Help Needed: Adjusting Cabinet Dimensions Urgently
  • Thread starter Thread starter quickfingers81
    Dimensions
The discussion centers on adjusting cabinet dimensions from 1000x450x350 mm to 500x500x300 mm during the manufacturing process. Key considerations include calculating the sizes of boards required for both dimensions and understanding material loss during cutting. The conversation emphasizes the importance of tolerances in manufacturing and the implications of cutting boards that have already been sized for the original dimensions. The need for clarity on whether multiple cabinets are being produced is also highlighted.
  • Understanding of basic woodworking and cabinetmaking principles
  • Knowledge of material properties and tolerances in manufacturing
  • Familiarity with cutting techniques and tools used in woodworking
  • Experience with dimensional calculations for cuboidal shapes
  • Research board cutting techniques to minimize material loss
  • Learn about tolerances in woodworking and their impact on design
  • Explore software tools for cabinet design and dimension adjustment
  • Investigate best practices for managing changes in manufacturing specifications
This discussion is beneficial for cabinet makers, woodworking professionals, and anyone involved in furniture manufacturing who needs to adapt designs and manage material efficiently.
quickfingers81
Please someone help me to answer this question...Urgent
You're halfway manufacturing a cabinet 1000x450x350(D).You're informed that the size change to 500x500x300(D).What do you do?
Assume you are making a cuboidal box. What are the sizes of the boards needed in each case ? Since it's not stated at what stage the change occurs, let's assume you've cut the boards to the first requirement. Now from these boards, can you cut the boards needed for the second case ? What are the allowed tolerances ? If you take a 1000 long board and cut it in half, you get nearly 500 long boards, but you lose material some from the cut, unless you shear.
And when you say 'manufacturing', are you making just one cabinet or several ?
That should get you going...
  • · Replies 42 ·
  • · Replies 26 ·
