone please clarify this for me? In summary, I am trying to understand the concept of a metric tensor, and am having difficulty understanding how contravariant vectors are related to basis vectors.
mysearch
Hi,
I am in the process of trying to teach myself GR Maths, at the A101 level, and have been working through the idea of tensors as scalars, vectors and matrices, i.e. rank-0, 1 and 2 tensors. Think I have also acquired some idea of the concept of contravariance and covariance, which then seems to define the superscripting and subscripting on the tensor. Have also worked through the basic coordinate transforms associated with these concepts and have now arrived at the idea of a metric tensor, which seems pretty important in terms of GR, so wanted to try to clarify some issues before plodding on.
[1] [tex]ds^2 = g_{\alpha \beta} da^\alpha db^\beta [/tex]
I am using (da) and (db), not the usual (dx), to identify what I am assuming to be differential displacement vectors because I want to used (x), in the description below, to identify the unit vectors, which I believe in this context are called the basis vectors. As such, I am also assuming that (da) and (db) can be related to (a) and (b) in [2] below, which might be a mistake. Anyway, [1] above appears, to me, to be a generic description of any metric, e.g. 2D flat space through to 4D curved spacetime. For fairly obvious reasons I would like to start by trying to interpret this equation in terms of the simplest form, i.e. normal 2D flat space, as described in terms of Pythagoras’ theorem and Cartesian coordinates:
[2] [tex]s^2 = a^2 + b^2[/tex]
As indicated, the superscripted terms in [1] have been assumed to be contravariant displacement vectors [da, db] or rank-1 tensors, while (g) is an n-dimensional array or rank-2 tensor. In the 2D example associated with [2], (g) is a 2D array:
[3] [tex]g= \left(\begin{array}{cc}1&0\\0&1\end{array}\right) [/tex]
I will defer my questions about the nature of (g) to another time, as this post will probably end up being too detailed and too long to solicit any response. Anyway, if I expand [1] in terms of the multiplication of 2 contravariant 2D vectors, where the basis vectors are [x1, x2], I appear to end up with:
[4] [tex] a^\alpha b^\beta = a^1 b^1 x^1 x^1 + a^1 b^2 x^1 x^2 + a^2 b^1 x^2 x^1 + a^2 b^2 x^2 x^2 [/tex]
Now it would seem that [4] can be simplified by multiplying through by [3], which seems correct for the 2D flat space metric in [2]:
[5] [tex]s^2 = g_{\alpha \beta} a^\alpha b^\beta = a^1 b^1 + a^2 b^2 [/tex]
At this point, I wanted to try to anchor the notation in [5] to an actual geometric example, which would be a specific solution of [2], i.e. [a=3] and [b=4] giving [s=5]. My assumption was that the magnitude of (a1) is defined with respect to the basis axis (x1). Therefore, given that (a,b) in [2] actually align to the basis vector (x1, x2), I assumed the following values: (a1=3, a2=0, b1=0, b2=4). However, these values do not appear to prove any obvious equivalence between [2] and [5], therefore I must assume that I have misunderstood some fundamental concept and would appreciate any help on offer. Thanks
[tex]
[/tex]
This does not make sense to me. If you are using a chart with coordinate names say (t,x,y,z) then conventionally dx0 is dt, dx1 is dx, dx2 is dy and so on.
The metric is used to raise and lower tensor indexes, so vector [itex]t_\mu=g_{\rho\mu}t^\rho[/itex], for instance.
The displacement equation for 2D Euclidean space is
[tex]
ds^2 = g_{\alpha \beta} dx^\alpha dx^\beta
[/tex]
where [itex]\alpha[/itex] and [itex]\beta[/itex] range over 1,2 say ( or 0,1) and g is given by your equation (3).
