Why Does the Basis (1, 1, 1) Satisfy the Given System of Linear Equations?
The basis for the subspace defined by the linear equations a - 2b + c = 0 and 2a - 3b + c = 0 in R^3 is (1, 1, 1). This vector satisfies the condition that all solutions can be expressed as scalar multiples of (1, 1, 1), indicating that the subspace is one-dimensional. The intersection of the two planes represented by the equations results in a line where a = b = c, confirming that the basis must consist of three components corresponding to the dimensions of R^3.
  • Understanding of linear equations and their solutions
  • Familiarity with vector spaces and subspaces
  • Knowledge of R^3 coordinate system
  • Basic concepts of linear combinations and scalar multiplication
  • Study the concept of vector spaces in linear algebra
  • Learn about the geometric interpretation of linear equations in R^3
  • Explore the properties of bases and dimensions in vector spaces
  • Investigate the relationship between linear independence and spanning sets
Students of linear algebra, mathematicians, and educators seeking to deepen their understanding of vector spaces and linear equations in R^3.
vsage
Ok another question:
13. The set of solutions to the system of linear equations
a - 2b + c = 0
2a - 3b + c = 0
is a subspace of R^3. Find a basis for this subspace
The book claims one of the possible bases is (1, 1, 1) but I don't see how. I mean I realize a = b = c from the above just am not making the connection why there has to be THREE 1's. Originally I had (1, 1) but I really can't remember why. Is it because since a, b and c are equal, all the solutions to the above in (a, b, c) format are given by d(1, 1, 1) where d is a scalar?
a - 2b + c = 0
2a - 3b + c = 0
Makes perfect sense. Think about it...the set of solutions is a set of real numbers (a, b, c) that satisfy both linear equations. It sounds like such a set has three components, necessitating that it be a vector in R3. In fact, a = b = c is satistied by vectors of the form (1, 1, 1)...(2, 2, 2), ...(3, 3, 3). But all of these can be written as linear combinations of (1, 1, 1). Which is exactly what you said...all others are scalar multiples of that vector. The subspace is the line through the origin. One vector is sufficient to span a 1-dimensional subspace, but that subspace is located in R3, so the basis vector must have three components.
Another way to look at it...those two equations define two planes in R3, (where in this case our coordinate space is formed from the mutually orthogonal a, b, and c axes) and evidently they intersect in the line a = b = c.
If you were just trying to SOLVE the equations, you would subract one from the other to cancel the "c" terms and get -a+ b= 0. Okay, a= b. Now put that back into the first equation: setting a= b gives -a+ c= 0 so a= c. If you put a= b= c into the second equation, you find it is automatically solved: any numbers a= b= c satisfy both equations so (a, b, c)= (a, a, a)= a(1, 1, 1). The have to be THREE numbers in the "basis" because your solution consists of 3 numbers, a, b, c.
(By the way, your book says "one of the possible bases" because, of course, (2, 2, 2) or (3, 3, 3) or any set of 3 identical numbers would work.
  • · Replies 42 ·
