New Reply
Arc length of a circle using integration
Share Thread Thread Tools
Dec12-10, 09:04 AM   #1
Hello there,
suppose i want to find the arc length of a circle x^2+y^2=R^2 using integration, implicitly differentiating the equation, i find y'=-(x/y)
now,
arc length (circumference)= ([tex]\int[/tex] [tex]\sqrt{1+y'^2}[/tex]dx
putting the value of y'=-(x/y) and substituting for y^2 from the equation of the circle
(y^2= R^2-x^2)
solving, the equation i get
circumference= R*{ sin-1 [x/R] }[tex]^{a}_{b}[/tex]
where a and b are the limits of integration
whats bugging me here is the limits, when i use the limits [-R,R], i get circumeference=[tex]\pi[/tex]*R
now what i dont get is why do i have to multiply by two to get the actual answer, i mean i didnt use the equation of the upper/lower semicircles ANYWHERE in my calculations, shouldnt these limits be giving me the full circumference, without the need to multiply by two??
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Dec12-10, 09:17 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Well, -R to R is the interval x runs along on the--half circle.
Remember that the inverse sine function is uniquely defined only on intervals of the type 0 to pie.
Dec12-10, 09:24 AM   #3
Thanks for the quick reply arildno.
ButI still don't get it, I mean x runs along both half circles doesn't it?
both upper and lower AND our function (x^2+y^2)=R^2 accounts for both the semi circles, so shouldnt it's integral ALSO account for both half circles?
Dec12-10, 09:32 AM   #4
Recognitions:
No.
Because a function can only have one function value for each argument value.
The graph of the full circle is not the graph of a function because for practically all x-values, there are are two y-values on the graph.
Thus, representing "y" as a function of x, you have necessarily restricted yourself to the half-circle.
You could do differently, by regarding BOTH "x" and "y" as functions of a single variable, say the angle made to the positive x-axis.
In that case, you have the parametrization:
[tex]x(t)=R\cos(t), y(t)=R\sin(t), 0\leq{t}\leq{2\pi}, R\geq{0}[/tex].
In this case, your arc-length integral becomes:
[tex]L=\int_{0}^{2\pi}\sqrt{(\frac{dx}{dt})^{2}+(\frac{dy}{dt})^{2}}dt=\int_ {0}^{2\pi}Rdt=2\pi{R}[/tex]
Dec12-10, 09:51 AM   #5
OK, I'm starting to get it a bit.
A function, should only have one y value for each x value, so inverse sine is a function if and only if we restrict the range (i.e.we make it the principal inverse sine function).
BUT if we consider sine inverse (the relation; which has an unlimited range), then does the fact (that a FUNCTION can only have one y value for each argument), make any difference in our ability to calculate the arc length of sine inverse (again the relation not the function) in a range of (say) -100pi to 100pi.
can we directly apply the limits in the integral (as i have applied to the circle equation) or do we have to account for the fact that sine inverse is not a function and multiply the answer by some constant (as in the case of the circle) in order to get the "real" arc length?
(If Im not wrong)we do NOT have to do anything of this sort in case if the inverse sine. Why are these two cases different/?
Dec12-10, 10:14 AM   #6
Recognitions:
Well, you can't integrate a "relation", in your usage of the terms.
Only among functions do you find integrable fellows.
Dec12-10, 10:17 AM   #7
but supposing i integrate sine inverse the function, (i can do that cant i?)
THEN i apply the limits of integration from -100pi to 100pi (which are not Actually in the range of the function), will that give me the arc length?
Dec12-10, 10:23 AM   #8
Recognitions:
No.
Because those values are not within the domain of your function.
Dec12-10, 10:26 AM   #9
i mean if i integrate with respect to dy. then take the limits -100pi to 100 pi, that would give an answer, what would be the physical meaning of that answer?
Dec12-10, 11:32 AM   #10
Recognitions:
Sigh.
you have WRONG ideas about what functions&integration are.
Go back to your texgtbolok, there is nothing further to be said on this matter.
Dec15-10, 12:25 PM   #11
The way I see it, there are several problems with your analysis are:
1. The equation of a circle (x^2 + y^2 = R^2) is not a function in the first place because each x value maps to two separate y values. You either have to break the circle into two halves and then multiply by 2, or use the parametrization (x = R cos t, y = R sin t). To properly use the arc length formula, you have to use the parametrization.
2. You are using the substitution y^2 = R^2 - x^2. Because the arc length formula you're using integrates over dx, you are making y a function of x (y(x) = Sqrt[R^2 - x^2]) which only yields a half circle.
3. The real part of the inverse sine function doesn't have an unlimited range. Both the domain and range are bounded. The domain is [-1,1] and the range is [-Pi/2,Pi/2].
If I'm wrong, please let me know. I am by no means an expert.
New Reply
Thread Tools
Similar Threads for: Arc length of a circle using integration
Thread Forum Replies
Integration of part of a circle Calculus & Beyond Homework 3
Define Circle Knowing Two Points and ARC LENGTH Only. General Math 4
Length of a portion of a circle Differential Geometry 12
Length of Wire Around Circle of Cylinders. Calculus & Beyond Homework 5
calculation of length inside a circle Precalculus Mathematics Homework 7