So if we have two points, (2,3) and (6,4), the distance between them is
[tex]
ds^2= g_{11}dx^1dx^1 + g_{22}dx^2dx^2
[/tex]
which evaluates to
[tex]
(2-6)^2+(3-4)^2
[/tex]
Mentz114 said:
This does not make sense to me. If you are using a chart with coordinate names say (t,x,y,z) then conventionally dx0 is dt, dx1 is dx, dx2 is dy and so on. The metric is used to raise and lower tensor indexes, so vector [itex]t_\mu=g_{\rho\mu}t^\rho[/itex], for instance. The displacement equation for 2D Euclidean space is
(A) [tex]ds^2 = g_{\alpha \beta} dx^\alpha dx^\beta [/tex]
where [itex]\alpha[/itex] and [itex]\beta[/itex] range over 1,2 say ( or 0,1) and g is given by your equation (3). So if we have two points, (2,3) and (6,4), the distance between them is
(B) [tex]ds^2= g_{11}dx^1dx^1 + g_{22}dx^2dx^2[/tex]
which evaluates to
(C) [tex](2-6)^2+(3-4)^2[/tex]
Hi,
I have inserted labels (A), (B) and (C) into the quote above purely for reference and please bear in mind that much of this does make sense to me either, which is why I am asking questions to rectify the misunderstanding. So, clearly, there is an implication that my replacement of [dx] in [A] with [da] and [db] is nonsensical. This may well be the case, I had simply assumed that [dx] was representative of a differential displacement vector that could be renamed to better align its application to 2D Euclidean space:
[1] [tex]s^2 = a^2 + b^2[/tex]
Therefore, could you or anybody elaborate a little further on the scope/interpretation of dx, which would then explain the difference in implication such that [2] below is inappropriate and not representative of (A):
[2] [tex] ds^2 = g_{\alpha \beta} da^\alpha db^\beta [/tex]
While I understand the inference of (C) being a solution of the Pythagoras form in [1] above, it is unclear as to how you substituted your values in (C) into (B), i.e. is there a specific expansion of [tex]dx^\alpha dx^\beta [/tex] along the lines:
Anyway, appreciated the helpful insights. Thanks
...it is unclear as to how you substituted your values in (C) into (B),
dx1=2-6
dx2=3-4
g11=1
g22=1
[tex]
ds^2= g_{11}dx^1dx^1 + g_{22}dx^2dx^2=1 (2-6)(2-6)+ 1 (3-4)(3-4)
[/tex]
This,
[tex]
[/tex]
The term on the left looks like the product of 2 contravariant vectors. On the right is something else which I can't identify.
Mentz114 said:
[tex]
[/tex]
[tex]
[/tex]
Again, much appreciate the help. I think one of the things I lost sight of is that the following equation represents a summation (?), i.e.
[tex] ds^2 = g_{\alpha \beta} dx^\alpha dx^\beta [/tex]
[tex] (ds)^2 = (dx)^2 + (dy)^2= \sum (dx^i)^2 [/tex] where i=1..2
This then seem to explain your equation:
[tex] ds^2= g_{11}dx^1dx^1 + g_{22}dx^2dx^2=1 (2-6)(2-6)+ 1 (3-4)(3-4) [/tex]
The second equation in the quote above, where you didn’t understand the term on the right was taken from an articlehttp://www.tommangan.us/Tensors.pdf" on page 8, which seemed to imply it was the multiplication of 2 rank-1 tensors. Obviously, I will need to read this more carefully as it wasn't 'gentle' enough. Thanks again.
Yes, there is implied summation.
The thing on the left is a product of 2 rank-1 tensors ( i.e. vectors), and the result will be a rank-2 tensor, whose components are just the products of the components of the two multiplicands.
Keep going, you are moving forward.
1. What is the metric tensor?
The metric tensor is a mathematical object used to describe the geometric properties of a space. It provides a way to measure distances and angles in that space.
2. Why is the metric tensor important?
The metric tensor is important because it allows us to define a notion of distance and angle in any space, regardless of its curvature. It is a fundamental tool in the study of geometry and plays a crucial role in many areas of physics, such as general relativity.
3. How is the metric tensor different from other tensors?
The metric tensor is a special type of tensor known as a second-order tensor, meaning it has two indices. It differs from other tensors in that it is used to define the geometry of a space, while other tensors may represent physical quantities such as force or energy.
4. How is the metric tensor calculated?
The metric tensor is calculated using the inner product, or dot product, of basis vectors in a given space. This results in a matrix of components that describe the relationships between these basis vectors. In a flat, Euclidean space, the metric tensor is simply the identity matrix.
5. Can the metric tensor change in different coordinate systems?
Yes, the metric tensor can change in different coordinate systems. This is because the basis vectors used to calculate the metric tensor may be different in each coordinate system, resulting in different components. However, the overall geometric properties of the space remain the same regardless of the coordinate system used.
