Find Empirical Formula for Gas X: C_7H_16
  • Thread starter Thread starter Clari
    Formula
The empirical formula for gas X, which has a density of 1.187 g/dm³ at 1.01 atm and 35°C, is determined to be CH₃. The initial calculations indicated a mole ratio of carbon to hydrogen as 7:20, leading to an incorrect empirical formula of C₇H₂₀. Upon reevaluation, it was clarified that the correct empirical formula is CH₃, as a gas with seven carbon atoms is illogical in this context.
  • Understanding of mole ratios and empirical formulas
  • Knowledge of gas laws and conditions (e.g., density, temperature, pressure)
  • Familiarity with chemical composition and percentage by mass calculations
  • Basic proficiency in LaTeX for chemical notation
  • Research the properties and applications of hydrocarbons, specifically C₇H₁₆ (Heptane)
  • Learn about the ideal gas law and its applications in determining gas properties
  • Explore the concept of molecular vs. empirical formulas in organic chemistry
  • Study the simplification of ratios in chemical formulas and their significance
Chemistry students, educators, and professionals involved in organic chemistry and gas analysis will benefit from this discussion.
Clari
A gas X has a density of 1.187[tex]gdm^-3[/tex] at 1.01 atm. & 35[tex]^oC[/tex]. Gas X contains 79.8% by mass of C & 20.2% by mass of H. Find the empirical formula of X.
Here are my steps:
mole ratio of C to H = 79.8/12.01 : 20.2/1.008
= 7: 20
In that case, its empirical formula is [tex]C_{7}H_{20}[/tex] while I don't think there is a gas with this formula, the closest one is [tex]C_{7}H_{16}[/tex]. Can anyone help me with it?
I know what's wrong now...I have mistaken it as the molecular formula...hheee...being silly...so the answer should be [tex]CH_{3}[/tex].
Chemistry news on Phys.org
Ok.
Note: to make your Latex fit into the text, use "itex" and "/itex" in the brackets instead of "tex" and "/tex".
It is very simple; just simplify the ratio, [itex]\frac {7}{20}[/itex] to obtain [itex]\frac {1}{0,35}[/itex]. As you know that a carbon-containing gas must contain up to five carbon atoms, a gas with seven carbons would not be logical. So just simplify the ratio for your needs.
14K
