What is the effect of conveyor belt inertia on the movement of a ball?
  • Context: Undergrad
  • Thread starter Thread starter marked1000
    Belt Conveyor Inertia
The discussion centers on the dynamics of a ball on a conveyor belt influenced by the belt's inertia and the motor's torque. The setup involves a circular motor that drives the belt, which transitions from a straight path to an inclined or declined angle. Key equations include two force equations (Fx and Fy) for both the horizontal and inclined scenarios, as well as motor equations involving torque (Iα) and angular acceleration (a = rα). The primary unknowns are the angular inertia of the motor, the mass of the ball, and the mass of the belt, which complicates the analysis of forces acting on the ball during its movement.
  • Understanding of Newton's laws of motion
  • Familiarity with torque and angular inertia concepts
  • Basic knowledge of force equations in physics
  • Ability to analyze motion on inclined planes
  • Study the principles of rotational dynamics and torque calculations
  • Learn about angular inertia and its impact on moving objects
  • Explore the effects of gravity on objects on inclined surfaces
  • Investigate the relationship between linear and angular acceleration in mechanical systems
Students in physics or engineering disciplines, mechanical engineers, and anyone interested in the dynamics of moving objects on conveyor systems.
marked1000
This is a possible problem that I can have on my quiz.
There is ball on a conveyor belt. The belt is moving to the right, and a circular motor is running the belt. The belt starts of straight then starts to bend where the circular motor is. The circular motor is just at where the bend occurs and is of course under the belt. The same ball after passing the motor is now on the belt at an angle.
Now we have been told there will be six equations.
Two force equations for when the ball was sitting normally on the belt as the belt motored on. Fx and Fy
Two force equations after it passes the belt. Fx and Fy
Two equations for motor : Iα and a=rα
You might need to draw a picture. I can't understand from explanation alone what this setup looks like.
So the motor is providing a torque Iα and the belt is initially accelerating at rα with the ball accelerating at some fraction of the belts rate depending on it's angular inertia while on the level surface. The force on the ball equals the mass of the ball times it's linear rate of acceleration. Once the ball is on the inclined (or declined) portion of the belt, gravity also exerts a force on the ball.
The unknowns are the angular inertia of the motor (since it's torque was specified as Iα, but I is unknown), the mass of the ball, and the mass of the belt (I'm not sure how to deal with the angular inertia component for the belt). You could probably assume the ball is a sphere of uniform density to determine it's angular inertia.
If Fx and Fy are the forces applied by the belt to the ball, then for the horizontal (level belt) case, you only need to know the rate of acceleration of the belt, and the angular inertia and mass of the ball. What isn't known is how the motor responds once the ball is on a decline or incline, since either the torque and/or the rate of acceleration of the belt will change.
11K
  • · Replies 45 ·
