| New Reply |
Finding the 3 Rotation Angles of an Object relative to another point. |
Share Thread | Thread Tools |
| Dec8-10, 11:38 AM | #1 |
I have a weird problem I can't seem to figure out.
I am creating a 3D project; In the project I am creating a Sphere of Radius r at Origin(0,0,0) Then I am finding x number of points around the sphere that are equal distance apart; that is if I parameterize 6 points it will be 6 vectors returned at each axis both negative and positive. In most cases the number is like 11 or 12 the function I am using is the "Hypercube Rejection Method" At each of these points, I am placing a "cone" which is oriented along the X-axis the points determine the center of the cone mesh. I want to point the cone towards the origin. How do I find the Angles of Rotation on all 3 axis per cone since they will all vary from their orientation of 90 Degrees off the X-Axis(yaw), 0 Degree off the Y-Axis(pitch) and 0 Degrees off the Z-Axis(roll). The problem isn't a LookAt problem; it's a Pitch,Yaw, Roll degree calculation; based off of the origin and the center points of the meshes. |
| New Reply |
| Thread Tools | |
Similar Threads for: Finding the 3 Rotation Angles of an Object relative to another point.
| how do u convert relative angle to absolute angles? | Introductory Physics Homework | 4 | ||
| Euler angles of rotation about x=y=z | Differential Geometry | 1 | ||
| Adding angles of rotation | Introductory Physics Homework | 2 | ||
| Relative Velocities with angles | Introductory Physics Homework | 1 | ||
| Rotation Angles for 3D Vector | General Math | 2 | ||
