Help finding kinetic and potentail.
  • Thread starter Thread starter leonne
    Kinetic
The discussion focuses on the derivation of kinetic and potential energy for a system involving two masses, m1 on a frictionless table and m2 hanging from a pulley. The correct kinetic energy expression is T = 1/2 (m1 + m2) \stackrel{.}{x}^2, where x represents the horizontal displacement, while the potential energy is given by U = -gmx, indicating that the potential energy is negative when the initial height is set to zero. The confusion arises from the relationship between the movements of the two masses, where the vertical movement of m2 corresponds to the horizontal displacement x of m1. The Lagrangian formulation is also mentioned as a method to analyze the system.
  • Understanding of Lagrangian mechanics
  • Familiarity with kinetic and potential energy equations
  • Knowledge of basic physics concepts such as mass, gravity, and motion
  • Ability to apply calculus in physics problems
  • Study the derivation of the Lagrangian for mechanical systems
  • Learn about the relationship between kinetic and potential energy in conservative systems
  • Explore the concept of energy conservation in pulley systems
  • Review examples of systems with multiple masses and their interactions
Students studying classical mechanics, physics educators, and anyone interested in understanding the dynamics of systems involving pulleys and multiple masses.
leonne
mass m1 rest on a frictionless horizontal table and is attached to a mass less string. The string runs horizontally to the edge of table passing threw mass less pulley and than mass2 hangs there.
I thought the kinetic would be
T=1/2 (m1[tex]\stackrel{.}{x}[/tex]2) + m2[tex]\stackrel{.}{y}[/tex]2)
and than potential would be U=gmy
but they have it as T=1/2 (m1+m2)[tex]\stackrel{.}{x}[/tex]2)
U=-gmx
Why is this? I thought block 2 moves in the y direction so why is it given velocity in x direction same thing with potential and why is it negative?
thanks
What is the question? :confused:
This is the kinetic energy at a certain value of x and y, where x = y in magnitude, since they move together
yes, at a certain point y, but if the initaial value of y is taken as zero at the start point, then this term is negative, since y is negative
same answer as your's, where x = y, and the equation is then factored
U=-gmx
Yes ,see above, and note x = y
thanks
Still confused? But what is the actual question?
the question is to write down the Lagrangian for the system and to solve for acceleration that part is easy just suck at figuring out the potential and kinetic lol
  • · Replies 33 ·
  • · Replies 22 ·
