Can a Bluetooth Module's Range be Configured and What are the Options?
The discussion revolves around the configurability of Bluetooth module range, specifically whether it is possible to adjust the range of a Bluetooth module from a longer distance to a very short one, such as from 5 meters to 1 foot or less. Participants explore potential methods and alternatives, including the use of Near Field Communication (NFC) technology.
  • One participant inquires about the possibility of configuring the range of a Bluetooth module, specifically the BTSerial1 module, and seeks recommendations for alternatives that may be less expensive or better.
  • Another participant suggests that creating a very short-range Bluetooth device might involve limiting the transmit power, incorporating a distance sensor to prevent pairing beyond a certain distance, or using a focused antenna to restrict signal reception.
  • A participant expresses confusion regarding Near Field Communication (NFC) and asks for clarification on whether it is an external device or something that can be attached to Bluetooth.
  • There is a mention that NFC is a new technology similar to RFID, but it is unclear how many devices currently incorporate it.
  • One participant queries about the market availability and pricing of NFC devices.
The discussion contains multiple competing views regarding the feasibility of configuring Bluetooth range and the relationship between Bluetooth and NFC technology. No consensus is reached on the best approach or the availability of NFC devices.
Participants express uncertainty about the technical feasibility of suggested methods for limiting Bluetooth range and the specifics of NFC technology, including its integration with Bluetooth modules.
This discussion may be useful for individuals interested in Bluetooth technology, NFC applications, and those exploring options for short-range wireless communication solutions.
jednified
Hi guys. I am new here. Is there a bluetooth module which you can configure the range of the the module? For example from a 5 meter range to about 1 ft or less... Currently planning on using BTSerial1 Bluetooth module. Any idea of a less expensive and better bluetooth module?
Im new to this stuff so please bear with me.
I think what you're looking to do is create a http://en.wikipedia.org/wiki/Near_Field_Communication" device using bluetooth. Some ways to do this I would think:
  • Limit the transmit power of the device to some very small value useful only for a couple of inches (not sure if this is possible without having a standard receiver sensitivity).
  • Incorporate some sort of distance sensor in addition to the bluetooth tranceiver which prevents pairing beyong some pre-set distance (would work)
  • Incorporate a highly focused antenna to only allow signal reception in a small target volume (not sure if this is possible, I'm not an RF antenna engineer).
Thank you sir.
I tried researching Near Field Communication device and I got confused with the terms. Is there any NFC device that you know of? Is it a device that would be attached to the bluetooth or is it something external?
Just click on the wikipedia link! Near-Field Communication is a new technology, I don't think many (if any) devices have it incorporated yet, but it's basically just RFID.
Is that available in the market? How much does it usually cost?
  • · Replies 27 ·
  • · Replies 21 ·
  • · Replies 21 ·
